Question about Coby 5.1 Channel DVD Player with Home Theater Speaker System System
I have a Coby dvd 505 home theater system and it's playing dvd's only in black and white Any suggestions?
  • Coby Master
  • 5,103 Answers
There are a few possibilities. 1) You have the system on wrong broadcast system. Press the TV.Sys button on the remote. (In the US, you need the NTSC (analog) broadcast for older TVs). If you have lost the original remote, you need a replacement that matches the feature. See http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=12937326385240&smodel=DVD505&brand_pn=COBY_DVD505 for a substitute remote. 2) You have mismatched cables/inputs.
For the second issue, a composite video cable could be connected to a component video input. If both devices have component video, get a component video cable (red, blue and green for the video, separate red/white cable for audio); it isn't included with the player. Otherwise connect to the composite (AV) connections on the TV (yellow for video, red/white for audio).
If needed, you can reset the player as follows:
****RESET THE DVD PLAYER BACK TO THE DEFAULT SETTING***
1) Open the DVD tray.
2) Press the "Setup" button.
3) On the "Down" arrow, press it three times.
4) On the "Right' arrow, press it once.
5) On the "Down" arrow, press it three times
6) On the "Right" arrow, press it once, then press "Play/Sel" button.
7) Press the Setup button to exit.
*The default setting will take affect as soon as you press the setup button (step 6).
I hope this helps.
Posted on Dec 30, 2010
Will only play DVDs in Black and White
Onkyo DV-CP706B 6-Disc DVD Player (Black) - Amazon.com
www.amazon.com/Onkyo...Player-Black/.../B001AMS...
Amazon.com, Inc.Color: BlackChange .... It's quieter than it was before, and it plays ALL DVDs, even if you can see some visible damage ..... THere was no color-just black & white.
Onkyo dvd player no color only black white Questions ...
www.fixya.com > Forum > Tags > dvd player no color only black white
Onkyo dvd player no color only black white related problems. Ask your Onkyo dvd player no color only black white questions. Get free help, advice & support ...
Onkyo dvd player plays black white Questions & Answer
Dec 29, 2015 | Onkyo Dr-s2.2 5.1 Dvd Home Theater...
Coby DVD968 surround sound w/TV
you have to check to see if your TV also has "AUDIO OUTPUT" ports, they would be red/white (not next to a yellow - those are inputs", you would hook up red/white from back of the TV to the back of the DVD player where it is labeled "input", you then turn on the dvd player and press the 'source' button to switch it to the right input for your connection. P.S. - it will only do the front two speakers because your tv only outputs 2 channel audio.
May 19, 2013 | Coby DVD968 Theater System
How do i hook up a rca Rtd325w dvd home theater to a coby tft lcd flatscreen
You can use either the multi pin connector cable, or plug the white, yellow and red cables to the TV set at the DVD player input or "Video 1" and the the audio output of the TV Another red and white set of RCA cables into the audio input of the home theater. This way the TV can play through the home theater system when you are watching cable or over the air.
If you do not want to hear the TV audio, you should go to the audio properties and select "external speaker system" but if you do this the home theater system must be on to hear any audio from the set until you set it back to the TV speakers through the TV's setup menus again.
Apr 03, 2012 | RCA Audio Players & Recorders
I have a Coby DVD938 dvd player. I have sound and picture but the color on the picture is only in black and white. How do I fix this?
Make sure the video connections are in the correct ports If they are, get to the screen with the coby logo, make sure no disk is in the tray and reset the DVD player with remote:
Make sure you do not have a disk in the tray. Using the DVD player remote control:
  1. Press 'Setup'
  2. Press the right arrow 4 times
  3. Press the down arrow 7 times
  4. Press Enter
Jul 16, 2011 | Coby DVD938 Theater System
When i play dvd the picture is black and white
If you are using component cables red green blue amke sure they are all properly connected and secure. A misconnection will definately cause the picture to be black and white.
Mar 14, 2011 | Samsung Ht-c550 5.1 Dvd Home Theater...
How to avoid black & white pictures.
Check the connections on your cables, you may have the composite and component cables mixed up. Use either JUST the yellow (composite) or JUST the component (Green/Red/Blue) and you should be good. Don't forget you still need the red/white for audio.
Hope this helps,
Cheers
Jan 23, 2010 | Coby DVD-937 5.1 Channel DVD...
Bose lifestyles v28 plays dvds in black and white
Check your video output settings in the menu. If you are using a composite video output and do not have the system sut up for it, you will get a B&W picture. Check your menu settings.
Aug 19, 2009 | Bose Lifestyle 28 System
I can't get my coby DVD 937 to play sound while watching tv. It works fine while playing a DVD or CD????
there should be an input line of just audio cable hookups (one red and one white) that you have to run and an output cable from your tv audio output of just red and white. make sure the tv says output or line out and the surround sound system says input or line in
May 05, 2009 | Coby DVD-937 5.1 Channel DVD...
Black and white
Unplug the home theater for about 2 minutes, and see if the default color has been reset once you replug it.
Mar 23, 2009 | Philips HTS3410D/37 700W DVD Home Theater...
Coby dvd 755 home theatre system hook to directv
The composite output (red, white and yellow) on the directv receiver should connect to the audio in (red and white) on the coby ht system. Then you have to select the correct input on the coby til you here the audio from the DTV receiver
Feb 10, 2008 | Coby DVD-755 System
Coby 5.1 Channel DVD Player with Home Theater Speaker System System Logo
218 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
