Question about Xerox Phaser 6300N Laser Printer
We have a Xerox Phaser 6360 and the ink on the pages is not fully tranfering to the paper in some areas causing the ink to rumb off and the image on the paper to start to disappear. The printer has not notified us that it needs anything replaced and we have tried to clean the machine. Is this a problem that can be fixed and how?
    Scholar:
  • 57 Answers
This sound like it could be a media problem. Check and/or play with your paper settings, or try using different paper.
Hope this helps.
Posted on Jan 19, 2011
Just put in a new imaging unit to a xerox phaser 6360 and now everything is pink... any ideas how to fix?
Check which colour you replaced and check that everything is seated correctly.
Good Luck.
Jul 22, 2014 | Xerox Phaser 6360 Laser Printer
I have a Xerox Phaser 6360 that one day just stopped printing yellow, despite having plenty of ink. Xerox told me I needed a new imaging unit, so I replaced it, but it didn't help. I put the old one back...
Your machine uses solid ink wax blocks. So no calibration is necessary. Does the self test print look good. I suspected not.
Check out the Xerox.com website. It could be a problem as you machine is no longer sold.
Sorry.
Oct 16, 2013 | Xerox Phaser 6360 Laser Printer
Not printing cyan on xerox 6360
INK PROBLEM
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Jan 22, 2013 | Xerox Phaser 6360 Laser Printer
Xerox phaser 6360 imaging unit stuck
The lid lifts a lever on the right side of the printer that moves a set of gears that releases the imaging unit. If the lever is broken or disconnected, it will not release. You may have to remove the right side panel to resolve it. You have to release the top, by removing 4 screws, and then the panel will release.
May 18, 2012 | Xerox Phaser 6360 Laser Printer
The black print jobs have a shadow about 3 inches down the page
I had replaced the fuser - no improvement. I removed the fuser, imaging unit & transfer roller. CAREFULLY using a vacuum cleaner I cleaned all units and the internals of the printer, rotating the roller on the imaging unit to clean all parts. (Warning Place Imaging unit on paper as toner escapes) After a few test prints the page cleared and duplicate ghosting cleared.
Apr 07, 2010 | Xerox Phaser 6360 Laser Printer
Are LD products safe to use?
Safe , most likely, recommended? I don't recommend using generic supplies in anything but ink ket printers. By that I mean the liquid inks. The toner is a phaser is pretty unique, and the OEM toner is by far the best way to go.
Jan 20, 2010 | Xerox Phaser™ 6360/DT Printer
I have a problem with ghosting on a Xerox Phaser 6360. Have replaced the Transfer Roller, Imaging Unit, and Fuser. It looks like the problem is mainly in Magenta. This is not a repeating defect, but a...
I have the same problem with whatever color that used most. The Xerox sent its people over to fix it. However, the problem gets after a few days. Probably, it cannot handle large volume.
Dec 02, 2009 | Xerox Phaser 6360 Laser Printer
I have a customer with a Phaser 6360. The are
i think check your color space on the applications you printing from:)
Nov 24, 2009 | Xerox Phaser™ 6360/DT Printer
Xerox Phaser 6360N ghosting images on each page
Is it a ghost of the image or just a repeating defect? In the menu, there is a repeating defect information page that you can print out. Depending on the spacing of the defect, you can determine which component it is.
Mar 10, 2009 | Xerox Phaser 6360/N Printer
Xerox Phaser 6300N Laser Printer Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
