Question about SanDisk Sansa e250 MP3 Player
SD card won't lock into the expansion slot. It keeps popping out. Is there a fix?
  • blm0 Jul 09, 2008
    I have a Sansa e280 with the same problem. There is only one orientation that at all allows the microSD card to slide into the slot. It slides in, but will not lock into place.
  • 8,596 Answers
Try flipping it vertically or horizontally, and see if it will fit in better
If the lock mechanism is physically damaged, you will have to call Sansa and get a replacement player
Posted on Jul 08, 2008
How to remove/load sd card stuck in Huawai M860
The SD memory card slot is spring loaded, to insert the memory card insert the card into the SD memory slot with the SD card contacts going in first and gently push it in until it locks in place. NOTE if the SD card does not slide into the slot easily then the SD memory card has been inserted back to front, turn the SD card around and insert it again.
To remove an installed SD memory card, press the SD memory card and it will pop out slightly then you can then pull out the SD memory card.
Mar 12, 2013 | Cameras
It keeps popping up write protection on and won't let me take pictures
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 09, 2012 | GE T123 Digital Camera
SD card won't stay in the slot of my Panasonic Lumix DMC-SL80
is the lock on the card by chance. also depending on how old the camera is and how big the sd card is in gb. the lumix may not be able to handle that size of card, too many gb. My lumix would only accept up to 4 gb, so when I moved to 16 they did not work.
Oct 04, 2017 | Nikon Coolpix S210 Digital Camera
Nikon d40xcamera...sd card won't click into slot
there is a lock on the side of some sd cards try checking if there is one.
Oct 30, 2011 | Nikon D40x Digital Camera
Sd card won't stay in the slot of my nikon coolpix S210
See fix 4 http://camerarepair.blogspot.com/2009/07/simple-fix-for-memory-card-locked-error.html?m=1
Jan 16, 2009 | Nikon Coolpix S210 Digital Camera
SD card keeps popping up when inserted in cama. SD card will not stay down in camara Says it needs to be formatted. It will not format. Never has this problem before How can I fix this
The SD slot of the camera got damage somehow. The SD slot contains thin copper prongs that locks the card in place and comes in contact with the surface of the card. If these prongs are damaged, then it cause a read failure of the camera.
Sep 29, 2008 | HP Photosmart M525 Digital Camera
LifeDrive will not recognize SD expansion card
If the sdcard is the right type and size all you need to do is fully insert it into the slot. Its spring loaded so it will pop up if it isn't quite far enough in. It should only fit one way.
Generally the LD likes 2gb and smaller sdcards , it can use bigger such as 4gb but that's when you can be hit or miss. That depends on brand and sd version.If you search for a list of LD compatible sd cards you should find out what card to use or buy.
Jun 17, 2008 | Palm LifeDrive Mobile Manager Handheld
Palce where to insert sim card
It's not a phone. It's a pocket PC.
CAUTION: For synchronization to work properly, install Microsoft
ActiveSync on your personal computer before you connect your
iPAQ Pocket PC to your computer.
To install a CompactFlash (CF) or Secure Digital (SD) card into
an expansion slot on the iPAQ Pocket PC:
1. Locate the appropriate slot on the top of the iPAQ Pocket PC.
To identify slot locations, refer to the Getting Started
document that came with the iPAQ Pocket PC.
2. Before inserting a CompactFlash (CF) card into the CF
expansion slot, pull the plastic slot cover from the CF slot.
3. Insert the expansion card into the appropriate expansion slot
and push the connection edge of the card firmly into the
expansion slot.
✎If your expansion card is not recognized, follow the card
manufacturer’s instructions to install it.
✎For more detailed help, refer to the Help files installed on your
iPAQ Pocket PC. From the Start menu, tap Help > Connections.
✎To prevent power loss, remove any expansion cards from either
the CF or SD expansion slots before turning off the iPAQ
Pocket PC.
44bf6e2.jpg Your iPAQ Pocket PC supports 802.11b Wireless LAN (WLAN) technology using the expansion slot in the top of the device. Figure 1: Expansion slot c00059391.jpg To make your Pocket PC a WLAN device, you need:
  • To purchase a WLAN CF or SDIO expansion card
  • To have access to a wireless network
Dec 29, 2007 | HP iPAQ H2215 Pocket PC
Cannot see any SD card in expansion slot
The first thing to try is a soft reset while the card is inserted.
Sep 11, 2005 | HP iPAQ H2210 Pocket PC
Expansion card doesn't stay in.
Problems inserting expansion cards, or keeping them in your device, may have a simple solution. Try these first: * Make sure the expansion card is facing the correct way. See the handbook for your device for illustrations. * Expansion cards do not fit into the slot if not oriented properly. If a MultiMediaCard (MMC) slides all the way through, it does not operate correctly. Make sure to fit cards carefully in the slot. * The mechanism of the expansion slot is called "push-push." Much like a glass cabinet door, you push to insert the card, and then push it in again to get the mechanism to release. Expansion cards do not need to be forced out of the expansion slot. * Though most expansion cards are notched at the top for removal with a fingernail or other such object, removing the card this away may damage the mechanism. Use an object only when a push fails to release the card. Please be aware that you could damage your handheld if you remove a card improperly, or insert objects other than expansion cards into the slot. * Expansion slots damaged by forced removal of the card do not release the card when pushed, and could refuse to ?lock? the card in the slot. Expansion slot damage can only be repaired by having the entire handheld serviced. * Some expansion cards labeled as SD or MMC do not actually conform to the SD or MMC specification.
Sep 07, 2005 | Palm Tungsten T5 - Multilingual Handheld
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
