Question about Panasonic PT-53WX54 53" Rear Projection HDTV
Keeps turning off and red light is blinking 3 time
  • 10,594 Answers
If it is Panasonic PT-53WX54 rear projection tv then 3 times red light blinking indicates problem of convergence output chips failure in tv that need to be replaced to solve its problem.
Let me know if you are handy with electronics stuff repair and can replace/ solder parts in circuit board to provide you more helpful info OR call local tv repairman to replace convergence output chips tin tv.
Thanks.
Posted on Dec 30, 2010
When I turn on the tv it beeps 4 times then the power button light will flash 3 times in a row but the power will not come on it just keeps flashing 3 times
power will not come on Linda, could be bad capacitors or cracked/bad solder joint,bad main logic board.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Samsung TV won turn on blinking red light explained fix 18
Sony Bravia TV kdl red blinking led light error codes solutions
Apr 02, 2016 | Televison & Video
Red light flashing, tv wont turn on
need the model number of the panasonic and also how many times it is blinking. The blinking is an error code.
Aug 03, 2012 | Panasonic Televison & Video
Tv light standby red just keeps blinking after replacing bulb
If red light was not blinking before lamp replacement and after that it start blinking 3 times then pause for three seconds and again blink, check lamp cover that has not been fixed on tv or it is not fixed/ seated correctly there.
Lamp cover is first thing that you removed from tv to replace lamp.
Hope these info will help. If red light is blinking other than 3 times, let me know how many times it is blinking along with tv model number written at rear to provide you helpful info.
Thanks.
Jan 27, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
Just replaced the bulb with a brand new sony bulb. it takes me almost 20 minutes to get the tv to turn on..i turn it on it turns itself off and red light blinks, and i keep trying until it finally powers...
If red light blinks 3 times when tv refuse to power up then check lamp cover that was removed to replace lamp, make sure lamp cover is fixed in its position securely and screw is tight.
Let me know how many times red light is blinking after three second long pause IF it is not blinking 3 times.
Thanks.
Dec 30, 2010 | Sony KDF-50E2000 50" HDTV
Power light keeps blinking Red and TV will not turn on
Is the light blinking constantly or is there a long pause then more blinking. If constant check the lamp door switch . Usually it is broken or jammed. If you jumper it and the set comes on that it. 4 blinks is bad fan.
Mar 24, 2010 | Sony Grand WEGA KF-42SX300 42" LCD TV
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
6 red blinking lights
You have a bad thermal fuse.
Oct 23, 2009 | Televison & Video
Screen went dark
Ur video ic inverter board is dead.
U need a new one.
Aug 25, 2009 | Televison & Video
TV doesnot Turn ON
sounds like you need a new light bulb
May 08, 2008 | Sony XL-2100U Projector Lamp for...
Panasonic PT-53WX54 53" Rear Projection HDTV Logo
108 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
