Question about Whirlpool SF379LEKS Gas Kitchen Range
I have a Whirlpool Gas Range Model #SF379LEKS that keeps turning itself off/down. It doesn't always happen but enough that I can't rely on it! If I try to re-start it, you can hear it trying to ignite but after a couple clicks...it just stops. Do you know what part can be replaced to fix this? When I remove the bottom panel and heat shield above the bottom burner it operates fine. Thanks!
  • palms00 Dec 31, 2010
    The burner ignites perfect when the bottom panel and heat shield are removed. If the ignitor was bad then why does it ignite with cover and shield off?
  • 1,998 Answers
This is because you are letting more air into the unit try this take a voltage regulator or a multimeter and set them to read amperes clip around one of the wires going to the ignitor should be reading in between 3-3.3 amps any less then this and it wouldnt light the oven in time when the gas is coming out of the these are also noted on these diagrams as part number 16 oven ignitor in which you have two inside your unit so you would need to test both of them and part number 14 the oen burner you would want to take these out and clean with a wire brush to assure that each small gas opening is open and there are no deposits left in any hole of the burner if you have any further questions please message me back and please remember when this chat is concluded to rank how this opinion has helped in your appliance situation and have a Happy New Year Thanks again
Rick
1st link is so you can get an idea of what sears charges http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Range-Parts/Model-SF379LEKS2/1198/0124002/W0319142/00003?blt=06&prst=&shdMod=
2nd link is your diagram http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fW0319142-00003.png
and lastly if you need to order any parts i would suggest you go to www.marcone.com under contact us there is a 1800 number as well as an overseas number if you happen to be overseas this is the cheapest and largest appliance parts company in the world I only give plugs for them because there alot cheaper and saves the customers $$$$ Remember any further questions to message me back
Posted on Dec 31, 2010
  • Rick Ead
    Rick Ead Jan 05, 2011
    because with the heat shield off the oven is getting more oxygen inside more air allows the ingitor to light do the ampere test on the ingitor message me back with your finds remember 3-3.3 amps is what it should draw any less and it would take longer Thanks again
    Rick
    p.s its probably around 2.7- 2.8 which constitutes a weak ingitor
  • 2,382 Answers
Hi, if this is a gas range, then the odds are your electronic ignitor is shot. It may glow for a while, which is where you'll pick up some small amount of heat, but it's not allowing the proper voltage to pass so the gas safety valve can open and allow the burner to light. The igniter will have to be replaced, either by you or a tech.
If it's an electric range, then there's a problem with the thermocouple connected to the heat control knob. The thermocouple senses the amount of heat in the oven and regulates it by turning the element power on or off. If the elements heat at all, then they're ok. If they were shot or open, as we say, then there would be no heat at all.
Posted on Dec 30, 2010
Dryer hot at first and then stay cold
Sounds like the thermocouple needs replaced. When ever the couple doesn't make enough electricity the gas valve is shut down automatically. Sounds like your thermocouple is right at the threshold of minimum voltage and doesn't generate enough voltage to keep valve open.
If not that try YouTube for some good diagnostic videos:
https://www.youtube.com/results?search_query=Whirlpool+gas+dryer+pilot+light+goes+out+quickly+or+doesn%27t+stay+on
Oct 28, 2015 | Whirlpool Dryers
LP gas stove top . burners want turn down to low. Only medium and high flame work on burners.
Has this just recently happened? Check the knobs aren't cracked sometimes the brass spindle inside the knob is not gripping to turn it right down, also check your l p gas pressure it should be 2.75 kpa.
if the flames are big and yellow it's getting too much gas, not enough air.
Mar 13, 2014 | Whirlpool WFG231LVB Freestanding Gas Range...
Our Whirlpool just started showing the following
E2 F1 - UL A/D error(s)
1. Disconnect power longer than 30 seconds.
2. Re-apply power and observe for longer than 1 minute.
3. If failure remains, disconnect power, replace control.
Here's parts diagram for your model:
SF379LEKS2
Diagram#2 Part location#12 is your electronic control that you can order if you need to.
May 16, 2010 | Whirlpool SF379LEKS Gas Kitchen Range
When dial of oven is turned on, nothing happens.
Have you checked the pilots for the oven? If the pilots are lit and it still isn't working then the problem may be the gas valve.
Mar 06, 2010 | Whirlpool SF310PEK Gas Kitchen Range
Error message when trying to use oven. E2 F1
Here’s a simple explanation of what’s going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn’t high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn’t happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you’re gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
–don’t spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
(from tip by JSRock)
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 01, 2010 | Whirlpool SF379LEKS Gas Kitchen Range
Stove bunners flame are to low?
take the knob off, insert a small flat head screwdriver into the shaft and turn slowly
Jul 20, 2009 | Whirlpool GS460 Gas Kitchen Range
Oven won't turn off
My gas oven won't stay off. It feel like it's on, always warm.
Jan 05, 2009 | Whirlpool SF379LEKS Gas Kitchen Range
Extended warranty
Greetings abdilhaqq,
If you are a Best Buy™ customer, you can contact 1-888-BESTBUY and have a copy sent to you. Otherwise you would need to contact your manufacturer for a copy of your warranty.
I hope this helps!
Dorothy
Go Ahead. Use Us.
Jun 11, 2008 | Whirlpool SF379LEKS Gas Kitchen Range
Re:Whirlpool SF310PKE gas range
When the oven safety valve refuses to open and let gas through, it's almost always because not enough current is flowing through the ignitor. Often an aging ignitor will appear to be glowing pretty brightly but still won't draw enough current to make the valve open. The first thing to try replacing is the ignitor.
You describe your ignitor as "red and glowing" but oven ignitors normally get a lot brighter than "red" -- well into what I'd call yellow.
Dec 19, 2007 | Whirlpool SF310PEK Gas Kitchen Range
Whirlpool SF379LEKS Gas Kitchen Range Logo
201 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
