Question about Samsung DV3C6BEW Dryer
Lights come on but dryer will not start. I hear a delayed clicking sound once pushing the start button. door is shut and lint tray is clean.
  • Samsung Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Jan 03, 2011
The dryer stopped working while in use. There is now no power going into the machine. It is a Bosch Maxx 7 dryer.
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
May 06, 2015 | Bosch Dryers
Hi my fisher and pykel dryer starts then turns off after 5 minutes. It is producing heat but won't start for at least another hour. You can hear a clicking sound when you try to restart it. Have cleaned...
Try this test out to see if u have weak windings or relay on motor.
Lastly check ut push start button for continuity with a meter when pushed in the on position, it may have gone bad.
Feb 21, 2015 | Fisher and Paykel Dryers
I have a Kenmore HE 3, model number 110.8787,8789. I cleaned the lint screen, unscrewed the plastic that holds the screen and cleaned all lint out. After doing so, my dryer won't start. The lig
when you removed the screen from the inside you disconnected the wires from the 2 metal strips. now you need to remove the lower panel on the front. and reconnect them. you will need a T-20 torx and unplug the dryer to be safe. the wire will have 90 degree push on connectors and it does not have any polarity concerns. the two male connectors are real close to the top of the panel, maybe even slightly under the other panel. By the upper right of the silver fan duct.
Jan 02, 2012 | Kenmore Dryers
Maytag Performa dryer blows fuse after clothes get hot. I cleaned a large buildup of lint from inside the dryer all the way to my roof. I then replaced the hi limit thermostat, thermal fuse and dryer...
their are two possiblities causing that
1) while cleaning the lint from the motor a wire accidently got pulled of of the motor switch
2) to me the buzzing when start button is pushed and may or may not start,the motor is bad
When trying the trick to start the motor by hand the door switch also must be pressed in
Gene
Aug 05, 2011 | Maytag PYE2200 Dryer
Maytag epic Z dryer. I hear rapid beeps when I press the start button and it won't start, no matter what setting I try. The door is firmly shut and the lint tray is clean.
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
heatman101
May 20, 2011 | Dryers
The delay start light on my washer is on and I do not want to delay start. I have pushed the cancel button twice like instructions say and once I hit start, the delay start light is on and machine is...
First I made sure the detergent dispenser door was closed. That did not work. Then i made sure that the dispenser was clean, by running water thru it. That did not work,. Then I turned the dial to hand wash and pushed the start button. That worked. Delay light did not turn on. Then i turned the setting to the proper wash cycle and pushed the start button. Clothes are being washed now.
Nov 23, 2010 | Frigidaire FTF2140FS Front Load Washer /...
Our dryer ran for about half an hour and then stopped running I opened the door shut the door and you can hear the timer but when you go to push the button to start it it will not start. Any suggestions?
sounds like the overheat circuit breaker popped for safety. when the unit cools it will work again. most likely problem is your vent out is blocked, or lint filter full. once i found a birds nest on the exaust outside lol.
Jun 14, 2009 | Maytag PYE2300AY Electric Dryer
Dryer will not start.. Here clicking sound when i push start button but nothing happens
Did you clean the lint screen and replace? Also - all lint should be cleaned from back of dryer and the duct...many dryer manufacturer have safety sensors that will not light dryer due to there being too much lint, not enough air flow...(safety feature) ...
Oct 09, 2008 | Kenmore 62602 Electric Dryer
Dryer just says beep beep beep everytime I push start
sounds like you may have a bad door switch(mach thinks door is open when it is not).open door and look on front panel that door pushes into.you should find a small button covered in a grey rubber boot.push on it and listen for a click,if u dont hear a click the switch is bad.if u do hear a click it could still be bad or you can have a open thermal fuse
Sep 29, 2008 | Whirlpool GEW9250 Electric Dryer
ASKO T700
I had the same problem. Turns out the reset button on the back of the dryer needs to be pushed; when you push the reset button you should hear a click. If you do not hear a click the problem was probably not the reset button. The button shuts down the dryer heating elements if they are getting too hot and also keeps the drum from turning unless the start button is held down.
If you push the reset button and the dryer starts to work again, I strongly recommend that you stop the dryer and investigate why the heater elements overheated. In my case there was lint/hair build up on the heater elements themselves. Extensive dryer disassembly is required to properly clean the heating elements but it is worth the prevention of a house fire. While you're at it, clean the rest of the machine and the duct work.
Hope this helps
Jun 20, 2008 | Asko T700 Electric Commercial Dryer
Samsung DV3C6BEW Dryer Logo
156 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
