Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
My craftsman 3/4 hp garage door closer will not work. When I pressed the button the lights blinked on and off, so I checked and changed the sensor. Still NG. There is power to the unit, as the light can be turned on and off; sensors lit and steady. What can I check next? Thanks
    President:
  • 3,197 Answers
If when the door starts down the main lights flash 10 times and the door reverses to the open position it is a door sensor problem. If this is not the case you can try increasing the 'down force' just a bit. This control is on the rear of the motor unit near where all those white wires go. If this doesn't do it you may have a bad RPM sensor. This is a small printed circuit board just in front of the motor.
Posted on Dec 30, 2010
I have a 1/2 hp craftsman opener. Remotes work fine. Wired wall unit has a blinking light on the open button and will not work Lock pad and light pad work but not the operate pad.????
Try pressing and holding the lock button for 3 seconds to stop the light from blinking. Your wall control may be bad. Usually when that light is blinking it is the remotes that will not work.
Jul 02, 2010 | Sears Craftsman LiftMaster Chamberlain...
For 1/2 HP belt drive opener: With the belt off, the motor sprocket only turns 1/8 - 1/4 turn each time the door opener button is pressed. Although nothing is obstructing the door or the sensors, the...
If the main light blinks 10 times when you try to close the door it is a door sensor problem. Make sure the small light on each sensor is lit and not blinking. Tweak them a bit if necessary.
Oct 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
We have a 3/4 hp Craftsman garage door opener that has stopped working. It opened fine, but will not close. The lights on the unit work but the Training Light is blinking.
If by training light you mean the LED next to the smart/learn button then this is normal if it is random blinking. Make sure your door sensors are properly aligned and pointing at one another. Each of them has a small light that should be lit and not blinking when they are aligned.
Jul 30, 2009 | Sears Craftsman LiftMaster Chamberlain...
Hi I have 1/3 hp liftmaster garage door opener that will not open from the remotes but will open with button on wall. I think it is a reciever problem?? any suggestions?/
reset your remotes and your main transmitter after removing and replacing the remote batteries (these use rolling codes that change each time you operate the door) the procedure for doing this is listed on the liftmaster website
Apr 30, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears craftsman 1/2 hp garage door troubleshooting
My garage door opener will start to close then stop and go back to the open position. If I put pressure on the door as it is closing sometimes it will close all the way and sometimes it will return to the open position. Can you help me. Thanks pbstation771@verizon.net
Aug 18, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
74 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
