SOURCE: whirlpool lhw0050pq washer will not spin
Possible your belt is loose; you have to unscrew the back after disconnecting electrical connection from wall socket. If the belt "gives" more than half an inch, you have to loosen the motor bolts and push motor upwards, then tighten the bolts very well. Try spin only to check, before closing the behind. It shd spin very fast.
SOURCE: roper(whirlpool) washer will not spin
check the tub casting under the agitator or it the gearcase
SOURCE: Washer will not Spin during SPIN CYCLES
Thanks for the question If your washer sorta spins and washes ok, your problem is with the transmissionTHanks for your question THe Appliance doc
SOURCE: My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
SOURCE: My washer won't complete the final spin cycle. It
Hello, problem here is the spin control board is bad. Remove panel under the door and you can locate the spin control at the rear right of the machine screwed to the floor. Replace it and you will be all set. Mike
