Question about Cameras
I dropped my Fuji Finepix J50 while it was turned on. The lens is retracted and nothing happens when I press the power on button. The battery is fully charged.
  • Cameras Master
  • 4,738 Answers
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Posted on Dec 30, 2010
Showing lens control error fuji finefix HS 30 exr
Does it say Lens control error, or does it say Focus error, turn off the camera and turn it on again?
The last can happen when you touch the lens barrel. When the lens does not retract when you shut down the camera, perhaps the battery is exhausted or the barrel got stuck.
Try to recharge the battery and start all over again. If nothing goes, try carefully to pull out the lens a little Less then one millimetre. or gently press it back a little. Be aware the camera is a very delicate piece of equipment, so don't use force, because that could damage the camera definitive.
In the manual, it says you should contact FujiFilm, when the error comes back after you switched off and on. So if nothing helps, that is the last option. Visit a repair shop from Fuji, or bring a visit to your dealer.
Dec 27, 2013 | FUJIFILM FinePix F300EXR Digital Camera
Lens on my S7000 doesn't retract when switched off - now permanently extended - and camera dead
This is going to require service / repair at the shop, not something you will be able to correct.
Jan 26, 2013 | Fuji FinePix S7000 Digital Camera
Suddenly, after taking some photos the camera will light up to the Fujifilm start window, and no further, then blacks out. It will not shut off with the power button, nor retract and close the lens even...
The main board is bad. Was it recently dropped? If so, then the board might have been damaged - it's not worth fixing. When a camera is dropped it's like a car getting into a major collision - you'll have other problems later. As long as the memory card is good, you should still be able to recover your pictures.
Dec 12, 2010 | Fuji FinePix J10 Digital Camera
How do I fix the Zoom Error for Fuji Finepix F47fd? I can't even extend the lens fully like what previous posts stated
Hi Jasmine,
With fresh batteries inserted in your camera, try to do this little trick:
1. Hold the camera on your right hand with the lens facing the ground.
2. As you press the power on button, tap or hit the camera's base to your left palm. Do this several times.
Chances are, there could be a sand or granule of dust that got stuck on the sides of the lens, preventing it to retract properly.
Hope this helps.
Dec 13, 2009 | Fuji FinePix S304 Digital Camera
Zoom error ( stuck) fujifilm finepix s2000 hd
The lens is having a hard time retracting out that is why it is giving you that error. Make sure that your battery is fully charged and if it is, but still does not do any good, then do this little trick:
Hope this helps.
Nov 27, 2009 | FUJIFILM Finepix A200 Digital Camera
Lens wont retract or extend when pushing the power button and cannot take photos. power will not remain on.
Can you turn the camera on by pressing the playback button? This should turn the camera on to view pictures on the card without opening the lens.
Check the tab on the battery door. it should activate a micro switch next to the card slot on the main board. If this is damaged then the camera will not power up.
If the lens is stuck then this will also prevent power up
Nov 15, 2009 | Fuji FinePix E900 Zoom Digital Camera
'FOCUS ERROR'
If bought this at best buy and are still under your MFG warranty they can send it out to repair, or if you have their service plan, nothing you can do, this needs to be sent to a repair facility...
May 28, 2008 | Fuji FinePix A500 Digital Camera
FUJI FINEPIX S7000
Try it with a different set of battery. It is possible that one of your battery is "dead" or close to it, and the camera shuts down.
You have to find the bad battery.
It worked for me.
Jan 22, 2008 | Fuji FinePix S7000 Digital Camera
Cameras Logo
27 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
