Question about Craftsman 25 gal Air Compressor 3 12 hp Vertical k 2 Stage Oil Free Pump
I have a Craftsman 919.165610 2 stage oil free air compressor. It will not build pressure? I have replaced the check valve, checked the filter and still no luck? Help
    President:
  • Craftsman Master
  • 1,383 Answers
Problem sounds like valve plate /reed valves or worn cylinder /vinyl ring. Easy to check, push piston to top position and examine cylinder neer top looking for scratches. If scratched, most likely vinyl piston ring/s are worn and allowing pressure to leak past. If cylinders look good /shiney all the way up to top, remove head/s and examine reed plate/s for missing/broken reeds and or torn gasket/s. If your reed plate is missing one reed and your are good at being creative, you can seal individual hole by threading and plugging with thin piece of bolt. Good luck and good holidays
Posted on Dec 30, 2010
Leaking around Pressure Switch. Ordered & replaced switch but still leaking
Some pressure switches have a valve that reliefs the compressor head pressure when the motor stops and closes the head pressure relief valve when the motor runs.
There is a check valve that keeps air pressure from coming back to the compressor head and the relief valve.
I think the check valve is leaking tank pressure to the relief valve and compressor head.
The check valve is where the pressure switch mounts on to and it mounts threaded on to the compressor tank.
Try replacing the check valve
Nov 01, 2015 | Craftsman 33 gal Air Compressor 6 hp...
Craftsman air compressor model 191.135131 wont build pressure
I can not find a Craftsman compressor with that model number anywhere so here are a couple things to look into. If the compressor fills to 70psi and keeps on running check the valve plate and piston/cylinder assemblies. Check that the valve reeds on the valve plate are not bent, broken or warped from heat. Then check that the wiper (oil less) or pistion rings (oil splash) are not damaged and that the cylinder wall is not scarred up. Any of these will let the compressor fill up to the point where the air pressure leaks past the valves or piston and won't fill any further. If the compressor fills to 70psi then shuts off the problem is in the pressure switch. Some have an adjustment screw or bolt to control when it turns on and shuts off. If you had a drop from 100 to 70 the springs may be weak or broke and you'll have to replace the switch.
May 22, 2012 | Craftsman Air Tools & Compressors
I have a Craftsman compressor Model # 919-15292 2. The compressor stopped building pressure because air was continually being released through the unloader valve. I have replaced the unloader valve,...
you must have wired the new pressure switch incorrectly .when the pressure switch opens it will release the head pressure so your compressor must be running with the pressure switch contacts open should be 4 connections 2 marked motor which is from your compressor and 2 marked line which is your power coming in
Jun 15, 2011 | Craftsman 33 gal Air Compressor 6 hp...
My ssl5l compressor builds pressure real slow now. Rings or Valves? it did get a little warm while sandblasting lately....
Very rare to have problems with rings. Blow-by would produce high pulsating pressure in the crankcase causing oil to blow out the oil filler plug/ dipstick. If normal crank pressure, suspect problem with valves or gaskets. Remove air filter cover and check for air blowing out of intake or very hot head or air discharge tube. Leaking valves or blown gasket will cause low volume/ low pressure and hot discharge air. Remove the in-tank checkvalve and look for carbon deposits /debris build-up. If the checkvalve and the interior or discharge hose are coated with oil deposits /carbon, most likely problem is valve plate/ gaskets /head. Good luck with your repair.
May 03, 2011 | Ingersoll Rand SS5L5 Ir Electric...
25 lb oil free air compressor craftman not building pressure
most likly the regulator is no good, some can be serviced, some are sealed units.
Mar 12, 2011 | Craftsman 33 gal Air Compressor 6 hp...
Compressor runs to 175psi but trips pressure relief when pressure drops tries to restart motor but motor wont turn blows breaker. changed whole pressure switch have same problem.
The problem is lilkely the check valve between the compressor and the tank -- it is alowing pressure to build from tank to compressor preventing the compressor from turning over. Clean, maybe replace, check valve...
Charlie
Jan 09, 2011 | Craftsman 25 gal Air Compressor 3 12 hp...
I have a 5 gal, i hp craftsmen compressor, 3 years old, used once a year to blow down sprinkler system. Compressor ran up to 120 lbs upon turn on, would not cycle off. manually shut off unit and turned...
Oil free pumps do tend to blow the piston ring (not too expensive) available at searsparts.com. Remove covers to pump and manually turn crank until piston is at top and look at the condition of the cylinder neer top, If it looks scratched, order cylinder kit with piston ring. If it looks good and shiney, could be the valve plate in the head. There are reed valves that tend to break. Run pump however with covers removed and check with soapy water for air leaks and repair as needed (air leaks under the cover will prevent unit from filling). Good luck
Nov 13, 2010 | Craftsman 15 gal Air Compressor 3 hp UMC...
My 1 hp. 12 gal. air compressor is not building air pressure the motor runs the pressure won't go above 20 lb.
It could be that the input air filter is badly clogged. I might more likely be that the Non-return valve on the air tank input is not sealing properly and not allowing the tank to build up pressure. This valve is at the end of the main pipe runs between the compressor and tank. It could also mean (less likely) that the poppet valves inside the compressor cylinder head are not sealing properly. Other faults could be worn rings on the compressor pistons or a bad seal between the compressor cylinder head and block.
To check the Non return valve allow compressor to build up some pressure and then loosen union nut on Non return valve. There should be some air released at first but should stop if valve is ok. If leaking remove valve and check for dirt and clean. If valve still leaks replacement is the only fix.
Sep 14, 2010 | Craftsman Air Tools & Compressors
WILL NOT BUILD PRESSURE
Many craftsman compressor are built by champbell hausfeld using a dry type of cylinder and piston (no oil, no crankcase). If dry type, check for worn cylinder and piston ring. Pieces of the vinyl ring can jamb between the reed valves in the head causing air to escape from the intake. If your compressor has a crankcase and oil, check for broken reed valves in head. Spray soap solution on hoses, checkvalve, drainvalve, and fittings to check for leaks. Most likely problem is reed valves broken or open. Parts are available from sears or match parts to chpower.com. enjoy
Nov 26, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman 25 gal Air Compressor 3 12 hp Vertical k 2 Stage Oil Free Pump Logo
583 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
