Question about Ovens
Had to repair loose handle on oven door for model GLP84800 and I need an illustration of how to get door back together with all its parts in right place.
SOURCE: Loose Oven door handle
can get spares from
Tel. 01628 620081 Fax 01628 776345 - Spares Email is spares@a1tech.co.uk
Posted on Apr 14, 2008
SOURCE: loose oven door handle
I had the same problem. We took the door off completely & turned it upside down. There are screws on the bottom of the door, take them out, take off bottom trim piece that holds the outside glass panel in place, remove glass panel and you can access the door handle screws and clean the inside of the glass while you are at it.
Posted on Feb 17, 2009
mastatech
  • 478 Answers
SOURCE: Neff Oven handle loose
The door can be seperated by screw on the side of the door, Put lock washers to insure futer tightness.
Posted on Mar 12, 2009
Maytag317
  • 1136 Answers
SOURCE: oven door handle is loose. Don't know how to get to it.
Hi, Get me a model# and I can look this up for you.
Thanks
Vic
Posted on May 16, 2009
paul4265
  • 592 Answers
SOURCE: The handle is loose on my kitchenaide superba oven
The glass portion of the oven dorr is not only attached by the screws, but there is a procedure to remove the door from the stove as well.
1: Open the door all the way.
2: On the hinges is a flip latch, flip them both up.
3: Close the oven door as far as it will shut, leaving the latches flipped up.
4: Lift up on the oven door evenly and squarely, lifting up and off hinges.
{note}...DOOR WILL BE AWKWARD AND HEAVY!
5: Place on flat surface, and under the bottom of door should be retaining screws for the door skin, so as to allow for removal of it as well. This should give you access to the handle so that you may tighten it.
Then go in reverse order to put door back on, making sure to flip hinge latches back down after re-insertion of door onto hinge pins, as the door will not shut without them being flipped down.
Posted on Jan 20, 2011
Oven door handle one side not attached to door other side loose
look around the outer edge of the door a few screws hold the 2 halves together caution do it on a flat surface as the glass can fall out .
Sep 01, 2016 | Neff Ovens
Need to remove the door, but my hinge doesn't look like the illustration in the manual
Open door alittle push down and pull out and up to remove door.. You may have to wiggle it a bit.
Hopes this helps Mike
May 23, 2015 | Thermador Ovens
Remove door
I recommend calling either the manufacturer or the place you bought it from. Quite likely need a new door.
Jan 29, 2014 | Candy FP855 Electric Single Oven
Took apart glass oven door on a whirlpool. Where
Hello, bd_lft_up.gif bd_top_bg.gif bd_rt_top.gif bd_lft_bg.gif OVEN DOOR bd_rt_bg.gif bd_wpl_oven_door1.gif bd_wpl_oven_door2.gif clear.gif bd_lft_btm.gif bd_btm_bg.gif bd_rt_btm.gif Oven Door
#1 -- Oven door liner
#2 -- Oven inner glass
#3 -- Oven door hinge
#4 -- Retainer, glass
#5 -- Bracket, handle
#6 -- Door glass seal, top
#7 -- Door glass seal, side
#8 -- Oven outer door glass
#9 -- Door handle
#10
Read more: http://www.appliancepartspros.com/bd_whirpool_oven_parts.aspx#ixzz0pj5Z78oi
http://www.appliancepartspros.com .
Hope this helps.
Thanks
May 30, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Oven door handle is loose
Remove the screws holding the door together to access the handle screws
Oct 02, 2009 | Whirlpool Ovens
Oven cleaning
1) take oven door off (position door fully open, flip forward the 2 jammer levers on the hinges, raise door 1/2 open until hinge springs are relieved by jammers, gently ease out door)
2) at the bottom of the door there are 3 screws on left and 3 on right. Remove the innermost screw on left and innermost on right.
3) ease open the glass front by pivoting on the top of the door, separating the bottom that you have just released by removing the 2 screws.
Written by a Chartered Accountant who has current first hand experience of the FEA0614 door
Apr 11, 2009 | Jenn-Air JJW8230D Electric Double Oven
Mar 12, 2009 | Ovens
Loose oven door handle on kitchenaid gas range
youl have to take apart the door.the screws are on the other side of the glass/framing
Dec 31, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Whirlpool oven door
The metal bars go under the top door handle part, put them under the part you need to screw back in.
Sep 15, 2008 | Whirlpool RBS245PDS Electric Single Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
