Question about Maytag PYE2300AY Electric Dryer
Hoy to fix my maytag PYE2300 dryer stop working. i push the start button and is does not power up... nor make any noise
    Problem Solver:
  • 6 Answers
Do you have any ticking coming from the timer control when you set the time? Be sure the dryer breaker on the breaker panel is not tripped. You may be missing one leg of your 220 volts from your breaker also. I you have a volt meter you may check to see if you have 220 in to your dyer. BE VERY CAREFUL AROUND POWER, THIS COULD INJURE OR KILL YOU IF YOU DO NOT KNOW WHAT YOU ARE DOING.
Posted on Dec 30, 2010
My maytag Neptune dryer is not working. It makes a noise when you hit the start button but doesn't start. The timer continues to go until it reaches stop. Have checked belt and it seems to be fine? Any...
I have worked at sears appliance have come across exact or similar problems. You push the button and you hear something like a loud buzzing. My experience has been that the drive motor is locked and needs replacing. Depending on the age of the dryer and the cost of a motor and installation, you might but another dryer.
Mar 03, 2015 | Maytag Neptune MDE4000 Electric Dryer
Maytag clothes dryer Model PYE 2300 AYW will not start. All elements tested okay. pye2300 AYW won't start.
Check the door switch. It might be a small button under the edge of the door. It's possible it is stuck.
Sep 26, 2013 | Maytag Clothes Dryer Almond Timer Knob...
Maytag dryer sounds like it is going to start but wont start
could be that the belt is cut off , of the the puleys are jam .. does it make a big noise ( squeeky noise
May 12, 2017 | Maytag PYE2300AY Electric Dryer
My maytag dryer model LDE7304ADE stopped working. I stopped it mid-way through, closed the door, pushed the "on" button and it made a weird noise. I tried again and now it doesn't make any...
Door switch broke???
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 27, 2010 | Maytag Dryers
My Maytag dryer model pye2300 stopped working one day randomly. I know its not a fuse issue to the 220 outlet in the house, because I tested the oulet, and the drier still is receiving electricity, because...
The timer on your dryer is more than likely bad. You already know what the timer is and where located. Not really that high priced thru ebay or an appliance repair outlet. Usually just a screwdriver and a small socket is all you need to change. Great sense of accomplishment when you finish and it works while saving a lot of $$$$. Stan
Apr 02, 2017 | Maytag PYE2300AY Electric Dryer
Maytage neptune dryer wont start
heatman101
Feb 24, 2010 | Maytag Neptune MDE5500AY Electric Dryer
I have a Maytag PYE2300AYW. Push button but nothing happens. Had breakers to house checked and all good.
Dryer suddenly stop working when pushing start button (knob will make a humming or ticking kind of noise but won't turn on. I cleaned and check the outside exhaust and lint screen passage. Nothing is helping. help
Jan 08, 2010 | Maytag PYE2300AY Electric Dryer
Maytag PYE2300 AZE electric dryer
Unplug the cord of the dryer before starting.
Raise top by placing a putty knife between top and front in the seam between the two about 2 inches in from each edge and lifting up at the same time. Raise top to full open position.
Look down inside the open top dryer at each side there will be a screw on each side a few inches down. Leaning against the front remove the two screw and pull the top forward a few inches and raise it from the supports at bottom then swing it aside protecting any wiring.
This will give you access to the underside of the dryer.
Reverse the disassembly process to reassemble the front and top being careful not to disconnect any wiring.
Sep 19, 2009 | Maytag Dryers
Kenmore dryer start button not working
when I push the start button on my kenmore dryer it will not start and the drum will not turn.
Nov 09, 2008 | Dryers
Kenmore dryer stopped working, start button does nothing
hi thanks for the question i would check the thermal fuse at the back remove back panel . by the air duct theres a small thermal fuse with 2 smaller blue wires to it check that it does cause this thanks appliance doc
Sep 13, 2008 | Maytag PYE2300AY Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
99 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
