Question about Frigidaire Dryers
I have a Frigidaire Gallery large capacity dryer (model # FSE747GESO) that has a very annoying high pitched squeal / squeeking noise. I checked the belts and the condition is like new. I am looking for the source of the problem which a service tech said is located in the back of my dryer and comes in a kit for approx. $15- $20. They will not come service it because the product was not purchased from them. Also, where do I find a diagram to find out the how to's when replacing this part? Thank you very much for any help you may have to give. Mother of 6 daughters.
    Top Expert:
  • Frigidaire Master
  • 45,120 Answers
Go to www.repairclinic.com and enter FSE747GESO. You will be presented with a list of common replacement parts and may be able to view a generic Frigidaire video showing disassembly and parts replacement.
Posted on Apr 24, 2017
SOURCE: Frigidaire Gallery Heavy Duty Front Load Dryer problem
it's probably the nylon bushings that the drum rides on. they wear out and the drum rides directly on the pad that the bushings attach to.
Posted on Sep 02, 2008
TheMobilian
  • 8220 Answers
SOURCE: Frigidaire Gallery dryer SMELLED like Burning rubber.
Reach inside and try to turn the drum. If it seems hard to turn then your glide kit (Part#5303937139) may be in need of replacement:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Apr 10, 2009
  • 864 Answers
SOURCE: Squeeks loadly when running
The drum belt is slipping or a support wheel bearing is worn.  Spray some belt dressing on the belt or replace the belt.  Lubricate the wheel bearing or replace it.  It is also possible that the seal between the drum and the housing (at the back) is worn and the drum is rubbing metal-to-metal on the housing.
Posted on May 29, 2009
hunter19_46m
  • 7482 Answers
SOURCE: Dryer making a high pitched squeek, I took apart
I normally don't work on gas dryers but it sounds like the drum rollers are in need of lubrication. Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps Please rate me, Thank You
Posted on Dec 27, 2009
lscf150
  • 443 Answers
SOURCE: dryer problem
Your dryer drum front support glides and rear drum bearing needs to be replaced, parts are not expensive but labor to do the job may be $50 to $100 dollars.
You should call Frigidaire customer help line just to gather some info from them. 1-800-FRIGIDAIRE
Good luck !
Posted on Jan 05, 2010
The dryer has a loud, high pitched squeek
Hello Robin, thank you for your post!
From the information you have provided your Frigidaire dryer is making a loud high pitched squeaking noise. This noise could be coming from your belt, motor, or spider arm. In order to find out which component might need to be replaced you would need to disassemble the dryer. We would recommend having a professional technician out to perform a proper repair. Improper disassembly of the dryer could result in personal injury or a problem with the dryer later in its life cycle. I hope that this information is helpful to you. -Matt
Feb 07, 2016 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Dryer was making high pitched squealing noise and now won't run
Please supply the model number so we can help further.
May 20, 2012 | Hotpoint Dryers
Front wheel noise
The first thing I would do is inspect the brakes. The brake pads have a metal indicator that will start to rub when the pads get low. It will make a really annoying high pitch squeal. It could also be a condition known as metallic squeal. This would be a metallic particle in the brake pad that is causing the noise. Replacing the pads is a guaranteed fix for this. It could also be a backing plate rubbing or any number of things. Checking the brakes would be a good first step. Let me know if you have any questions and I'll do my best to answer them. Thank you for using FixYa.com!
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Feb 02, 2012 | 2006 Saturn Vue
My dryer squeels a high pitch sound until it heats up. it does ok till it starts cooling down then it squeels again. Is it the drum bearings and how hard are they to replace? It is a frigidaire Gallery...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Aug 19, 2010 | Frigidaire Dryers
Dryer problem
Good luck !
Jan 05, 2010 | Dryers
Apr 10, 2009 | Dryers
Dryer makes loud squeaking noise when spinning
there are two possibilities for this question. 1) there is an idler roller that give the belt the correct tension . unplug dryer and remove idler roller see if it spins freely if not replace it @0 there are two drum rollers in back of machine thatdrum rides on remove drum it's self explanitory how to remove drum and very easy also. you can roll these wheels and check for free movement visually check them ,one or both should be worn out or the bearing in the wheel has failed before putting old or new wheels back sand the wheel shafts to get any gunk off them and that's about the only thing that can make a dryer squeek
Jan 25, 2009 | GE 5.8 Cu. Ft. Extra-Large Capacity...
Squeeky noise
I own a Frigidaire Heavy Duty Dryer The Model # is FDE436RES1. It is 10 years old. When running the dryer it makes a very loud squealing noise although the heat and the dryer still work. Is this a belt or roller problem or does it sound like something else. It is very high pitched and can be heard throughout the entire home. I do not know much about dryer troubleshooting so your help would be greatly appreciated. Thank You.
Oct 17, 2007 | Frigidaire GLER642A Electric Dryer
Dryers Logo
83 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
