Question about Hitachi DVD / VCR Combo
Hitachi DV-PF 2U dvd player works fine when hooked directy to TV (channel 3) but won't work when connected through the new COX digital cable box. TV is set to channel 4, dvd player turned on, disc inserted, dvd remote set with dvd button-just get solid blank screen on TV.
    President:
  • 1,335 Answers
If the cable box needs to be set to 4, the TV will need to be set to 4 as well as the dvd player. The hookup should be cable box to dvd player to the TV for your system to work. Let me know if you have any other questions. Thanks.
Posted on Dec 30, 2010
My RCA XL100 is hooked up to cable and works perfectly fine. We've had it for ages and the picture is clear, sound is beautiful, and it gets along fine with my universal remote. There's just one...
Some of their very old sets the video input was located on channels in the 90's; Try scrolling down from 99 to 90 to see if you locate the video input; this is just the way they did things in the older sets.
Before you rate this solution let me know what you find first.
SD TECH
Jul 08, 2011 | RCA Televison & Video
How do i hook up a dvd player to my tv if i have cox cable? I dont know what channel to put my tv on. I know there has to be a way to watch a dvd without unhiiking the cable
Most DVD players have a coax input and output on them. But some newer ones don't. Assuming your does then you can run your DVD player to your TV with a coax cable you bet. Either on the back of the DVD player there will be a little switch or in the menu settings it will give you an option for channel 3 or channel 4. The same channel you select on the DVD player will be the same channel you will want to put your TV on. For the coax install run it from the output on your DVD player to the coax input on your TV. If you use a coax for cable too then just run you coax from the output on your cable box to the input on your DVD player.
Mar 20, 2011 | Samsung Televison & Video
I have a new rca receiver and have it hooked up to my dvd player which works fine. I have it hooked into my tv and Im not getting sesurround through my tv how can I connect to the tv to make it work my tv...
Take a clue from the 10-year old vintage of the TV and the two analog audio cables. It's Dolby Pro Logic Surround at best, not Dolby Surround in the modern, digital, multi-channel sense.
TV's are not the source nor the end of a multi-channel audio chain. Feed this thing a 2-channel source from a Cable Box (into the "TV" jacks), DVD, Video Tape or CD with proper Dolby Surround encoding and will seem to open up the sound field a bit and kick in a little surround effect. It can also simulate a Hall effect and Dolby 3 stereo.
http://en.wikipedia.org/wiki/Dolby_Pro_Logic
Jan 27, 2010 | RCA RT2400R Receiver
Would like to record from my tv to my magnavox dvd/vcr combo box
If I understand your request right, You do not have cable or satellite box.
You can not record from your TV. You use the TV as a monitor from the dvd/vcr combo box. What the box receives is what shows on the TV. So you will have to have a digital convertor hooked to the (antenna in) dvd/vcr combo box, (antenna out to the tv antenna in) Depending on the antenna you are using that is on the other end of your cable-in coax connection this will hook to your antenna in on the digital convertor box. If your cable is hooked up and operating correctly and directly to the tv that is digital ready you probabbly have a good picture. When the vhf/uhf signal was transmitted you could go from the dvd/vcr to the tv with no problem. But now that the signal is digital and the tv is set for digital the dvd/vcr will not pass a digital signal to the tv. Best suggestion, you have to get a digital dvd/vcr receiver. If you have more question please contact me.
Mike
Jul 25, 2009 | Philips Magnavox DVD/VCR Dual Player
How to set my DVD/VHS Govideo player...
If you used to put the TV on channel 3 to watch the videos that means you had this hooked up with the RF RG6 COAX cable. You most likely had this passing thru the cable box and then to the TV, but with the new digital format that may not work any more. A quick fix for this is to take the coax wire from the player and hook it up directly to the TV Cable port then flip your tv to 3 and it should work. If you have an older tv without the newer connections you may have this port already in use with the cable box - if that is the case you may need to get an RF switch or splitter. hope this helps
May 01, 2017 | GoVideo DV2150 DVD VCR
Problem hooking up DVD player to TV thru my cable box
Chances are you've got your DVD player hooked to OUPUT jacks on the cable box, not inputs. I haven't yet seen a box that takes any kind of an input other than the cable line, but they will have RCA jacks for audio and video outputs on the back. So your cable channels are fine, but the DVD signal is hitting a dead end.
The only solution if your TV doesn't have RCA inputs for video and audio is to get an RF converter (around $10-$20). This takes the A/V signals from your DVD and turns them into a channel 3 or 4 signal that connects to your TV's antenna input.
The converter also has a connector on the back for the cable coming from the cable box, since you'll have to disconnect that from the TV. When the DVD player is off, the cable box signal gets passed to the TV as normal. Turn on the DVD player and the RF converter switches on; put your set on channel 3 or 4 and you'll see your video.
One final thing: The converter will need an AC outlet for its power adapter or power cord, so make sure you have a spare. If you don't already have your TV and DVD player connected to one, this would be a good time to pick up a surge-protector outlet strip. Then not only will you have enough outlets, you'll be protecting your equipment as well.
If this solution has given you what you need, please take a moment to rate it appropriately. And thanks for asking here!
Feb 01, 2009 | RCA DRC277 DVD Player
Ittermittent digital audio drop out on some channels
Did the issue ever get resolved. I have similar issues with a connection to Cox Cable HDTV and Onkyo TX-DX989. All sources (DVD Player) sound fine and not issues except channels 706 and 710 on Cox Digital receiver. I had Cox replace the HDTV receiver and the same issue occurs. I've tried optical audio and also the COAX audio ports with the same issue. The workaround I have found is to set the audio to "Other" on the Cox box, but the volume then has to be turned up quite a bit.
Jan 16, 2009 | Onkyo TX-DS989 Receiver
Hook up Cox Dig CBL Box to receiver and TV for home theater
The easiest way to proceed is by using RCA cables (the red, white, yellow) to connect the cable box.
Jan 02, 2009 | Pioneer HTD-510 System
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
Hooking up a magnavox MWD7006 DVD player to a APEX TV
honey and guest: connections: Red, white, and yellow composite from out of cable/sat box to in of this dvd, and then a 2nd red , white and yellow cable from out of this player to in on television. Every television calls the correct channel something different - make note of where you plug the r,y,w cables to TV -- it may be labelled video1, video 2, av1, av2, input1, ext 1, etc. Turn tv to correct input/av/source/video channel. Call 1-800-605-8610 for further assistance.
Jan 13, 2008 | Philips Magnavox MWD7006 DVD Player
Hitachi DVD / VCR Combo Logo
137 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
