Question about GE Ovens
It quite working can;t find the fuses - GE Ovens
  • 65 Answers
  • ok who brought if you did bring it back
Posted on Dec 30, 2010
RBD245PD fuse?
No I think the power surge has destroyed the main control board.
Oct 10, 2016 | Ovens
Problem start when i turn Oven only on teka, then the fuses blown up. I can still use grill but whwn I turn to oven fuses go blow up again.
Hi! It seems it is not the heating element! It seems to be before that. Either a short circuit delivering to much current thus causing the blow. I would check the corresponding cable all the way to the circuit and the circuit elements corresponding to the oven element. The grill and oven elements being "independent" explains why grill still works. (A short circuit seems quite possible to me!)
Dec 06, 2014 | Ovens
Frigidaire gallery series oven
Check your bottom element with ohm meter.
Oct 10, 2013 | Ovens
Panasonic micro wave stopped working after a lightning bolt hit near the house
If you remove the cover assy you will see a fuse somewhere. It is pbobably blown. Be careful with microwaves as they can give off quite a shock even when unpluged. If you keep your hands away from the magnatron you shouldn't have a problem. If you just change the fuse you won't have a problem. The hi voltage cage is toward the back
Aug 03, 2011 | Ovens
Alright, heres my problem. My double oven quit working during a self clean cycle, I replace the fuse and the circuit board and it now has power to the circuit board but now the only burner that comes on is...
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 24, 2010 | Whirlpool RBD305PD Electric Double Oven
Bottom coil does not heat. Top coil for broiling works ok
Check your fuses - both on the oven and in your breaker box.
Most likely the bottom coil has quit. Replacement is usually quite easy.
With the power off - you remove the screws at the back of the coil and disconnect the power lines. Bring to appliance center and they can match size/shape.
Dec 02, 2009 | Maytag Ovens
Bottom element not heating
DEPENDING ON USE WITHIN THAT YEAR IT MIGHT NEED REPLACING AS IT COULD HAVE BURNT OUT.
Oct 13, 2009 | Ovens
Oven elements suddenly quit
check your power supply for 240volts, at your service panel and have it checked at the range thats the easiest step to start with and if both elements are that way thats what it sounds like now,theres no internal fuse I know about.
Jul 23, 2009 | Frigidaire FEB24S2AS / FEB24S2AB Electric...
Stove don't work at all
CHECK THE POWER IN THE WALL MAY BE BURNT
Apr 27, 2009 | Ovens
Ovens Logo
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
