Question about Sunpentown 12,000 BTU Portable Air Conditioner WA-1230H
I have lost the instructions for a Sunpentown WA-1220E. How do I get a new booklet?
2 Suggested Answers
daddyo742001
  • 70 Answers
SOURCE: My Sunpentown WA-1220E portable air conditioner is
Sounds like compressor failure, overheat or some other reason can't get started. Make sure everything is clear and unplug and let it set for a while and try again. If that don't help take it to shop.
Posted on Jun 28, 2009
The ac unit will not turn on. The "comp" red light is on & it beeps
Did you get a manual with this unit? I believe the red light is a ground circuit fault interrupter GFCI. This detects minute amounts of leakage current and opens to protect the user from a shock. Is there a drain located on the unit for the moisture that is naturally condensed out of the air you are conditioning? If so, that needs to be drained. Many of the GFCI's they place on these units are cheap as they are made in China. I believe your unit takes some or all of the condensed moisture and runs it over the condensor coil to cool the coil, which is OK. My question is where does the excess moisture end up and how does this unit get rid of it? I believe they sell these at Wal Mart so I know it was made in China.
Aug 03, 2011 | Sunpentown WA-1220E Portable Air...
Need instruction manual for Sunpentown WA-7500M
You can get the manual on the link below I hop it will help you.
http://www.sylvane.com/images/productpages/sunpentown/manuals/WA-7500M.pdf
Good Luck and please rate 4 thumbs up for the free answer
Jun 19, 2010 | Sunpentown 7500 BTU Portable Air...
Sunpentown WA-1210E
The unit is probably undersized for the space. Rule of thumb is 12000 btu per 500 sq ft. Take a thermometer and measure the entering air to the unit and then hold it in the outlet air stream you should see a temp. difference of about 10 to 15 degrees if it functioning properly. Hope this helps 2rns4u <*{{{>(
Jul 22, 2009 | Sunpentown WA-1210E Air Conditioner
My Sunpentown WA-1210E airconditioner stopped working. It emitted several beeps and the power light is blinking continuously. When I unplug, wait a few minutes and replug in the unit, it shows the same...
Have you checked the water container in the unit? It has a float switch that when it is full it will not allow the unit to run so that it will avoid spilling water on to the floor. Hope this helps 2rns4u <*{{{>(
Jun 29, 2009 | Sunpentown WA-1210E Air Conditioner
My Sunpentown WA-1220E portable air conditioner is not working. Comp light is flashing (red light). Any idea what could be wrong?
Jun 28, 2009 | Sunpentown WA-1220E Portable Air...
Why is my sunpentown WA-1210H portable AC not blowing cold air anymore?
Might be a dirty filter, a burnt compressor wire or a bad capacitor. Or it could be a bad thermostat.
May 10, 2009 | Sunpentown WA-1220E Portable Air...
Spt portable ac unit keeps tripping and will not turn on
Sounds like you have a short in the high voltage wiring. The compressor may be bad.
Mar 10, 2009 | Sunpentown WA-1220E Portable Air...
Sunpentown 12,000 BTU Portable Air Conditioner WA-1230H Logo
Top Sunpentown Heating & Cooling Experts
Dan Webster
Dan Webster
Steve F
Mister Danger
Are you a Sunpentown Heating and Cooling Expert? Answer questions, earn points and help others
