Question about Refrigerators
Ice maker flashing 2 times then pause, tried powering down to reset, jumped out t-h to force harvest, led went to flashing then back to 2 times repeating. No movement from ice maker. Checked voltage and I'm only getting 80 volts. I can't find a wiring diagram. can you help?
    Problem Solver:
  • 17 Answers
Replace pipe thermistor who attach with freezer
Posted on Dec 31, 2010
Icemaker not working
Here are the tests for the IDI Optics ( the red light)
Jan 28, 2016 | Whirlpool Refrigerators
BROKEN INFRARED ICE CONTROL - ON WHIRLPOOL SIDE BY SIDE. CAN I REPLACE THAT PART?
The part you need to replace is 4389102 this comes with both boards and replace them as a pair. I have a question though, is the harvest fingers in the ice maker at position like a clock? Also to confirm the flashing of the light when the flap is depressed it 2 flashes and a pause? Not 1 flash and a pause, this means unit is harvesting and the ice maker should be moving and if not the ice maker could have a broken gear. This control unit could run you about 100 buck so make sure this is what you need before your purchase. Good Luck
Jul 28, 2014 | Whirlpool Refrigerators
Whirlpool how to install
With the freezer door open, depress the flap on the left. Does the flashing stop? If so, the Ice maker is the problem, not he optics. With the flap depressed is the only way you can test this. Solid light mean good, one flash and a pause means cycling, 2 flashes and a pause means faulted optics. Now for the ice maker, what position are the harvest fingers sitting at? At 2 O'clock the Ice maker is parked, At 12 it should fill with water so if the fingers are in any other position than 2 O'clock than the ice maker will not cycle at it can't. Its possible that the ice maker have a broken gear and will not function as designed. Get back to me if you need more information and a model number would be great. Good Luck
Jun 18, 2014 | Whirlpool Refrigerators
WHY scotsman iec machine shuts down on the refridgeration light ON CM3 CONT
Is the machine producing ice thick enough to come off the evaporator plate? the machine will try to harvest 3 times before it locks out on long harvest. Harvest cycle: The compressor and hot gas valve are both powered during the harvest cycle. The fan and pump are off at this time. The machine stays in the harvest cycle until the evaporator thermistor senses 52 DEG F. If the bin is not full, the unit goes into another freeze cycle. I would check the Thermistor
May 28, 2014 | Scotsman CSW45 15" Ice Maker with 26 lb....
Sce170a-1a wont harvest
This machine has a cube size control. Which tells the machine when to go into a harvest. there is a harvest switch did you try to force it into a harvest and if you did, did it harvest. depending on ambient temperature from start of freeze cycle to harvest it should be making ice every 15 to 18 minuets and then go into a harvest. so start the ice machine and time it , run it for 18 minuets and force into a harvest. after ice drops check the ice bridge thickness. Bridge thickness should be about 3/16'' the ice dimple must not be DEEPER than 1/16". If this is good then we need to look at what is not working to harvest ice. The cube size control is a reverse - acting thermostat that controls the start of the timed freeze cycle. It must be set properly to prove the correct size cube bridge. When it is closed, an indicator light on the control board will be on. If you force it into a harvest and it harvest the ice with no problems and the ice is at the right thickness then replace the cube size control, but if dose not harvest the ice and you see the ice is at a good thickness and not to thick because if it is to thick it will freeze to every thing and will not drop. SYMPTOM. Unit freezes, but will not try to harvest. POSSIBLE CAUSE: Cube size control will not close; to check: Unplug water pump, switch unit OFF and then ON, in about 2 minutes the timed freeze light on the control board should be ON. PROBABLE FIX: If timed freeze light does not go ON, replace cube size control. SYMPTOM #2: Timed freeze light glows, but after 4 minutes unit dose not power hot gas nor purge valves Then replace control board.
Dec 15, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Installed new valve, getting water to valve but ice maker will not cycle or call for water
GE's ice makers are harvestable, means you can manually tell the ice maker to harvest or cycle. Turn ice maker off, went 5 seconds, turn ice maker back on, tap the paddle 3 times (push the paddle inward completely) then it should cycle, may have a delay like 20 second. I hope this helps.
Jul 12, 2011 | GE WR57X10033 GE Refrigerator Water Valve
English instructions for saivod fhs186 ice maker
DO THE BASICS:
Change the water filter
Add ice machine cleaner and go by the directions.
What should be kept clean?
There are 5 things to keep clean:
1. The outside cabinet & door.
2. The ice storage bin.
3. The condenser.
4. The ice making system.
5. The ice scoop.
The ice storage bin should be sanitized
occasionally. It is usually convenient to sanitize the
bin after the ice making system has been cleaned,
and the storage bin is empty.
