Question about Canon PIXMA MX310 All-In-One Printer
My pixma mx340 keeps saying load paper but i already inserted paper.
SOURCE: my canon pixma mx340 just
I had the same problem with my MX340. I called canon and it turns out that something have falling in the paper tray. tilt it to the back and stick your finger in there and try to move the rollers or shake and tap it a little till it falls out. I had a little nail in there. it's working find now.
Posted on Mar 08, 2011
F Victor man
  • 812 Answers
SOURCE: Canon PIXMA MX340 All-In-One InkJet
Open the cover so you can see the glass plates. Look up into the cover where the document exits from. There is a white flat bar with two small white tabs hanging down. Look at the tab that nearest to the front of the machine. In the slot to the left of it there should be a small black plastic arm hanging down. it is probably stuck in the up position. use a paper clip to bring it down and see if it is free to swing. DONT spray anything near it if it is stuck. Use tweezers to pull it down and it should click back into position and swing freely.
Good luck.
Posted on May 31, 2011
rulds2008
  • 3866 Answers
SOURCE: canon pixma 3100 keeps saying load paper and won't print
If you have paper in the loading tray and it keeps giving you out of paper message then the sensor by the loading hopper is not working and would need to be replaced.
9 times out of ten though you might want to clean the printer and make sure the hopper is not just jammed this happens when you put too much paper in there at one given time.
thanks
Posted on Sep 17, 2009
SOURCE: how come paper keeps getting stuck in printer and
You will have to remove every speck of paper that caused the jam in the first place. Look real closely and you will probably find paper lodged in remote places. Use a small flashlight and examine the printer
Posted on Jun 18, 2010
  • 126 Answers
SOURCE: paper is inserted properly but error message keeps
i think the printer has 2 trays, one down and the other one on top from where you insert the paper. load the paper there as well. if there is only one tray then check the paper sensor in the bottom, if the paper end sensor comes out of position then it will not detect the paper.
Posted on Jan 06, 2011
Which slot does the paper go in? Is there any online manuals?
Please read for PDF manual for Canon PIXMA MX340 Wireless Office AllinOne InkJet Printer.
Canon-MX340-Multifunction-Printers-manual
or Download Here
I hope usefull.
Jul 31, 2011 | Canon PIXMA MX340 Wireless Office...
My canon mx340 will not print from my laptop wireless....keeps saying offline
Is the Printer switched on? Do you have enough rights to use the printer wirelessly? Have you printed documents over your wireless connection previously?
Mar 15, 2011 | Canon PIXMA MX340 Wireless Office...
My printer keeps saying that there is a paper jam but I cannot find one
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Mar 08, 2011 | Canon PIXMA MX340 Wireless Office...
My canon pixma mx340 just keeps having paper jams and it pulls to one side then it says paper jam
Mar 07, 2011 | Canon PIXMA MX340 Wireless Office...
My Canon MX340 printer says there is a paper jam .... there is no paper jam. I've opened the cover, the scan cover and checked in the back. There is no paper jam. i've tried resetting the printer by...
I had the same problem...after trying everything suggested on the forum. I had enough and decided to disassemble the printer. I removed the CAD and disconnected the wires and it solved the problem. No more paper jam error code on the screen. This probably includes that the CAD won't work anymore but I never used this anyway. So now I can print and scan like I used to.
Nov 06, 2010 | Canon PIXMA MX340 Wireless Office...
Canon pixma mx340 4-in-1 wireless printer thinks it's jammed when it's not. say "error 6000". Assistance is greatly appreciated. thank you
error 6000 is a paper jam, which means there is something in the flag that senses whether or not there is paper in the path. Look very carefully in the area just before the paper comes out before the printing area. You will likely find a small piece of paper stuck, or a small object. Often a small inspection mirror helps.
Oct 31, 2010 | Canon PIXMA MX340 Wireless Office...
My printer says i have to put in new paper, but there is already plenty of paper in it!
Please make sure that you are loading paper onto the correct slot. You can load paper from the manual input or in the paper tray. Try putting paper on all trays and see if it works.
NOTE: Please rate our help to keep this free service online.
Jan 09, 2010 | Canon PIXMA iP1600 Printer
Will not recognize loaded paper, keeps saying no
There 's a torn piece of paper blocking the paper level sensor. Re check all areas where the paper feeds. the try re insert the paper, if its clear . turn printer off for 5 mins then turn on and try again
Jul 08, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Canon PIXMA MX310 All-In-One Printer Logo
209 people viewed this question
old marine
old marine
