Question about Kenmore 62622 Microwave Oven
I have a 721.62629200 Kenmore microwave that the exhaust fan will cut on periodically while using the range stove top.The only way to stop the fan is to pull the power plug.Steam seams to cause it to come on but the control buttons will not turn it off. Just the exhaust fan comes on.A friend suggested that the "thermistor" might be bad but I could not find such a part in the breakdown diagram at SEARS. Thanks for any help
SOURCE: kenmore over the range microwave oven
hi how r u
i want to know what's the average power that i should put it on my microwave
thank u
Posted on Apr 21, 2008
SOURCE: Kemore Microwave Hood Combination
I HAVE KENMORE 665/61629 LIGHT STAYS ON. AND DO NOT COOKS. AND THE FAN DOES NOT WORK.
Posted on Jan 19, 2009
jmgldsmth
  • 1906 Answers
SOURCE: Kenmore over the range microwave 721.63684300 - nothing works
you must remove the MW take off the cover then look for a large metal can (capacitor) and a white (ceramic) fuse...look and, smell and, you should find the cause
Posted on Apr 22, 2009
erpaalai
  • 999 Answers
SOURCE: Kenmore Microwave Oven model #401.80082700
Sounds like a bearing is tightening up when it get heated up with use. Then after a cool down period it works normally until using it heats it up again. Eric
Posted on Sep 15, 2009
MicrowaveSvc
  • 9086 Answers
SOURCE: I have a Kenmore Microwave hood combo model number
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Posted on May 16, 2010
No suction on my microwave
Over-the-range microwaves have lights and fans in them mostly for show. They protect the microwave from heat rising from the stove and provide a light to illuminate the stove top. The fan assembly is far too small to generate any real pull or draft and if it did, it would only blow it back in your face since these models do not exhaust to the outside; they only exhaust out the front of the microwave. A few models have a "filter screen" that is supposedly there to catch grease and contaminates but really it only serves to further weaken the draft as it provides a resistance to air flow.
Oct 14, 2016 | Samsung 1.8 Cu. Ft. Over-the-Range...
Kenmore Elite Microwave Hood Combination fan blows air out of the top but is not sucking in the heat from anything on the stove...for example boiling water.
does th fan exhaust to the outside --filter clean --directional duct to out side --also small unit so will not suck air like a standard stand alone exhaust fan which are over 3 to 4x the size
Jul 31, 2016 | Kenmore Microwave Ovens
The vent will turn on randomly and not turn off!
Most over the range microwaves have a heat safety system built into them. If for instance you are cooking on the stove top for a long period of time on the burner directly under the micro control panel and the control panel get too hot, a thermostat in the microwave will automatically turn on the vent fan to help keep the control panel cooled off. My guess is that the safety thermostat (usually right behind the bottom of the control panel) may be going bad and needs replaced.
Apr 03, 2015 | Kenmore 30" Microwave Combination...
Kenmore elite microwave
Was it just the exhaust fan that came on? If so this is normal when cooking on the stove for long period of time without the fan running. The heat builds up under the microwave and eventually activates the fan.
Sep 05, 2014 | Microwave Ovens
Have Kenmore microvave and the vent starts on its own
Actually, that's a feature! If you cook much on the range (stove) beneath the microwave, the heat will cause the microwave bottom to heat up quite a bit (just touch it!), and the microwave will turn on it's exhaust fan in an attempt to save itself from burning up. It will shut off in about 15 minutes after you turn off the source of heat.
But if the fan comes on by itself even when the microwave is cool (or at least not hot), then you probably have a defective fan thermostat. This thermostat is located behind the control console on the inside bottom of the microwave.
Aug 27, 2014 | Kenmore Microwave Ovens
I have a Kenmore microwave. The vent will just start on its own and can't shut off
My fan for the stove reduces power once the microwave is turned on
you must understand that any manufacturer has the proper design engineering from to save electricity, etc. And they using the new concept of reingeenering.
If the microwaves do not HEAT and working, do not worry.
Mar 06, 2013 | Microwave Ovens
Sep 15, 2009 | Kenmore 62622 Microwave Oven
Samsung MU3250W Shut down
It could have been steam or humidity.
If this is an over the range model, be sure you always use the hood vent exhaust fan when you're cooking on the stove top.
Whether it's a counter top or over the range top, always be aware that the cooling fan is running when it's cooking.
When in doubt feel for air flow through the vents.
Good luck.
Oct 19, 2008 | Samsung MU3250W Microwave Oven
Kenmore microhood
"Microhood" seems to be a slang term for the "microwave hood" (hood fan or exhaust fan) which is normally part of an over-the-range microwave oven or range. But these should be available separately, as I seem to recall. I would contact home centers such as Lowe's, Home Depot (if they still exist), etc., or a local appliance store.
Dec 06, 2006 | Kenmore 62622 Microwave Oven
Kenmore 62622 Microwave Oven Logo
67 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
