Question about Brother VX1435 Mechanical Sewing Machine
My bobbin and needle wont connect---thread won't grab the bobbin thread-----vx11200
  • 9 Answers
SOURCE: The needle will not grab the bobbin thread
Double check the needle position when you put your new needle in. It is so easy to put them in backwards or sideways when learning a new machine. Also try checking the thread path of the thread, that it is not wrapped funny.
Posted on Jul 17, 2009
Zenqi
  • 208 Answers
SOURCE: needle not grabbing the thread
Place a new needle in the machine with the flat side to the back.
Raise the presser foot.
Turn the handwheel until the take-up lever is at it's highest position.
Set the top tension to 5.
Re-thread the machine.
Posted on Oct 01, 2009
  • 40 Answers
SOURCE: thread is tangling on the lower bobbin
check the needle first.Bent or spurred needles will result in this action.
Posted on Jun 01, 2010
SOURCE: Top threaded needle will not
you might check your needle to see if it's bent
check in the bobbin area for any lint or loose threads
make sure there is a bobbin tail at least 2 to 4 inches long
hold the top thread tail ( at least 2-3 inch tail) as the needle goes down
to pick up the bobbin thread
Posted on Aug 04, 2010
SOURCE: I had to change my
does the needle have a flat side to it? if it does try putting the flat side to the back of the machine & see if it will work that way
Posted on Sep 07, 2011
Consew 206rb bobbin won't loop and grab needle thread
the needle thread should form the loop which is grabbed by the hook. before getting too involved with timing etc, clean bobbin area a fit a new needle
Feb 02, 2014 | Sewing Machines
My needle won't grab the bobbin thread
Please put on correct size needle. And check the tension & timings.
Jan 02, 2014 | New Home HF-106
The bobbin thread wont come up when lowering the needle
The bottom thread won't come up?
Make sure you:
-Have the top threaded and through the eye of the needle (Basics are best to check, I've missed it once or twice! lol)
-Are holding the tail of the top thread when you lower your needle and pull it back up (Hold it too tight though, and it might not grab)
-Have an inch or two of "tail" or extra thread for the needle to grab on your bobbin thread (sometimes it won't grab if there's not much there)
-Have all your lower pieces in and secure. (Mine tend to jump around if I'm not putting 'em in right)
If it's still not grabbing, I'm not sure. Sorry, hope it helps.
Aug 21, 2011 | Brother LS-2125 Mechanical Sewing Machine
My needle does not pick up the bobbin thread. I double checked that I threaded the needle correctly and the bobbin seems to be in the right position. The needle doesn't look like it's making contact with...
Make sure that you have the needle's flat side facing the rear of the machine, or else it will never grab the thread. Also, make sure you hold the top thread in your left hand until it grabs the thread and you pull the bobbin thread up
Sep 07, 2010 | Euro-Pro Shark 60 - 384
Needle won't grab thread from bobbin
Sometimes you have inserted the needle wrong, make sure that the needle faces the rear, if that is not it, try a new needle. Make sure that you have threaded the bobbin right, by your manual, and have at least a 6 inch tail, hold your top thread and move your handwheel towards you, not away from you and it will grab the thread. If any questions go to euro-pro.com
Sep 06, 2010 | Euro-Pro 9130 Sewing Machine
Brother VX 1100 will not pick up bobbin thread...have cleaned and oiled machine and replaced bobbin case, could it be timing? It sure looks like it wants to work but just wont grab the bobbin thread.......
Replace the new needle, making sure the flat side is to the back of the machine.
Hold on to the top thread as the needle lowers and raises.
If it does not catch the bobbin thread, the timing may need adjusted.
You can find a graphic for adjusting the timing at sewusa.com, or take the machine in for service.
Mar 10, 2010 | Brother Sewing Machines
Needle not grabbing the thread
Sep 30, 2009 | Brother LS-2125 Mechanical Sewing Machine
Top & bobbin thread will not sew
Most likely the needle is in backwards. Weird I know, I have no idea why but if the needle is in wrong, it either hits the bobbin and breaks or won't grab the thread at all. Good luck.
Jan 06, 2009 | Brother LS-1520 Mechanical Sewing Machine
Needle won't grab bobbin thread
Check the position of the needle. Some machines have to have the needle in a certain way or they won't pick up the thread from the bobbin. Make sure the screw on the bobbin is tight but not to tight you may have to adjust it a few times to get it where it needs to be. Also make sure the bobbin is wound tight
Jun 17, 2008 | Kenmore 15208 Mechanical Sewing Machine
Machine wont pick up bobbin thread
needle won't pick up thread I think the timing is off, how do I retime it?
Aug 25, 2007 | Kenmore Drop-In Bobbin 16231 Mechanical...
Brother VX1435 Mechanical Sewing Machine Logo
71 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
