Question about Husqvarna Craftsman 36cc, 16 In. Gas Chain Saw
I just replaced the cylinder and piston on a 55 husqvarna. starts and sounds good but does not have the power it should when cutting. I played with the high needle and turned it all the way counter clock wise and it seemed to be getting a little better, but just not right.
  • Husqvarna Master
  • 2,239 Answers
Just a thought, there is a small green impulse seal in the cylinder, it sits just below the main induction rubber, did you remember to re fit the seal in the new cylinder? or has it split when re assembling the carb plate
Posted on Jan 04, 2011
    Brigadier General:
  • 4,088 Answers
Check the fuel filter, air cleaner and muffler for plugging. Check the fuel lines for decay or other damage. Did you use a fresh gasket on the lower part of the cylinder and the carburetor? You may need to clean the interior of the carburetor with spray carburetor cleaner. Also, check the condition of the lower chamber diaphragm for hardness or cracking--check the needle valve that it controls too. Correct adjustment of the H jet needle is when the engine is running at speed unloaded, it is 4-stroking, but immediately 2-strokes when cutting. Make sure the bar and chain are being oiled properly by running the bar tip at speed near some cardboard--it should throw off a thin line of oil. Hope this helps!
Posted on Dec 30, 2010
Saw starts, but why does it run few seconds then quit?
Has it enough compression ? because i have the experience it have a questionable closing system for carburetor air filter it is not always fully locked take care to close it replace parts if its not as soon as this problem is there or its to late , on the way it should but when it is not good closed it leaks in much cases and the piston had often grooves by polution from graveldust it can have lost compression by it first to do is control the piston.
In the event that all of this is not the subject the tank airiation and fuelhoses to control.
51MM Cylinder Piston Kit For HUSQVARNA PARTNER K750 K760 REP 506 38 61 71
Feb 11, 2016 | Husqvarna K760 Cut-off Saw,2-cycle...
Husqvarna 55 rancher chainsaw acts like it is locked up, remove the spark plug and it spins fine. what is the problem?
That sounds like normal compression. By removing the spark plug you are eliminating the compression in the cylinder therefore it will turn freely. Doesn't sound like a problem.
However, check that it is the right spark plug for the saw. If it is too long then it may enter the cylinder too far and be acting like a piston stop.
Mar 16, 2013 | Husqvarna Garden
I have a husqvarna partner K960 concrete saw that the skirt of the piston on the exhaust side has shattered, there is no scoring in the bore, the actually sides of the piston above the damage has no...
If the piston is working in the cylinder properly, that part of the piston shouldn't be making contact with the cylinder wall so lubrication shouldn't contribute to its demise unless it was bad enough to lead to enough heat buildup to cause the failure. It is most likely the metal was weak in a way or spot that the force of the piston going up and down was enough for the metal to finally fail. Of course the faster the motor is turning the higher those forces are so over reving the motor could certainly lead to this type of failure.
Sep 10, 2012 | Husqvarna Partner Gas Powered Cut Off Saw...
I have a scored piston in my Husqvarna 51 chainsaw. Can I hone out the cylinder and still use it?
You can do that. But it would not run as good or as long as it would buying both the piston and the cylinder housing. You either have to buy both or the try installing a new piston with new rings in it. It should give you enough compression to start it up. But it can't be guaranteed to last too long.
May 29, 2012 | Husqvarna Chain Saw Models 51, 55
My chainsaw starts and idols ok ,when I try to cut a log it bogs down and stalls off
Sounds like a carb problem. My 310 stihl did the same thing. Rebuilt the carb and now it will cut the gates of the hinges off of H**L
Sep 22, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna rancher 55 chainsaw having problem starting have spark new spark plug, plug is wet after trying to start it
You need to check that this machine is mechanically sound, remove the muffler and check the condition of the piston skirt through the open exhaust port, any signs of scuffing ( seizure ), and the cylinder will need to be removed to assess the damage
Aug 27, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
55 rancher-put new after market piston,ring and cylinder new sparkplug,cleaned carb,tried adjusting hi lo-new gas filter,new fuel line ,cleaned air filter-will start but on acelleration bogs and dies took...
I had a very similar problem with a stihl 029 farm boss.I did everything you did except I took it to a shop to do the piston and ring replacement. When I got it back the first time it would run for about two mins. then die.I fought it for a couple of weeks then took it back and expressed my displeasure. Then checked it all over and replaced piston and ring again and it runs great. They told me they could not get the right compression with the first one and thought the groove for the ring was cut to deep.I hope this is of some help to you. Thank you.
Mar 21, 2011 | Husqvarna 455 Rancher 555cc 35 hp 20"...
Saw stalled after last cut,and seems to have lost compression
Doesnt sound good, remove the two muffler screws, remove the muffler, check the condition of the piston through the exhaust port, any signs of scuffing, or piston damage and the cylinder will have to come off for possible replacement. Cylinders are very expensive so you need to consider wheather this is a viable repair.
Mar 07, 2011 | Husqvarna ChainSaw 18 in Bar 32 HP Model...
55 rancher Husqvarna got very hot due to no oil in gas, and will not start again.
The piston rings rely on the oil in the gas to lubricate the cylinder wall. More than likely, the rings are now too small to provide the proper seal for enough compression. It could also have worn the cylinder wall more than the rings, the end result is the same.
You can try to remove the plug, put in about a 1/2 teaspoon of oil into the plug opening, slowly pulll the rope 1 time to let the oil coat the ring & wall & then put the plug back in & try to start it. Use a little extra oil in your gas to provide thicker lubrication. good luck
Jan 31, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
How do I get the clutch drum off? Husky 55 Rancher
A YouTube video shows the procedure using a Husqvarna 350 here:
http://www.youtube.com/watch?v=cdqkIuVNUQc
1. I looked at IPLs for the 55 & 455 and didn't see any special tools.
2. A length of starter cord or nylon rope may be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and be cut when the piston rises.
3. It is probably a left handed thread (tighten it to loosen it).
Let us know how it worked for you. GL
Lou
It appears the 455 must be a "spur" type chain drive sprocket. the 55 offers the option of a "rim and spline" drive sprocket. If replacing the clutch drum I recommend the "rim and spline".
Sep 10, 2009 | Husqvarna Garden
Husqvarna Craftsman 36cc, 16 In. Gas Chain Saw Logo
141 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
