Question about Sony Video Game Consoles & Games
Samsung lcd tv le26r74bd mode not supported hdmi ps3 why please
SOURCE: Samsung LCD tv and PS3
the problem is with the frames per second that the ps3 is putting out. i wound up calling both samsung and sony and the problem was in the settings. the ps3 allows you the option of playing in 24hz and for some reason if the option isn't turned off our tvs won't display frames at that rate. just go to the dvd settings and deselect the 24hz option, changing it from AUTO to OFF... the only problem i have with this is that this should effect the picture quality, becasue if it isn't displaying in 24hz that means it is downscaling the display and if it isn't upscaled by the tv's processor, then the display should be worse. i might be imagining it, but it does seem worse.. atleast they play now though. hope i helped.
Posted on Nov 10, 2007
SOURCE: PS3 not working through HDMI cable
connect PS3 to TV select HDMI channel on TV press AND HOLD power button on PS3 until screen resolution selection page appears.
PS3 should now work.
had this problem, this solved it.
typical repairman looking for work :)
Posted on Jun 29, 2008
issken
  • 1472 Answers
SOURCE: PS3 setup to Denon AVR 2807 & Samsung LCD
Azahid
Since you are running the to LCD monitor instead of a LCD TV this is where you run into the issue. because the monitor is not setup to pull out the audio from the HDMI connection. So there is a few ways that you maybe able to to this.
The first one is look around at the different output cables out there the PS3. (I just got one so I do not know the accessories that are out for the PS3) This is becoming a common setup so if Sony does not have cable that will split off the audio then a 3rd party group may. I know they have one like that for the XBOX 360.
Another you can try is if your monitor will except an analog connection you may need to go that way. That is how I have my XBOX 360 that is my room connected. I have a RBG HD to VGA connect the VGA input on the monitor and the audio going to my sound card.
The reason why I suggested going analog is that right with our curent technology that if you are run with the 2 formats at the same time you will get audio/video sync issues. So you need to go all analog or all digital.
I hope this helps. Let me know if you have any other questions on this and/or need me to clarify anything.
Issken
Posted on Sep 29, 2008
SOURCE: Ps3 not playing blu ray on my samsung LCD
Change the frame rate on your tv to 60hd, that should solve it. Basically, your tv might be set to theater mode which is playing 24hd..
Posted on Jan 02, 2009
SOURCE: PS3 not working thru HDMI cable
i am having the same problem, so i called the mfg. of the tv and they told me to set the PlayStation to out put 1080i and not 1080p i don't think this is possible. my tv is a Hitachi and they are sending me an update card for the tv, hopefully this will fix the problem. Apparently its a problem with the tv not being able to receive a 1080p signal
Posted on Oct 31, 2009
Hdmi for playstation is not supported
Do a hard reset on your ps3. Hold down power button until it turns off or unplug the unit. Leave off for several minutes. Restart PS3 and set HDMI setting on TV to 720p.
Oct 19, 2012 | Samsung LE32R73BD 32 in. HD-Ready LCD...
My samsung tv wont connect to my ps3 through the hdmi cable, the tv works if i connect my laptop or anything else to it. iv tried my ps3 on my lg an it work just fine just cant get it to work on my samsung...
When you have PS3 connected to the TV with HDMI connector, hold the ps3 power button down for 5 seconds, when u hear 2 beeps, release it and it should display standard format on the TV, thats when you'll get the option to correct the picture mode for the PS3. Hope that helps.
Dec 23, 2010 | Samsung LN52A650A LCD TV
Cannot connect my ps3 to my tv. keep getting (mode not supported)on a black screen. anyone help ?
Check the supported modes in your user's manual for the TV. Check the output mode of the PS3 from its manual. Can you find any that match? If not, then you can't make it work....
Apr 23, 2010 | Samsung LE32R72B 32 in. HD-Ready LCD...
Samsung LN-T4042h to PS3 "Not Supported Mode"
i fixed it, on the PS3 u hold the power Button while holding then Switch the power button on on the back for like 10 sec and it resets the picture settings to default
Oct 24, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
'MODE NOT SUPPORTED' message appears on my TV screen
i have samsung 22' lcd series 4 tv but i connected it with the dvd player via hdmi it shows mode not supported. but the same dvd works very well on another samsung lcd of same configuratition. please help me
Jul 13, 2009 | Samsung Televison & Video
PS3 will not work on new tv using HDMI cable ?
you have to re sync your playstation when you go from HDMI to regular wires.
after you connect ps3 to tv.
hold down the power buttondown on the ps3 for like 5 seconds (1 beep then another ),
after you hear a second beep the ps3 automoatically adjusts itself to whatever it's connected to.
Feb 26, 2009 | Samsung Televison & Video
HDMI Problem
check your owners manual tv. my tv has 3 hdmi input.your tv manual will tell you which one to use. make sure you select the correct resolution. 1080p/720/480 etc. oh...make sure you have hdmi cables too
Nov 08, 2008 | Samsung LN-T2653H 26 in. LCD HDTV
Sony ps3 an samsung tv
Well your PS3 Can't connect with your TV to the Samsung, because PS3 Was made HD Blu-Ray. If your TV/Samsung is not supported by High Def. or Blu-Ray, it will not work, you will need a different HDMI Cable, and it should work fine.
Hope this Helped.
Jul 12, 2008 | Sony Playstation 3 (PS3) Console
May 14, 2008 | Sony Playstation 3 (PS3) Console
Samsung LCD tv
same problem.. i always get the screen: "not supported mode". whatever the hell that means. so the issue is definately with the tv and not the playstation. has anyone tried contacting Samsung?
Nov 03, 2007 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
192 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
