Question about Refrigerators
I have an old side by side Hotpoint fridge model CSX20EA. However, when looking on line for parts this model # does not come up. The problem I am having is as follows: Fridge door will not completely close. The door has dropped and I have to lift it to get it closed. I am assuming it is the cam riser??????/and or hinge assy. kit??????? I need to know what the part # it is so that I could get the parts and would prefer to buy it locally so that I don't have to wait for it to be shipped. I live in the 90713 zip code.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 118 Answers
Have you tried RepairClinic.com. They will work with you to solve the problem.
Posted on Dec 30, 2010
Fridge light not working
door light switch Need full model # for better idea .
but normal switch should be at bottom of door or at hing side of ref
some model have at top it may be broke off and thats why you don't see it send us a full model number we will find for you
Feb 28, 2015 | Hotpoint Refrigerators
Freezer working but fridge not cold
If the freezer really is operating at its proper temperature of +- 5 degrees F, then the likely problem is the failure of the fan that circulates the cooled air between the two cabinets. This fan is located behind the liner of either the freezer or refrigerator and is not an expensive part; the labor may amount several times the parts cost.
Since you did not list the model number for your unit, you will have to search on your own to find an illustrated parts breakdown of your fridge. You might start at the Sears parts department website as they have a broad range of manufacturers and models displayed with line drawings which can help you assess the difficulty in either doing it yourself or having it done.
Jan 25, 2010 | Hotpoint Refrigerators
Water on floor under freezer side csx20ea model hotpoint sems like twice a day a puddle the size of a cereal bowl is under front left hand side of my side by side fridg i have a pergo hard wood floor im...
If you have an ice maker, check for a leak in the water line. If no ice maker, there could be a leak in the pan for the defrost water, or the drain hose is out of position. Also, check to see if the water is actually leaking out from the freezer door. That would indicate a clogged drain. The bottom inside the freezer may have water, or ice on it. If so, suspect the clogged drain.
Jan 06, 2010 | Refrigerators
I have Hotpoint bought in 1990 and still works well. I would like to update the look, though. Can I buy new doors?
You have to call a hotpoit parts supplier to see if they still have them or if they can order the doors .They will ask you for the model and serial number wich is located on the side wall inside the refrigerator , some models you find these numbers at the bottom front on the outside of the fridge or also in the back outside of the fridge.
Jul 31, 2009 | Hotpoint HSS25GFP Side by Side...
Freezer cold, fridge warm
Hi, You have a self defrosting problem.
Remove the rear inside freezer panel and check continuity on the defrost element and bi-metal switch.The bi-metal has to be tested cold. If there is continuity on both parts, you will need to change the defrost timer.
The most common part that goes bad is the element. I hope this helps you. Please leet me know if I can assist you further.
Vic
May 28, 2009 | Hotpoint HSS25GFP Side by Side...
WATER RUNNING OUT FROM UNDER REFRIGERATOR
If the floor of the freezer is full of ice, your defrost water drain tube is clogged. Remove the ice in the freezer bottom, find the top of the drain tube inside the freezer near the top of the ramped up area, about the size of your index finger and blast hot water through it with a turkey baster. About 4 cups of good hot water but not boiling
Dec 20, 2008 | Whirlpool 19.8 cu. ft. Side-by-Side...
Hotpoint side by side csx20ea
Replace the defrost timer. Good luck!
barneyluc
Oct 06, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Fridge makes loud moaning sound
It is the control board. There is a recall on certain models and serial #'s that will cover the parts, but not all are covered. do a google search for hotpoint or GE howling noise. you will find out all the info you need.
Mar 14, 2008 | Refrigerators
Freezer not getting cold enough
Have you tried re-gassing your fridge maybe one of your lines may have a leak,let a refrigeration technician check it out to certain
Nov 28, 2007 | Refrigerators
Refrigerators Logo
100 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
