Question about Home
I need a pipe diagram for a six seater jacuzzi(make: Summer Place)
Installed a jacuzzi tankless water heater when I turned it on it beeps and has an 11 in the display what does this mean and how do I fix it
The error 11 indicates that the burner did not ignite the incoming gas properly. Make sure that the gas valve is open (at the water heater and the meter/tank, depending on the type of gas). If you have propane, check that the tank isn't empty. Make sure that the water heater is properly grounded.
The other causes for the error may require a professional to check them out. Check that the water heater is compatible with your incoming gas. (Propane burners do not work with natural gas and the reverse is true, as well.) Check that the gas pressure available is high enough for the unit. (Tankless water heaters often need larger diameter pipes to bring in the gas than their tanked predecessors.) Check that there is no air in your gas lines. Make sure that the condensation collar was correctly installed on the water heater and that the vent pipe isn't too long. There are some DIP switches that need to be set depending on the installation; make sure that all of these are in the correct positions. Next the burner, the igniter and the solenoid gas valve need to be checked. The wiring for the igniter and the valve need to be checked. The burner cover has to be removed to check if the burners are properly seated. The burner plate has to be removed so that the burner surface can be checked for debris or condensation. The igniter has to be checked to see if it is operational. Finally, the solenoid valve needs to be checked for a short or an open circuit.
I hope this helps.
(I've also had to check the end of the vent pipes for blockages - animal nests in the summer or ice in the winter.)
Jun 20, 2015 | Jacuzzi 7.5 GPM 180000 BTU Internal Gas...
Grounding wire# 8 cooper
The # 8 wire is a bonding wire for the hot tub or jacuzzi. It is to interconnect all the metal parts and equipment associated with the unit, pump, pipes, handrails, and also now there is a bushing that goes in the piping run to bond the water itself .
This wire will be incdentally connected to the electrical ground when it is bonded to the motor body.
Jun 10, 2010 | Jacuzzi RapidHeat Inline Heater S750
How do i install an jacuzzi that has no faucet its a bathroom jacuzzi has no place for faucet it just has a hole for drain handle
either mount on wall or need to drill holes through jacuzzi 99 % of tubs dont come with faucets
Apr 24, 2010 | Jacuzzi Home
I'm llooking for vacuum diagrams for G10a carby
one pipe to the serve and a smaller pipe to the dist advance unit.another to the air filter winter/summer setting control
Oct 24, 2009 | 1993 Suzuki Swift
My jacuzzi pool pump cracked so I need to replace it. Jacuzzi is no longer making parts, so what would be a good brand where I could still use the same pipes, filter, etc.?
here's a site where I found tons of jacuzzi parts and accessories.
http://calwesthot1.reachlocal.net/AdvancedSearch.aspx
under select catagory scroll about half way down to jacuzzi pumps and hit search.
If you find what you need can I borrow the jacuzzi .. lol
Jul 31, 2009 | Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM...
Why do I have air in my system after manual vacuuming?
you need to get all air out of 'vac' pipe before starting to 'vac'.
Best way is to start with 'vac' end - place in pool and push to bottom - let rest of hose follow - keeping hose under water (as much as possible )
** sorry if you are doing this all-ready.
Jul 03, 2009 | Jacuzzi Pool & Spa
Wiring diagram and user-owner manual, fraser nash
need wiring diagram
ultra multi mode meter plus
Apr 17, 2009 | Electronics - Others
Jacuzzi leaking
The best way is to cut the pipe out and repipe. I'm guessing that the pipe on this is a ridgid schedule 40 PVC. On the new units, they don't use ridged pipe much anymore. If you do decide to cut out the pipe and replace it, it is possible you might have to replace one of the jets depending on how they are mounted to the pipe. Make sure you use primer and a glue that is made to use on wet pipes. You can get it at the hardware store and it's blue. It's the type that you can use on sprinkler systems. You can try the epoxy but you need to make sure that the joint is dry and clean before applying it. Like I said, the best way is to cut out the old and replace with new.
Mar 21, 2009 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
Diagram for jacuzzi installation?
Go to jacuzzi.com and you will find all of the installation info you will need. good luck.
Dec 22, 2008 | Home
Home Logo
55 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
