Samsung LCD tv mod # LNT3242HX/XAA is dead. The red power led is on as soon as plug in tv, but nothing else lights up. Found Q8802 trans (on ac power mod) running extremely hot. There were no voltages at CNM801 or CMN802. What other test should be made?? What mod should be replaced???
  • 6,993 Answers
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Compliments of the season.
Posted on Dec 30, 2010
I have samsung plasma tv hpp5071x/xaa when i push the power button with remote control, i can hear cliking sound and looks like turn on and see red led light at the bottom right corner and also saww flash...
Hey If you have tried Using remote and side pannels Have you tried another TV to see if its the Cable? Also The clicking sound is normal its the TV's Power-source starting. The fan light I am not sure of but if it happens every-time it should be normal. If the screen gets warm Instantly (Hotish) Then you TV is dead D:
Mar 14, 2014 | Samsung PN42A450 Plasma TV
SAMSUNG LNT3242HX/XAA REPLACEMENT SCREEN
Replacement displays are the most expensive part of the TV and getting a new one will cost more than a replacement TV. You can check on Ebay for a unit that will not power up and you may be able to get a screen cheap enough but it most cases if the screen is broken then the TV is not worth repairing. Sorry
Jul 24, 2012 | Samsung Televison & Video
Need service manual for Samsung LNT3242HX/XAA, RM801 open
Found that the yellow glue that hold some of the components in starts to break down and start conducting causing a short between R801 and CM810 Replace the open resister and remove all the glue off the power supply
Feb 29, 2012 | Televison & Video
Samsung 50" plasma HPS5033X/XAA shut off and will
HGi:
This model is nortorious for Y-sustain board failure, replace the Y-sustain board and you should be good to go. The Y-sustain board is the one while standing with back off the set is the board on the left side of the television.
Jul 05, 2011 | Samsung HP-T5044 50 in. Plasma TV
My philips ambilight wont switch on i can hear clicking noise and red standby light keeps flashing any ideas
U have tools like a soldering iron,desoldering pump or roll of desoldering braids,a roll of solders and understanding basic electronic also can do basic soldering?This problems,most of the times are causes by those dying soon to be dead components call capacitors on the power supply board.Yes,take ur tv aparts,the power supply board,that the board,where the power a/c cord plug into it.Check the power supply board for those dying soon to be dead capacitors parts,it alway bulges up on it tops or puffing up on it tops.Replaced these dying soon to be dead capacitors parts,will solved ur tv noises clickings,power LED light indicator will stop flashing.Tv will power up normal again an work.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 20, 2010 | Philips 32PFL7332D 32 in. LCD HDTV
TV wont turn on
a bad power supply is most likely cause of this. Other possible cause is bad main circuit board.
May 03, 2010 | Samsung HL-S5086W 50" HDTV
Panasonic TX-32LXD60 won't switch on. Red standby light flashes quickly and then becomes constant. TV Clicks and slight flicker then nothing. Can anyone help please ?
U have sound at all?Yes,than ur LCD INVERTER backlight board it dead.If power LED light keep flashing nothing on,sound or picture.Than the power supply board is dead.Must replaced the power supply board.Tries Websites Shopjimmy.com,Ebay.com to buy these refurbish boards.
Feb 26, 2010 | Panasonic TX32LXD60 32 in. LCD TV
Samsung LCD TV doesn't power on, just blinks 5 times
After about 5 years the Samsung LCD televisions backlight fails which prevents the TV from coming on and the powerlight just flickers the backlight can be changed but it is often alot easier and cheaper to buy a new Television
Sep 14, 2009 | Samsung LNT2642H 26 in. LCD Television
SAMSUNG LCD MOD.LE32S71B : AT START THE RED LED PULSES
Replace swollen capacitors on the power board.
Sep 11, 2009 | Televison & Video
Televison & Video Logo
513 people viewed this question
Top Televison & Video Experts
Electro Med Services...
