Question about Spectra Cameras
Spectra model dpf-105 windows software? - Spectra Cameras
Ford c max goes in limpmode dpf blocked fitted dpf egr and dpf presser sensor sill goes in limpmode
Requires fault codes to be reset, this will require a code.reader with your models software.
Jul 05, 2016 | 2007 Ford C-MAX 1.6
I NEED THE FACTORY SOFTWARE DISK FOR MY SPECTRA DPF-105 DIGITAL PHOTO FRAME
Please have model number ready for their Customer Service, call 1-800-777-5331
Their address is also listed in the Spectra DPF-105 online manual. Hope this helps. http://www.manualslib.com/manual/665713/Spectra-Dpf-105.html?page=9#manual
Nov 12, 2015 | Spectra DPF-105 Digital Photo Frame...
Have a 2008 f450 and the exhaust system was just cleaned it still has no power and will not go over 25 mph it said to drive to clean dpf
To clean the DPF, the vehicle needs to be driven at 50-60 mph for an uninterrupted minimum time of 15 minutes. (Motorway?). If it won't go over 25mph that's a problem. You need a garage that has computer software, that can put the vehicle into forced regeneration. Other option is to have the DPF removed and the ECU reprogrammed, but there is a question about the legality of doing that.
Jan 02, 2014 | 2008 Ford F 450 Super Duty
My DPFMate is showing a blank screen
you must flashing that because the system software is error
Dec 27, 2013 | Spectra DPF-105 Digital Photo Frame...
I have a DPF light that despite following the Suzuki guideliness to drive at certain speed for a certain amount of time, this light has not cleared. I have already had a sensor in the exhaust replaced that...
A diesel particulate filter (DPF) collects particulates in the engine's exhaust, basically unburned fuel. Every so often the DPF will need to regenerate. What this means is when a certain amount of particulates accumulate in the DPF, a small amount of raw fuel is injected into the DPF to increase the temperature. The increased heat burns the particulates resulting in fewer nasty things going into the atmosphere. However, the regeneration process leaves a small amount of ash in the DPF which accumulates over time. You may have to have the DPF professionally cleaned (it's not a DIY thing) in order to restore its performance.
Mar 19, 2011 | Suzuki Grand Vitara Cars & Trucks
Westinghouse dpf 1411 shuts off after 2 minutes, wont stay on
Check your settings, maybe you have an auto-off feature turned on. If this is not the case, seek professional help, it's probably a software problem.
Apr 07, 2010 | Westinghouse DPF-1411 Digital Picture...
Are there catalytic converters fitted on 406 2.0l
Its a dpf not a cat.Easy way to clean out[regenerate]First bring the engine to normal temp bring up the rpm to 4000 for 2 mins,then allow to idle for 30 seconds then bring the rpm up to 3000 rpm for 3 mins and yourfilter will have regenerated [fancy word for clean itself out. DPF = diesel particulate filter.Its important to use good quality low ash oil for your oil changes.
Mar 03, 2010 | 2005 Peugeot 405
Cant open dpf and print
i hope you meant pdf in that case
please download and install a pdf reader,
open the pdf file using this software and print it.
to download pdf reader click on this link
for windows xp users
download
for other operating systems like vista
download
Hope this helps you
Thank you
Sep 27, 2009 | Computers & Internet
CDRom you are downloading to is read only
There are many other softwares you can use. try ACDsee
Aug 18, 2009 | Sakar DIGITAL CONCEPTS VC-16 Motorized...
Cameras Logo
213 people viewed this question
Top Spectra Cameras Experts
Are you a Spectra Camera Expert? Answer questions, earn points and help others
