Question about Bugaboo Cameleon - Tailored Fabric Standard Stroller
Wheels sticking will not open lock jammed - Bugaboo Cameleon - Tailored Fabric Standard Stroller
    Guru:
  • 541 Answers
The bugaboo brake lever can lockup. Check the screw nut at the bottom end of the cable. If you can wind that down to take some tension off the cable the lever will them release. If there is no adjustment try lifting the lever up higher (as to put the brake on harder) then push the white release button at the same time. The break lever uses a set of ratchet teeth that must move up slightly to release.
Posted on Jan 02, 2011
I have 2003 gallant, Islammed on the brakes really hard, tried to drive the car from that spot, go in gear but wouldn't move, front wheels roll, rear wheels are locked up.
If rear brakes are drum-type it is possible the shoes are jammed on the drums. They are normally retracted from there by springs, but if there is breakage or corrosion they can jam in place. One place corrosion occurs is in the wheel brake cylinders, so then the pistons do not return properly,
The same can happen with disc brakes as the pads are normally pulled back after application, just a little, by the springiness of the rubber parts on the pistons. So if there is corrosion in the calipers the pistons can stick.
Then, if disc brake pads are worn right down, I have heard of cases where the piston popped right out of the caliper on heavy braking, or else turned a bit sideways and jammed on. It should never happen, but apparently did.
If disc brakes you should be able to see this when the wheel is off. The calipers can then be removed. If drum brakes try hammering on the outside rim of the drums, this way and that, to get enough de-jamming to get the drums off.
Nov 17, 2016 | Cars & Trucks
I only have reverse and first gear on my 76 gmc th350 with over 30000miles rebuilt, what could possibly be wrong?
The synchromesh jamming, no oil, gear wheel teeth shredded, part of a gear broken and jamming, open gearbox and have a good look, this will reveal all and moving the gear stick.
Feb 22, 2015 | GMC Cars & Trucks
Xerox Phaser 8860 error 09,005.40:71198
Want to resolve your printer issues online then, dial Xerox Printer Support Phone Number1877-778-8@9@6@9 anytime as you like. For further Info Click:https://goo.gl/Co2Bom
Oct 30, 2014 | Xerox Phaser® 8860/8860MFP Extended...
Citroen troubleshooting
Change the lock cylinder and keys. There should be a place to stick a pin in there to release the old cylinder.
Aug 06, 2014 | Citroen C4 Cars & Trucks
Our Kenmore Microwave Hood combo model # 401.88529011 door sticks and is very hard to open off and on
Possible that the door lock is jammed, it can also be due to jamming of the door switch or the plastic lock being stuck on.
You need to remove the front panel , and reset the door assembly.
Jan 25, 2013 | Kenmore Microwave Ovens
Whirlpool microwave won't open
Possible that the door switch is broken or jammed,. You need to remove the top cover, open the panel and remove the door and switch , check for broken plastic or lock, If so use glue to stick and reset.
Jan 24, 2013 | Microwave Ovens
Chrysler sebring door lock jammed
The latch may be "tripped".
If you open the other door and look at the latch in the side of the door you may see the difference.
Sometimes you can take a screwdriver and move the wheel in the latch back to "open" position. The wheel turns as the door hits the striker post.
Jan 12, 2013 | Chrysler Sebring Cars & Trucks
Back wheels have locked up
Check the calipers for sticking, also check the lever where the e-brake cable connects to and makes sure the lever operates smoothly. You may need an assistant to operate the e-brake.
Mar 06, 2010 | 2004 Toyota Sienna
Left drivers door handle and lock stick
try spraying wd-40 into the key hole and on the door jam.
Nov 28, 2008 | 1996 Saturn SL
When I put my key into the ignition, key won't turn, it's too strong and feels like it's locked. What could be the cause and what can I do to start it up again?
try this take the steering wheel and turn it slightly to the right or left and turn the key at the same time. repeat several times. sometimes the locking detente in the steering column either sticks or gets jammed. this should solve the problem. please rate this....thanks
Sep 26, 2008 | Mitsubishi 3000GT Cars & Trucks
Bugaboo Cameleon - Tailored Fabric Standard Stroller Logo
138 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
J.D. Browning
J.D. Browning
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
