Question about Hotpoint Dryers
Hi My hotpoint dryer will tumble but no heat is generated the air outlet is clean and free from obstruction can you help me
  • Hotpoint Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Dec 31, 2010
Hotpoint Aquarius tvm560 tumble dryer is blowing cold Air can it be fixed
sure it can., check ur heating element, with multimeter, and check ur thermostats the hi-lo the thermal cut off , cycling thermostat, etc.
Jan 28, 2015 | Hotpoint Dryers
Hotpoint TCL 780G condensor tumble dryer
hi make sure heater element is not touching back of dryer causing a short or break on wire catching casing
Mar 05, 2014 | Hotpoint Dryers
Hoptoint CDT40G condenser tumble dryer pump running no heat or movement
hi i have a ctd40 mine wouldent go a few years ago on the heater i had three stats on one of them there is a tiny hole i pushed a sewing needle in hole it reset the stat you can see if you look at bottom of stat it might be concave so pushing it out set it again dryer then worked pull plug first
Apr 29, 2013 | Hotpoint Dryers
Hotpoint dryer model DLL2650BFLWH not heating
If this is an electric dryer, your heating coil has broken and is no longer conducting current and heating.
Oct 27, 2012 | Hotpoint TDL15 Electric Dryer
I have a hotpoint aquarius condenser tumble dryer
This sounds like the thermostats or heater
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
Nov 06, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint ctd00G will not heat up
This is most likely the thermostat switch or possibly the heating element itself.
One or the other is likely needing replacement.
If you are competent at electrical repairs, and have a test meter; Unplug and move to allow access.
Undo rear top screws and remove lid.
Heating element is usualy on top. Disconnect leads and check continuity of switches and element.
Replace switches with similar if either are open circuit. Available as spares from online parts centres.
Heating element should read in the low Ohms - around 20 - 35 Ohms if Ok, otherwise replace.
ONLY ATTEMPT REPAIRS IF COMPETENT (I have to say that)
Sep 23, 2009 | Dryers
Just hooked up outlet. Dryer tumbles, wont heat. Have I wired the outlet wrong?
Hi, Did you put red and black wire to the outer posts? White wire ti center and green to ground screw on cabinet? Dry will run on 120V but needs 240V for heat. Make sure there is 240V to the outlet as well.
Hope this helps. If so, please feel free to rate my answer so that I know how I am doing.
Vic
May 10, 2009 | Dryers
Tumble dryer not heating/drying
To check the element and stats, you need to remove the rear panel of the dryer, there you will see the stats and the element, you need to check for contin uity with a meter set on the ohms range, do it with the stats disconnected, or you will get a false reading.. if one of the stats has gone, then you must replace both of them.
Check thst all filters are clean ,air intake and outlet clear, and wash the lower fluff filter out under a running water supply.
If still no joy ,then could be a control unit prob..
Plz rate my solution
Thanks.
Dec 29, 2008 | Hotpoint Aquarius WD640 Front Load...
Dryers Logo
60 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
Chris Hall
Chris Hall
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
