Question about Kodak EasyShare Z650 Digital Camera
Picture dock Our picture dock for printing out our pics. Is cutting off the top of the picture. please advise. Thanks
    Genius:
  • 2,985 Answers
Go to Start/Control Panel/ Add remove software.
Remove the Kodak Easy share software.
Do not re install it.
Use USB cable to connect camera to computer
Use alternative software [picasa which is Free] or any other image editor for processing and printing images.
It is likely your printer has supplied software that is suitable.
Posted on Jul 08, 2008
I took pictures day with my 94 year old grandmother at church. When I got home the screen is white with a black line throught it. I can not see anything. Those pictures are priceless. I am extremely...
Take the card to a Walmart and insert it into one of their picture making machines. Print the pics and make a cd of them. Then, you can start worrying about your camera. Get back to us when you've printed the pics.
Mar 14, 2011 | Kodak EasyShare C613 Digital Camera
When i print my pictures the top portion of the photo is cut off. The snapshot shows up normally on the camera screen, but when the photos are developed the top portion is cut off.
This problem is related to the memory card which you are using in your camera,which has corrupted. Change the memory card and your pics will be fine.
Thanks for using fixya.
Nov 05, 2009 | Casio EXILIM Card EX-S770 Digital Camera
We have a Kodak easyshare series 3 camera and dock and when printing it only prints the lower half of the picture.
SOLVED!!
eppelr is correct, the small white cam on the right hand side at the top (internally) cracks and this allows it to come loose on its shaft and stops it from pressing the thermal head down onto the ink film on one side. If like me you have the top of the range bluetooth model its worth buying an old basic model off ebay for a tenner and robbing the shaft out of that. The mechanics are more or less the same and the shaft itself is identical, Doubt you would be able to buy the shaft seperate from Kodak, Thanks eppelr, I now have two working plus 3's.
If anyone wants pics etc please get in touch
Aug 30, 2009 | Kodak EASYSHARE Printer Dock Thermal Photo
The picture r coming out with half orange faded look..I have changed thr cartridge
If this is the usual 'only prints half of picture' problem then..
SOLVED!!
Aug 09, 2009 | Kodak EASYSHARE Printer Dock Thermal Photo
Cx7430 printer dock does not print a full pic., top is not printed
Hi,Try the following sites to short out your problem…..
http://uw713doc.sco.com/en/PR_admin/prntT.NoPrint.html
http://files.support.epson.com/htmldocs/pho22_/pho22_rf/trble_5.htm
http://www.smartcomputing.com/editorial/article.asp?article=articles/archive/r1101/04r01/04r01.asp&guid=
Thanks
Nov 24, 2008 | Kodak EasyShare CX7430 & EasyShare Printer...
I AM TRYING TO TRANSFER PICS FROM CAMERA THRU EASYSHARE PRINTER DOCK,TO PC,SO I CAN EDIT AND PRINT PICS,TRYING TO FIND THE SIMPLEST WAY BUT NO SUCCESS,PLSE HELP THANKS
Remove software installed.
Do not use the Dock
Connect camera directly USB to USB
Let the computer do the rest
Still in trouble by an externnal USB card reader
Jul 21, 2008 | Cameras
Kodak EasyShare Printer Dock Series 3
If the boundary between the blank half and the printed half is a sharp line, a wire to the print head may be broken or disconnected. If the boundary is irregular (wanders up and down an 1/8 inch or so), the problem is most likely a broken plastic lever on the end of the shaft that moves the print head. The plastic lever is keyed to the shaft by a flat on the shaft. The plastic has a tendency to split at the edge of the flat, resulting in the lever slipping on the shaft. This in turn results in one side of the print head not contacting the paper with sufficient pressure. The other end of the shaft has a thick plastic sector gear which is much less likely to break.
I fixed mine by making a clamp from a metal spacer (made from split tube about 1/8 inch long) and force fitting it over the part of the plastic lever that fits on the metal shaft (on the end towards the inside of the unit). There is just enough clearance to do this without hitting the print head frame.
To remove the plastic lever, first remove two screws from back of unit, then pull up on top of unit, unplug two ribbon cables from circuit board and remove top. Then unplug two remaining ribbon cables from circuit board, and three screws holding circuit board. Lift circuit board and fan/fan-holder as one piece. Finally, disengage tab on plastic retainer on end of metal shaft, rotate tab straight up and lift shaft up and to the side (may require a little wiggling). The plastic lever slides off the metal shaft.
Jun 27, 2008 | Kodak EASYSHARE CD33 & Printer Dock Series...
Bottom half of picture is printing
I had the same problem. There is a rod that on one end has a plastic gear and cam mechanism, and on the other end is a plastic cam. This rod rotates and pushes the print head against the paper. On my unit the plastic cam (not the one with the gear) split and was not putting pressure on the head on what would be the top half of the picture. I determined the proper position for the cam and super glued it in place. Now it is working like new.
Jun 19, 2008 | Kodak Dock Series 3 Laser Photo Printer
Cutting off part of the picture
check that the pic is not too big for the print mem if so try changing the port settings to spool or print direct
Mar 30, 2008 | HP Photosmart 3210 Printer
Cant charge camera on dock or print photos
the dock won't charge batteries that are ni-mh kaa2hr or Li-ion battery pack - so check that
about the printer's ability to recognize the cam, try this.. remove batt, put cam on top of dock (when cameras are on a dock, they can use the dock's power so you can print pictures without batteries) check if somethign will come up on the cam screen
if not .. either would need to be sent in for repair. a digital rep will advise you to send both so the repair center can check
Mar 09, 2007 | Kodak EasyShare CX7525 Digital Camera
Kodak EasyShare Z650 Digital Camera Logo
69 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
