Question about Kicker Car Audio & Video
How do i install kicker ds600.2 speakers into my car
My one kickers car speaker won't turn on, i replaced the old speakers and put these new kickers 6" speakers. One speakers works but other one doesn't?
try bridging them , first check wires from amp to box or boxes connectors , then check wires inside the box or boxes , then check fuses on amp !
Sep 18, 2013 | Kicker Car Audio & Video
How to hook up 2 kicker 10" speakers & kicker amp to a 2002taurus
Good day ma'am, hi, hooking up an extra amp. on your radio is done by audio professionals, but if you can remove the radio out from your ford, you can install that extra amp. Just follow the diagram below.63bff30.gif You need to find line out of your radio to line in of your kicker amp. connect them using audio shielded cables. connect your speakers to the amp. I guess you this already.
Nov 23, 2009 | Kicker KX600.1 Car Audio Amplifier
I cant remember how to install the kicker 12 l7
Your subwoofer is single or dual voicecoil? And what amplifier Make/model are you putting it on?
Thanks!
Nov 04, 2009 | Kicker (2) S12L7 12in Solo-Baric L7 + (1)...
It's getting very hard to find aftermarket 4/10 speakers, the last set I had were JBL and they were great, 10 Years ago Where do I go now, ps. they have to be 4ohm, not this GM 10ohm.
Kicker makes a set of 4X10's i just installed a set into my buddies 99 yukon, they even bolt up to the factory location. the speakers are kicker ks4100.
Aug 11, 2009 | Car Audio & Video
Best amp for Kicker Sub
Hello dalex7,
The Kicker 08ZX400.1 would be a great amp for your subwoofer. It will work into a 4ohm load with no problems.
But you can buy an amp with more power, looks better, has a smaller footprint, and cost less than the 400.1. I'd look at the Alpine MRP-M500. Take a look at it here at Crutchfield. The M500 is also easy to install, runs cool, and is very efficient.
Hope this helps.
May 21, 2009 | Jl Audio CVR12 Kicker 12" CompVR Series...
Kicker Subwoofer rating
These are good subs allbeit overpriced..they wirk best in 1.25 -1.75 cu.ft. enclosure or in a bandpass box, if you are a thumper, you'll like this sub.
Mar 13, 2009 | Kicker S8L74 Car Subwoofer
Am trying to install some L5 kicker subs..
I found this wiring guide to wiring them to the sub enclosure.
Click HERE
Jan 04, 2009 | Kicker CVR12 Car Subwoofer
Installing L5 kicker subs
Heres the link to a wiring diagram for your subwoofers
CLICK HERE
Hope this answers your question, thank you for stopping by Fixya!
Srt 8 factory kicker system
try running the cables trough a crossover & u can run what u want to what speakers u want
Aug 09, 2008 | Kicker 01C8VR4 Car Subwoofer
How to install..........
COMTE UNA VERGA GRANDISIMA WEY Y SE CONNECTAN SOLAS IJUUUUUSU CHINGADA MARDEEEEEEEEEE
May 07, 2008 | Kicker CVR12 Car Subwoofer
Car Audio & Video Logo
60 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
