Question about Epson Printer
How do I print on tracing paper using my SX515? It cannot recognise this thin and almost transparent paper.
ginko
  • 19396 Answers
SOURCE: Pixma MP210 printing on transparency paper.
You need to chose photo/glossy
Posted on Apr 11, 2008
  • 144 Answers
SOURCE: How do I print with transparent paper?
make sure you are using transparencies made for your type of printer. eg:...DO NOT use laser transparencies on an inkjet. and visa versa...
You dont say what kind of printer you have so I cant help too much. Let me know what type of printer you have....make ..model...etc...
and what software you are using.
rick
Posted on Feb 16, 2009
SOURCE: Hi, i would like to print on Transparency paper,
Hi
First of all, are you working with a laser printer or inkjet? if it is laser make sure that you have the correct transparency, IT MUST BE HEAT RESISTANT! if it is not,u'll end up buying a new fuser unit. then...
1. Put the transparency in your MP tray
2. When selecting "print" click on properties and select your MP tray as your source,
3. Select Transparency for you media type.
after doing this you will be able to print your transparencies.
I hope it helps
Kind regards
Yolande
Posted on Mar 04, 2009
wrinaldo
  • 185 Answers
SOURCE: Xerox phaser 7700 paper feed transparency errors
There is a Transparency sensor (called the OHP) which is part of the Registration Transport 116-1164-00
Clean it first. Or replace the whole assembly
Whit
Item, Inc.
Posted on Aug 10, 2010
SOURCE: keeps saying paper jamed when I try to print
On the Epson website it is confirmed that the Epson WorkForce 610 will not recognize transparency media. It is just the way the printer works; if it can see through the media, it doesn't think it's there.
However.....you can tape a sheet of white paper to the non-printable side of the transparency, and it prints just fine. I put two strips of scotch tape on either side, top and bottom. Works great. It's kind of a hassle, but better than not being able to print transparencies at all!
Posted on Jan 09, 2011
Can i print onto Transparency film from my Canon MG 6150 as there is no setting for transparencies, what paper setting would i use
Try the setting for glossy photo media. You want a minimum of ink. Also use the transparency media intended for ink jet AND observe the correct side to be printed on.
Jun 08, 2011 | Canon MG6150 Printer
Xerox phaser 7400DN jabs at fuser
The printer trays accommodate most sizes and types of paper, transparencies, or other
specialty media. Follow these guidelines when loading paper and media in the trays:
- Envelopes, labels, and glossy paper can be printed from Tray 1 (MPT) only.
- Transparencies and custom size paper can be printed from Tray 1 (MPT) and Tray 2.
- Fan paper, transparencies, and labels prior to loading them in the tray.
- Use only paper envelopes. All envelopes should be printed single-sided only. Some
wrinkling and embossing may occur when printing envelopes.
- Do not overload the paper trays.
- Adjust the paper guides to fit the paper size.
- If excessive jams occur, use paper or other media from a new package.
Mar 06, 2011 | Xerox Phaser 7400DN Laser Printer
I have a lasser printer CANON LBP-5200 can I to print on photografic paper?, how many gr.?
Are you saying photographic paper or do you mean photoprint paper?
Yes, laser printer print just fine on photoprint paper. I use 20 lb or 22 lb bond. 18lb is a little light and is not usually photoprint.
If you mean overhead transparency, you have to try it. On some units the overhead transparency will melt a bit and wrinkle. You may need to try different makes of transparency. Make sure it says OK for laser printers!
Apr 17, 2010 | Office Equipment & Supplies
Ink flakes off envelopes. No problems with sheets of laser paper.
High burnier:
Try these settings.
FUSER MODES
PLAIN
PREPRINTED
LETTERHEAD
TRANSPARENCY
PREPUNCHED
LABELS
BOND
RECYCLED
COLOR
CARDSTOCK>164 G/M2
ROUGH
[Paper Type]=
NORMAL
LOW
HIGH1
HIGH2
ENVELOPE
RESTORE MODES
Use this item to configures the fuser mode associated
with each media type.
Change the fuser mode only if you are experiencing
problems printing on certain types of media. After you
select a type of paper, you can select a fuser mode
that is available for that type. The available selections
might include some or all of the following modes:
NORMAL: Used for most types of paper.
HIGH 1: Used for rough paper.
LOW: Used for transparencies.
HIGH 2: Used for paper that has a special or rough
finish.
The default fuser mode is NORMAL for all print media
types except transparencies (LOW), and rough paper
(HIGH 1).
CAUTION
Do not change the fuser mode for transparencies.
Failure to use the LOW setting while printing
transparencies can result in permanent damage to
the printer and fuser. Always select Transparencies
as the Type in the printer driver and set the tray type
at the printer control panel to TRANSPARENCY.
When selected, RESTORE MODES resets the fuser mode
for each media type back to its default setting.
Hope this helps
May 24, 2009 | HP LaserJet 4300n Printer
Can the Canon MX310 print on transparencies?
Manual does not mention Transparencies.
Manual states that It will print T-shirt transfers:
T-Shirt Transfers TR-301
This paper is used to create iron-on transfers. The image is printed inverted.
Paper Support Load Limit: 1 sheet
Paper Output Tray Load Limit:
We recommend that you remove the previously printed sheet from the Paper Output Tray before continuously printing to avoid blurs and discoloration.
Paper Thickness Lever: Right
Media Type:
Printer Driver Setting: T-Shirt Transfers
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 16, 2009 | Canon PIXMA MX310 All-In-One Printer
Whit
Item, Inc.
Mar 24, 2009 | Xerox Phaser 7700DN Laser Printer
Hi, I would like to print on Transparency paper, but it will not allow me, what am I doing incorrect please . does it go into the photo tray or paper Tray ? Regards Ellen
Hi
I hope it helps
Kind regards
Yolande
Mar 04, 2009 | HP Photosmart C7180 All-In-One InkJet...
rick
Feb 16, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Print cartridge Carriage Jam how do I fix?
Sometimes this is simply an unseated ink cartridge, or a dirty cartridge guide. Check for both of these. Use a lent free cloth to wipe the cartridge guide - its generally a thin transparent plastic that runs along the cartridge track.
Jun 12, 2008 | Office Equipment & Supplies
Color transparencies are dark & poor color
Nice printer.. Hope this will give hints. Considering transparency papers, please try another batch of or a piece of transparency paper. Try to adjust also the graphics preferences (dark to light) aside from transparency paper selection. Have a nice day.
Best regards,
Rosener Guyano
Feb 17, 2008 | Epson ACULASER CX11NF All-In-One Printer
Epson Printer Logo
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
