Question about Onkyo TX-SR608 Receiver
Connect dell xps 720 h2c to onkyo txsr 606 i want audio and video.
  • Onkyo Master
  • 736 Answers
If you don't already have one (and I don't have any way of knowing whether or not you do because it isn't mentioned in this problem description) you would need to get an hdmi to dvi cable. It does not carry sound. If you have the adaptor piece that you attach to the end of an hdmi cable that doesn't always work as well for whatever reason.
However now that I am looking at the rear of you Onkyo I don't see that either of the hdmi inputs on it have a corresponding audio input to accommodate hdmi to dvi situations such as these. I was going to recommend connecting a 3.5 mm minijack cable between the computer and the Onkyo or rather a cable that has one 3.5 minijack end and a red and white RCA audio cable on the other end. The only problem I forsee with doing so is that when you select the function/input on the Onkyo you wll not be able to choose one for both picture and sound when connecting with you Dell. Unfortunately it appears that the Dell will have to be connected directly to a television.
Posted on Dec 30, 2010
Can I conect an Onkyo M-501 power amp to an Onkyo A/V TS xr601 receiver?
HI,
You will not be able to connect the M501 To the TXSR 601 AVR because the AVR does not have any pre out puts except subout.
Ajin
Feb 27, 2012 | Audio Players & Recorders
How do I program hdmi imputs on a txsr 506
You don't program hdmi. The manual describes all that stuff and the unnamed product at the other end of the cable plays a part, too.
http://www.retrevo.com/support/Onkyo-TX-SR506-Receivers-manual/id/13748ci477/t/2/
Sep 06, 2011 | Onkyo Audio Players & Recorders
I have my television, cable box, and apple tv running into the tuner with HDMI cables with the tuner hooked up to surround speakers for the sound. I'm having trouble separating the audio and video. I would...
The only way you can do this is by connecting the Cable Set Top box HDMI directly to the TV HDMI input and switching the TXSR508 to Apple TV. And if you want to hear the Cable sound through the TXSR, connect analogue audio out of the TV to one of the analogue inputs of the TXSR ( Aux or Video In ). You may not get the Cable TV's Dolby 5.1 sound but you will get stereo sound which on using the TXSR's dsp setting ( ProLogic II ) can be made into 5.1.
May 04, 2011 | Onkyo TXSR508 Receiver
How to connect a turntable to Onkyo txsr 500
Just like most contemporary AV Receivers, there is no built-in Phono preamp in this unit so if your TT doesn't have one internally, you'll need to get an aftermarket Phono Preamp somewhere to PREamplify and frequency-balance the minute Phono Cartridge output to a useable Line Level you can send to any available Line Level input on the Receiver (CD, Aux, whatever) .
Feb 06, 2010 | Onkyo TX-SR500 Receiver
Onkyo 606 Video Drop out
main board fault, its input feed on the board might be failing, it could also be a failing capacitor, you would need to open it up to have a look and see if there are any capacitors failing.
May 14, 2017 | Onkyo TX-SR606 Receiver
No audio sound from HDMI connection from TV to Onkyo 606 amp.
you have the output of the receiver going to the input of the TV?
i believe that you should be running the TV output to the receiver input to get your sound from the TV to the receiver and thus speakers.
the easiest setup is to just run your cable box and DVD player HDMI's into your TV inputs. then run another HDMI from the TV output to the receiver input.
Feb 28, 2009 | Onkyo TX-SR606 Receiver
Intel M750 ex.4
plz tell me wat you want to knw abt this you want download or update this
Feb 20, 2009 | Dell XPS 730 H2C Desktop Computer
Getting very low download speed ?
check for virus in your computer.
try using the opitmize software for your computer
you can try asuslogic software
Dec 26, 2008 | Dell XPS 730 H2C Desktop Computer
Onkyo TX-SR 606 KEEPS CLICKING INSTEAD OF TURNING ON WHEN POWERED
Here are your options:
1. An electrical problem, where your receiver has a grounding problem.
2. Your speaker wire connections are actually touching each other and that's why your receiver is not turning on.
Nov 09, 2008 | Onkyo TX-SR605 Receiver
Ps3 defaults to 576p when connected through onkyo 606 receiver
You have to tell the PS3 what the Okyo can do and it probably cannot do 1080P 60Hz (but can likely do 1080P 24Hz).  Try ticking more resolutions in the PS3s setup
Jun 22, 2008 | Audio Players & Recorders
Onkyo TX-SR608 Receiver Logo
66 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
