Question about Samsung HT-DS610 System
1. I have samsung tv model T26OHD I need to know whare i place leads in to tv with play station 2 device? I have tried and only black and white colour is shown. I have volume 2. Same model switches on intermittently during the night with volume only? - Why?
The Machine
  • 788 Answers
SOURCE: SAMSUNG
So you want to connect your red and white cables from your satelite box output to the receiver's auxillary inputs or TV inputs.
OR
Red and White from your satelite output to an input on your TV, then another red and white from an output on your TV to the recevier. This way you can have sound from the TV and use the receiver when you want things to get louder. You also need a yellow single connector from the satelite to the TV to carry video. If you are using a coax cable from your satelite to your TV then you are cheaping yourself out of picture quality.
Posted on Apr 08, 2008
VOTIT
  • 2071 Answers
SOURCE: Samsung HLN5065W freezes in black / White screen
Picture freezing that is the symtoms of depected DMD modules...
Just click below for electronics store you can order online;
Partstore.com.
Vance Baldwin Electronics
http://servicemanuals.vstore.ca/
http://www.electronix.com/catalog/
Hope this may help;
Regards,
VOTIT
Posted on Aug 21, 2008
VOTIT
  • 2071 Answers
SOURCE: Samsung HLN5065W DLP TV freeze in black/white image after sometime
Partstore.com.
Hope this may help;
Regards,
VOTIT
SOURCE: Need Comcast Remote Code for Samsung LN32A330 TV
I contacted Comcast and here are your codes for the three way remote with DVR Samsung 10812, 10766, 10814. I have the same TV Samsung LN32A330 and it was the very first code for my TV! Hope this cuts down your frustration!
Posted on Feb 04, 2009
SOURCE: White dots appearing on Samsung TV screen and multipling each day
It seems you might have an issue with the dmd board. Go to the menu, and if the dots still show on the menu, the issue definitely is with the dmd board but if they don't come up on the menu, the issue will be with the video board.
Posted on Aug 20, 2009
My tv has gone black and white I dont know how to get the colour back
check color system matches . If tv uses PAL then DVD player needs to be set to PAL. If TV station uses PAL then set devices to PAL. If TV station uses NTSC set devices to NTSC for color system.
Aug 06, 2015 | Televison & Video
My samsung TV will only play DVDs in black and white.
ensure the country region on the samsung bluray is set correctly to your country and tv set (NTSC OR PAL) at setup,
menu/system/setup - select country correctly - and this should detect another TV device if correctly connected through HDMI, and start the anyconnect application, if your Tv is another model, it wont. if playing DVD's in black and white it seems you might be located in another region to which you purchased the bluray player and differs from the set. did you buy the Bluray from the same store as the set?....please dont say ebay !
Aug 02, 2014 | Televison & Video
Why is my Samsung tv only showing black and white picture?
If the normal TV channels are OK then the wrong input has been selected. Probably set to component instead of composite.
Oct 14, 2017 | Samsung SyncMaster Televison & Video
My Samsung TV picture is supplied via a HDMI lead
yes you need to connect audio out from the tv to audio in on the dvd surround. you need the red/white phono to phono leads, simply connect together and select audio (av,au) on the input selection.
Feb 20, 2010 | Samsung LN46A650 46 in. LCD HDTV
My dvd's are all in black and white for some
hiya,
Try checking the connections between the dvd player and the tv, make sure they are fully pushed in.
If that doesnt work and you have a spare socket on the back of your tv try swapping the lead to that one.
I know that with scart leads if they arnt fully pushed in you will get a black and white picture.
I hope its thats simple..
Mike
Aug 02, 2009 | Bose Lifestyle 38 System
Proscan 26LB30Q Vs PS2 = HELP
The red white and yellow cables are composite connections. The red/green/blue connections are component connections.
The playstation's composite connections consist of two audio connections- red & white, and a composite yellow video connection. The TV's white connection is the audio, and the red/green/blue are component video. You need an adapter that will connect the one yellow(composite video) to the three red/green/blue (component video) connections
Feb 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Cant find channel for playstation 2
I have got a Finlux plasma television and i cant find my instructions. I have just been given a play station 2 and i have put it all correct in my television but its not coming up on my screen. I dont know what channel to put it on, please can you help me!?
Feb 16, 2009 | Sony PlayStation 2 (PS2) Console
Have a Konka TV but ps2 doesnt play through it.
It may be the T.V. And make sure that the connections are with the right colors, take a light back there and check to make sure. You said the T.V. plays through black and white, maybe the T.V. is old and can only play black and white but those cables will not make a T.V. go to color.
Jan 29, 2009 | Sony PlayStation 2 (PS2) Console
About play station 2
The device to use PS2 controllers (or any game controller) on a PC is called a superjoy. http://www.goldenshop.com.hk/AI-trad/pc/pc_joybox4.htm
Sep 22, 2007 | Sony PlayStation 2 (PS2) Console
What do I do to change from black & white to color on the screen?
Don't rate me badly for this, because this most likly is wrong, but try adjusting the TV Settings. It depends on the TV you are using and input cords (take a look at how firmly the input cords are) but try pressing menu then picture qualitity. Hope it works
Dec 28, 2006 | Microsoft Xbox Console
Samsung HT-DS610 System Logo
Top Samsung Audio Players & Recorders Experts
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