A sanitizing solution can be made of 1 ounce of
household bleach and two gallons of hot (950F. -
1150F.) water. Use a clean cloth and wipe the
interior of the ice storage bin with the sanitizing
solution, pour some of the solution down the drain.
Allow to air dry.
How to clean the condenser.
The condenser is like the radiator on a car, it has
fins and tubes that can become clogged. To clean:
1. Remove the kickplate.
2. Locate the condenser surface.
3. Vacuum the surface, removing all dust and lint.
Caution: Do not dent the fins.
4. Replace the kickplate.
Winterizing
1. Clean the machine as explained on the next
page.
2. Turn off the water supply.
3. Drain the water reservoir. See page 24, Spray
Pump Repair and follow the instructions to remove
the pump hose (step 2, bottom hose only).
4. Disconnect the incoming water line at the inlet
water valve.
5Remove control box cover and turn the timer
into the harvest cycle.
6. With the machine operating, blow air through
the inlet water valve; a tire pump could do the job.
7. Drain pump models should have about 1¤2 gallon
of RV antifreeze (propylene glycol) poured into the
ice storage bin drain.
Note: Automotive antifreeze must NOT be used.
8. Replace control box cover. Switch off and
unplug the machine.
CUBE ADJUSTMENTS
There are three items that may be adjusted: Cube
Size, Harvest Time, and Bin Level. Note: Cube
Size and Harvest Time adjustments should only be
done by a qualified service person.
Cube size control.
The cube size control should only be adjusted to
bring the cubes to the correct shape, the overall
size cannot be adjusted. Try to adjust the cube
size control when the ice machine is in the harvest
cycle, or in the first 10 minutes of the freeze cycle.
1. Open the door and remove the control box
cover.
2. Locate the cube size adjustment screw, and to
make fuller cubes, turn the screw clockwise about
1/4 turn. This will make the freezing cycle longer.
3. To shorten the freezing cycle and make cubes
that are not as full, turn the adjustment screw 1/4
turn counterclockwise.
4. After the next freezing cycle, the cubes should
have responded to the adjustment, if another
adjustment is required, do it early in the freeze
cycle.
Diagnostic Codes
Code Description
F - - - - - - - Freeze Cycle
F flashes- - - - Freeze Cycle is Pending
H - - - - - - - Harvest Cycle
H flashes- - - - Manual Harvest
b - - - - - - - Bin is Full
C - - - - - - - Clean Cycle
L - - - - - - - Board Locked
d - - - - - - - Test Mode
O - - - - - - - Off
E - - - - - - - Self Test Failed
1 flashes- - - - Max Freeze - Retrying
1 - - - - - - - Max Freeze Time Shut Down
2 flashes- - - - Max Harvest - Retrying
2 - - - - - - - Max Harvest Time Shut Down
3 - - - - - - - Slow Water Fill
4 - - - - - - - High Discharge Temp
5 - - - - - - - Sump Temp Sensor Failure
7 - - - - - - - Discharge Temp Sensor Failure
8 flashes - - - Short Freeze - Retrying
8 - - - - - - - Short Freeze - Thin ice
All 4 Upper Lights Flashing - Unit Remotely Locked Out
Jul 14, 2010 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Replaced water valve to ice maker -used jumper method on the ice maker to test - worked once then not again. checked the voltage coming in and it was 33 volts the ice maker also won't cycle with the jumper...
You need to replace the icemaker . Pt # 2198597 . When you open the freezer door . the laser flash 2 times , then pause , then 2 more times continually (normal) ? If the laser does not light at all , then icemaker is in the harvest mode ( may be stuck , replace icemaker ) . If in harvest mode , even slightly , jumper will not work .
Aug 29, 2009 | Refrigerators
Icemaker
Pull the front cover off the ice maker and force a harvest to see if you now get water. Also if the freezer is not 10 degrees or less it will not cycle. Jump "T" to "H" with a pice of wire stripped back 1/4" on each end. You only need a very short piece of wire. Leave it in the two holes for 15 seconds to see if a harvest will happen and if it will again fill with water.
Jan 10, 2009 | Refrigerators
GE Icemaker PFSS6PKXASS
To reset the filter light you need to hold the button in for 3-5 seconds , the light will usually flash while you hold the button down then it will go solid and then go out once you release the button. The ice maker will only make ice when the freezer is cold enough approx -14c . Did it make ice ok before ? There is the possibility that when changing the water filter air got into the system and has not bleed out of the ice maker feed tube yet.
The Ice maker can usually be put into a test mode by turning it off , wait 30 secs then turn it back on and press the ice level sensing paddle back three times within 15 secs of switching the ice maker back on . The ice maker should then go through a forced harvest cycle and ask for water at the end of it.
Hope this helps
Sep 02, 2008 | Refrigerators
Refrigerators Logo
54 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
