Question about Quasar VV-2002 20 in. TV/VCR Combo
Quasar tv remote.
Something happened to remote settings.  Now I cannot get all the tv channels.  It skips some.  I accidently did this. Now I cannot undo it.  I think it has something to do with the set up button.  The word auto comes up.  Some words are in green and some are in yellow.
  • 218 Answers
Sounds like you need to go to the main menu and run the automatic channel selector again. It will take note note of which channels are not in use and then skip over them when you use the channel advance. Use your remote to get into the main menu and select the "TV" submenu. Then run the auto channel select. After that's done, you can also manually choose to skip channels you don't like. I believe the channel numbers appear in green if they're to be included, and yellow if they're to be skipped. Even if a channel is skipped, you should be able to get to it anytime by punching in the number on your remote.
Posted on Jul 08, 2008
Auto program channels manually
the only way is with the original remote for the set.
Aug 07, 2009 | Quasar SP-2722 27" TV
Remote stuck--can't change channel or turn off TV
Pull out the power plug of your TV and don't use it for few minutes. Remove batteries from your remote and keep it without batteries for few minutes. After about 15 minutes your TV and remove both will work fine.
Jun 15, 2009 | Logitech Webcam
Channel keeps skipping on rca t.v
Problem with channel skipping has rectified itself. I simply unplugged the set and and started over with remote intructions on signal and channel setting. The tv was also turning itself off and on, this also has ceased. Thanks, hope I don't need you later.
Nov 24, 2008 | RCA Universal Remote Control
Quasar model VV2008 tv/vcr
in side the mother board(kit)  there should be vertical IC gone.   check the vertical section  for  the IC number  and  replace it  ,     this  will solve ur problem
Oct 26, 2008 | Quasar VV2009 Combo
20 year old Quasar colour TV (no remote)
That is because the switches of the front panel buttons are stuck or defective.
Try first unplugging power for ten minutes, this probably wont work.
To fix this the TV must be taken apart from an expert, and front panel replaced.
You can enquiry here for parts.
What you can do at home, is getting a replacement remote and using TV with a remote, or buying a freeview box, and watching and changing channels through the box.
You can get a replacement remote here: Replacement Remote Control orReplacement Remotes
My suggestion, if it is supported in your area, get a set top box with 30 channels : Freeview - digital TV from Argos.
Oct 11, 2008 | Quasar SP-2723 27" TV
Set up for cable
You might be able to restore the factory settings by pressing "play" and "FF" simultaneously and hoding them down until the set shuts off (about 5 seconds). Then when you turn it back on it will lead you through the setup routine, which includes auto channel select.
Plan B would be to buy a universal remote.
Jun 26, 2008 | Quasar VV-2002 20 in. TV/VCR Combo
Cable connection
some older tv's only go up to so many may not even need a remote to set up cable tv. if you are going to use a cable box on this tv, put the tv on channel 3.if not, look in front of the tv for a little door. behind it maybe knobs or buttons that can program the channels 1 at a time [+= add - = erase. there also maybe a switch for different cable types [hrc,std, etc]
hope this helps
Feb 02, 2008 | Televison & Video
How to UNDO autoset (channel setter)?
If I am not mistaking this is the same set as the panasonic PV-c2020. I attached an owners manual link here this should help you. Good Luck.
Mar 16, 2007 | Quasar VV-2002 20 in. TV/VCR Combo
Quasar VV-2002 20 in. TV/VCR Combo Logo
274 people viewed this question
Top Quasar Televison & Video Experts
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
