SOURCE: Remote Control Doesn't Work
You could pick up an IR tester. Your local electronics hobby store should have them. Also, you sound as if you have some electronics ability, you could do a search on the net and find a electronics hobby site and build yourself a tester. This is what I did. Now, in my 27 years of electronics I have never seen a bad IR section of a remote. the most common problem is broken solder connections. remotes get dropped, tossed, stepped on, etc... Open the unit up and look for bad solder connections. They do not have to have a physical break to be bad! If they are grey instead of shiny or if you see a ring around the lead then the connection is bad. Reflow all connections and clean all contacts. I would think that will get it back to a working conditon.
SOURCE: Need Remote Control Code
All these codes are used by Teac
Hopefully one will work for you
0037
0512
0455
0264
0009
0412
0349
0041
0000
0278
0037
0081
0307
0609
0110
0717
SOURCE: Factory Remote Control for Sylvania model SRT2319 doesn't work
You can buy an original replacement remote for your TV clicking the link below:
New Original Sylvania SRT2319 Remote Control $39.99
SOURCE: neewd remote control number
well you say that you need to get another remote for you TV..you can buy it here at this link..http://www.amazon.com/Akai-LCT3701AD-Panel-Built-Player/dp/B000WEODRU ..ok
SOURCE: Sharp A/C remote CRMC - A310JBEO RO3 (AAA) 2PCS is not working
There are two AAA batteries hidden below the keypad under the sliding cover.
Gently prise off cover to real batteries, and replace them.
