Question about Nikon Coolpix P1 Digital Camera
Picture project doesn't show up on computer. i have followed all instructions: set-up - usb and ptp, had computer off, turned it on; usb plugged directly into computer; all this worked in june but now nothing -- help
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
PictureProject was retired years ago, replaced by Nikon Transfer and Nikon ViewNX. You can download the current versions of all (free) Nikon software from
http://support.nikontech.com/app/answers/detail/a_id/61
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
Posted on Apr 25, 2011
How to get the Nikon in 5200 PTP Mode? Can not find USB mentioned any where.
I would not use PTP. Too many things can go wrong. Just about all professionals download directly from the SD memory card. Follow the following steps. They are very similar for both Mac and PC.
1) With the power turned off, remove the SD flash memory card from your camera.
2) If your computer has an SD card slot, insert the SD card in the slot. If it does not, there are many USB cable input card readers for under $20. Connect the external card reader to a USB receptacle on your computer. In either case, the computer will use "Plug-n-play" to connect your SD card.
3) Double click either the device or folder on your desktop. The pictures are almost always inside a subfolder. When you open that folder, you will see your photos.
4) Depending on what you want to do with your photos at this point, you may want to move the downloaded pictures to another location or software such as Lightroom or Photoshop.
5) CAUTION! If you want to erase your SD card, DO NOT DO IT VIA THE COMPUTER. Your computer's formatting may not be compatible with your camera's format algorithm. Remove the SD card from the computer or reader and insert it in the camera. Follow the instructions on page 168 of the D5200 manual to reformat the SD card.
May 19, 2014 | Nikon D7000 Digital Camera
My pc cannot detect my Fujifilm Z33WP connected with usb cord supplied. It used to work but now , nothing...help pls
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Feb 11, 2013 | Agfa FUJIFILM FINEPIX Z33WP Digital Camera
I can't download pictures to my computer error message says cannot detect camera
It may be a USB port issue or a USB cable issue. Try an alternate cable or a different USB port. Try other USB devices on those same ports to make sure they work. Try using a USB card reader to transfer photos from the card directly instead of plugging in your camera directly.
Jul 04, 2012 | Canon Powershot Sx150 Is 14.1 Mp Digital...
I couldnt able to copy from my sony camera to my pc
RE not being able to USB function on Sony Cyber Shot camera connecting it to TV....solution was to change USB Mode on camera from PTP to AUTO.
Turn on camera, press home button. Click to Main Settings 1 and then use down arrows to go to Main Settings 2. Highlight USB MODE PTP, and use right arrow to change setting to AUTO, and press Home button to exit.
Apr 21, 2011 | Sony Cyber-Shot DSC-W220/B Digital Camera
The memory card is not showing my pictures when i plug my camera into my laptop
Please follow the steps below for connecting the Camera to the Computer for transferring the images.
Turn the Camera ON.
Turn the Computer ON.
Make sure to Insert the Memory Stick in the Camera.
Set the USB CONNECT option in the Setup 2 Menu of the Camera to PTP. [Set the Mode dial of the Camera to Camera, press the Menu button, select SETUP-->SETUP2-->USB CONNECT-->PTP-->OK.]
Connect the Camera to the Computer using the supplied USB cable.
The Computer will automatically install the USB Driver for the Camera.
When the installation completes, an AutoPlay window will appear.
In the AutoPlay window, click the Import Pictures option.
In the Importing Pictures and Videos window, click the Import button.
If the USB connection from the camera is not recognized by the computer, disconnect the USB cable and repeat changing the USB CONNECT option to PictBridge, Mass Storage or Auto.
If the issue persists, try connecting to a different USB port on the Computer.
Try re-installing the USB Driver from the Device Manager.
Good Luck!
KenSolutions
Nov 23, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
DSC-S730 copy my picture to my computer?
The procedure to transfer pictures to a Computer depends on whether or not the Camera has the capability of using Picture Transfer Protocol (PTP). If the Camera is capable of PTP (in this case; DSC-S730 - YES), set the USB mode in the Camera menu to PTP and then use the PTP procedure to copy the pictures to the computer. Otherwise, use one of the standard USB transfer procedures.
This procedure must be performed while logged in as Administrator or to an account with Administrator rights:
  1. Turn on the Computer.
  2. Turn on the Camera.
  3. Insert the recording media containing the pictures into the Camera.
  4. Set the USB connection or Transfer mode setting in the Camera menu to PTP .
  5. Use the USB cable supplied with the Camera to connect the Camera to the Computer. NOTE: Connection through a USB hub or other USB device --such as a printer or keyboard-- is not supported and cannot be guaranteed. The Camera should be connected directly to a USB port on the Computer.
    NOTE: The Scanner and Camera Wizard should automatically start.
  6. In the Scanner and Camera Wizard window, click the Next button.
  7. Under Choose Pictures to Copy , do one of the following:
    • Click to select each picture you want to copy.
    • Click Select All to select all the pictures for copying.
    NOTE: Selected images will be marked with a green check mark.
  8. Click the Next button.
  9. Under Picture Name and Destination , in the Type a name for this group of pictures field, enter a name for the folder where the pictures will be saved.
  10. Next to the Choose a place to save this group of pictures field, click the Browse button.
  11. In the Browse for Folder window, click to select the location on the computer where you want to save the pictures.
  12. Click the OK button.
  13. In the Scanner and Camera Wizard window, click the Next button. NOTE: The pictures are copied to the Computer.
  14. After the transfer process it finished, under Other Options , click to select Nothing, I'm finished working with these pictures .
  15. Click the Next button.
  16. Click the Finish button.
If you are still unable to transfer pictures, please switch the USB mode of the Camera to Normal or Mass Storage and try again.
After following the steps above, the pictures from the camera should successfully be copied to the computer. If for some reason the pictures did not copy, try using the method for standard USB picture transfer.
I'm assuming you are using the Windows XP Operating System in the Computer. If not then follow this link:
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C116935
Good Luck!!!!!!!!!!!!!!!!!!!!!!!
Sep 06, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
Computer cannot detect Camera
RESTART YOUR COMPUTER AND try to use other USB ports
Nov 04, 2008 | Canon PowerShot SD600 Digital Camera
Can't Upload Pictures
What kind of system are u using? Mac or PC? What version of windows? If you are using their photoloader software please check the following: In picture taking mode press menu Go to setup tab Go up to USB press right arrow and highlight mass storage. press set. try that. If that doesn't work then try this: In picture taking mode press menu Go to setup tab Go to USB press right arrow highlight PTP press set. This will allow you to chose which program to open with. Chose the Microsoft scanner/camera wizard and then just follow prompts.
Aug 07, 2006 | Casio EXILIM ZOOM EX-Z60 Digital Camera
D70 USB setting issue
Users of Windows 98SE, Windows ME, Windows 2000 and Mac OS 9.x may experience problems trying to download images from the Nikon D70 using Nikon View. Initial shipments of the D70 have the USB option in the "Set up" menu set to PTP - Picture Transfer Protocol. PTP is only compatible for downloading images with Windows XP and Mac OS X. To solve this issue please set the USB menu option to Mass Storage and then connect the camera to the computer. The D70's card will then mount like a removable disk and Nikon View will be able to transfer images
Aug 30, 2005 | Nikon D70 Digital Camera with 18-50mm Lens
Nikon Coolpix P1 Digital Camera Logo
27 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
