Question about GE Refrigerators
I have a GE Monogram Side by Side Model ZIS480NRI Serial GM030316 that works fine except the freezer light does not come on. Tried bulbs and they were fine. When you push in the door switch the fan comes on in the freezer so that must work. Any ideas?? Thanks.. JM
peyton32034
  • 410 Answers
SOURCE: Whirlpool GD5RHAXNT00 Side By Side Refrigerator
your  problem on this is the main control in the compressor compartment. unplug your refrig then remove this control unplug all connectors and reconnect. this will probably get you working temporarily In almost every case I've seen we ended up replacing the control board. thx peyton
Posted on Feb 07, 2009
Greg20
  • 149 Answers
SOURCE: I have a side by side GE Monogram. When closing
the refrigerator should be leaning back enough to allow it to reclose. there are hieght adjusters behind the grill on front
Posted on Jun 12, 2009
  • 46 Answers
SOURCE: GE monogram ZIS420D. freezer reading 17degs and
to much stuff in the frezzer?
Posted on Jun 26, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Compressor of built-in monogram burning up. Should it be?
Don't know who to believe these days. When the compressor won't start and over heats the start relay,start capacitor and external overload may be the most likely reason. The door frames have heat strips that is normal. Sea Breeze
Posted on Jul 23, 2009
SOURCE: red door spring GE monogram fridge side door
Spring closure part # WR2X8916 from Sears Parts.
Posted on Aug 19, 2009
Serial #
What problem are you having? All you need is the model number.
Jul 05, 2013 | GE Monogram ZICS360NRRH C... Bottom...
GE Monogram 48" Freezer light works randomly
About the only way to determine what is causing the intermittent lighting to your freezer is to do a little electrical testing with a multi-meter. Also to press the door light switch in and wiggle it around may help you locate a bad door switch that simply can be replaced if the light decides to come on only when the door switch is pressed and released a certain way. Click here=> GE_Monogram_Refrigerator_Service_Manual Fresh Food and Freezer Light Diagnostics begin on page 46 of the PDF. I will be here if you have any questions but most of the physical testing will need be done from your end Testing the bulb sockets for firm connections and a good steady 12 volts output and 120 VAC input. If helpful please rate, Thanks, Sea Breeze
Feb 21, 2012 | GE Refrigerators
Have a GE Monogram Side-by-Side (Model ZIS42NCA), built-in. Reftigerator side will not cool below 58. Freezer side is fine. Condenser is clean. Is there a temp relay or the like out?
Check the vent inside the ref. section that its not blocked, usally next to impossible to do but should be checked, and then check the damper setting that direct the air flow off the evaporator back too normal settings.
Jun 26, 2011 | GE Monogram Side by Side Refrigerator
Need to find model # for ge monogram 42" side-by-side (1992?)
on the 42" Monograms the Model & serial nomenclature are usually located behind the top panel in the center section to the right of the compressor panel. Hope this helps....Bill
May 18, 2009 | GE Monogram Side by Side Refrigerator
GE Monogram Built-in Refrigerator Side keeps freezing
Sounds like a faulty thermostat. Try replacing it with a known good one and retest.
Apr 20, 2009 | GE Monogram ZISS480DRSS Stainless Steel
GE Monogram side by side freezer and refrigerator
HI thanks for your question. the problem could have been, a defrost timer, stuck on defrost. or a failing thermostat. keep a close eye on it, if it stops again. get in touch and we fix the problem. thanks
Jul 17, 2008 | GE Monogram ZISx420DR 42-inch Side by Side...
GE Monogram ziss480dmss Side-by-side refrigerator
no replace the door control bd or check for a loose or bad connection on the control bd also in an abstract sense one of the freezer door switches could be bad ones for the freezer light ones a safety for the door dispenser sys but that would be rare but possible
Mar 28, 2008 | GE Monogram ZISS420NRSS 42" Built-In...
Refrigerators Logo
65 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
