Question about Saeco Magic De Luxe Espresso Machine
I have Saeco Magic Delux SUP012, it stopped in mid cycle of preparing two small coffees and the red light came on the display (1st one on left) It seems to me that the motor may have seized. I have talked to a Saeco service agent who put me through steps of reseting it. This has not worked, any support on this would be greatly appreciated.
  • 515 Answers
Check so everthing is fitting to place like brewunit, degdrawer and driptray
Posted on Jul 11, 2008
  • simonmc01
    simonmc01 Feb 12, 2012
    I have exactly the same problem, have refitted everything, still no solution ?
Re Saeco Magic Comfort+ coffee maker - machine notes that there are no beans in chamber when there are, and the grinding mechanism runs at about half the usual sound. I've removed the screws and clean
If the machine at some predetermined time is not filled with ground coffee a volumetric container it stops.
1. Check if the knives rotating.
2. Look if the ground coffee falls in grup while it is milling. If you left the volumetric tank open.
3.Maybe the knives mechanism is not at the right possition.
Nov 14, 2014 | Saeco Coffee Makers & Espresso Machines
Panel won't light on Saeco Magic Delux
Sounds like a board issue. It was something that happened on the Saeco Magic Deluxe's enough to be noticed. The board is not available for magic deluxe's with oval buttons.
Parts for your magic deluxe
May 29, 2011 | Saeco Magic De Luxe Espresso Machine
Saeco coffee machine
make sure that the brew group and door are close or dump box ect
Jul 08, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco Magic Deluxe resets itself before completing brew cycle
Hi Try reprogramming the machine. Push and hold the button for the coffee you want, but hold it all the way through the process. Don't release the button until you get the amount of coffee you want for that button, then release the button. That should get you the same amount next time. You can do this for each coffee button. If that doesn't fix it, then you might need a new flow meter.
Jun 12, 2009 | Saeco Magic De Luxe Espresso Machine
Magic Delux - Not heating
try to descale your machine to see if it helps.
Aug 24, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Magic delux trip
your load is too high. try reducing it
Aug 20, 2008 | Saeco Magic De Luxe Espresso Machine
Brewing stops mid cycle
Sounds like dosage is too high and grind is too fine.
Rule of thumb with any saeco unit.
Do not grind any finer then 2 or your looking for trouble.
Open grinder, clean it out with a vac. Slapped it back on.
The reason it stops is grind is too fine, and the machine doesn't have enough pressure to pass threw the grinds, creates back pressure in the machine and the unit failsafes after a certain amount of time with and pressure.
Back pressure is what blew your boiler.
May 16, 2008 | Saeco Magic De Luxe Espresso Machine
Filter in saeco magic delux
little magnet keeps that red light from coming on.
magnets probably gone bad, need to buy a new water tank. As far as i know saeco does not sell the magnets seperate.
could also be a blockage sending the machine into alarm.
May 08, 2008 | Saeco Magic De Luxe Espresso Machine
Stops Mid Brew Cycle - Saeco Magic De Luxe
Hi
I would try to reprogram the button. Push and hold the button. Keep it held down while it is grinding. Don't release the button until you have the desired amount in your cup for that button. When you do, Then release the button. See if that doesn't clear the problem.
Apr 05, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
194 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
