Question about Midland Radio Communications
No reception even though the radio is new - Midland Radio Communications
    Problem Solver:
  • 44 Answers
Check coxail to antina
Posted on Jan 03, 2011
Antena for bose radio?
The Bose uses its power cord as an FM antenna. Make sure it's reasonably stretched out (not coiled), and is not in surroundings that shield it from the outside (a steel frame building, though even here putting it close to a window can give you reception). If this isn't enough to get stations clearly, there is a jack on the back of the radio where you can plug in a dipole (piece of wire) antenna available from Bose -- not cheap for what it is -- an indoor antenna from Radio Shack or a similar store, or even a roof-mounted unit. If you don't buy from Bose, you'll need an adapter to convert from the standard plug everyone else uses to the phone jack Bose has decided to use instead. Radio Shack sells one: catalog 278-257.
Jul 13, 2014 | Bose Wave Radio
Best buy installed radio & speakers bad reception told by installer factory wired wrong true or false can i get new harness & instructions where & price
Best Buy has a pretty good reputation for installing aftermarket radios and they generally use a new harness connected to the old harness to make it work right.
I would try to have the reception issue fixed by Best Buy before the warranty runs out.
How long ago did you have it worked on?
I'm sure they will make it right if you take it back.
Even, if it requires changing out the radio.
Have them check that the antenna is properly connected to the back of the radio.
Oct 28, 2010 | 1990 Chevrolet K1500
RDS reception with BMW Business radio
Well i remember the M25 being built so i wouldnt know about radio reception ,but i do remember radio london and caroline.Now i would imagine that this sort of auto reset of tuning reception is controled by a micro chip and this chip is now not working as it should so if you want it to work then its most likely cheaper to install a new radio.Or just use long wave for radio 4.
Jul 16, 2010 | 2000 BMW 3 Series
Have new dx959 doesnt get out very far talking 100yrds or so use rdking 56 mic mic works fine on old radio pc 78 and gets out fine also are 959 radios ok or junk has good reception
The DX959 has an output power setting knob. It's located next to the channel selector and is labeled RF Power. Turned counterclockwise will reduce output power. Turned clockwise will increase output power. Your switch is probably turned all the way counterclockwise resulting in low transmit volume.
Also, make sure the wiring for the RK59 is correct for the Galaxy. Even though it's a 4 pin plug, the pinouts may be different for the Uniden and Galaxy radios. Do a Google search for mic pinouts for your two radios to check.
Jul 12, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
Poor tuner reception
THIS IS NORMALLY DUE TOO BAD EARTHING, MAKE SURE YOU HAVE A GOOD CLEAN EARTH ON BODY
May 11, 2009 | Car Audio & Video
Bad reception w/ Panasonic RF-544
I solved the problem, but I did not "fix" the problem. Rather than rig an antenna to the old Panasonic RF-544 radio, I put it upstairs where it has good reception. I put the new Sony ICF-38 downstairs where it brings in the stations I listen to. The advertsizing claim for the Sony ICF-38 is that it has "Good Sound and High Sensitivity." I believe it does have "high sensitivity" because even in the basement it brings in my desired stations. (I am still curious to know if I could have rigged an antenna to the old Panasonic RF-544.) RL
Dec 07, 2008 | Panasonic RF-544 Radio
AM reception/AM power problems
Don't take your radio to work. Get your work done , then go home and listen to it. You will get better reception in a res. area.
Oct 08, 2007 | RCA RP7887 High-Performance Super Radio
VOX Transmit is "pulsing". Also, no wx channel reception
check if the mic is not dirty, there is nothing that you can do to fix this problem.
May 04, 2007 | Motorola Talkabout T6310 (14 Channels)...
Radio Communications Logo
37 people viewed this question
Top Midland Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
