Question about Cell Phones
How do you do a hard reset on an LG Remarq (LN-240) with a pin enabled phone?: Is there a way to override & bypass the pin?
3 Suggested Answers
Sheikhtijani
  • 1284 Answers
SOURCE: I enabled pin # security on my LG cg225 but used
It's free of charge to request for your puk code from your service provider because they are the only one that can provide you such information. If you can't make a call from your phone, make use of someone else phone and call the customer service center to request for it.
Posted on Jan 11, 2010
Testimonial: "Thank you for your time to solve my problem."
diodeic
  • 1622 Answers
SOURCE: I have an LG Remarq
Hi, sorry about what happened. The only way for you to bypass the lock code,is for you to go and apologise to your girl friend or second option, go through the process of contacting the service provider for help. That's the only two way to access the cell phone right now..
So choose which is easier and faster for you.. The ball is on your court..
Take care and Good luck to you..
Posted on Mar 24, 2011
My phone says I have a pin # to get in , but I did not set one, how to fix it?
Your only option here is to hard reset the device. There is no bypassing this. Keep in mind, this may trigger the Google security lock, where you will need to know the original Gmail login and password you used when you setup the phone.
How to Hard Reset the LG L34C
  1. Turn off the phone completely.
  2. Press and hold the Power button and the Volume Down Key.
  3. When you see the LG logo release the Power key, but keep pressing and holding the Volume down button until the factory data reset screen appears.
  4. Once you see the reset screen release all of the keys.
Feb 15, 2015 | Andrews 4.0" Touchscreen Cell Phone GSM,...
Tip
LG E612 Hard Reset Google Lock
With article and troubleshooting guide solution for LG E612 Hard Reset Google Lock
  • Method (1): Backup PIN & Google Account.
  • On the pattern locked screen, click on the "forgot pattern" button .
  • You will be asked to enter Backup PIN & Gmail ID & password that was being used in the phone
  • Phone will be unlocked once you have provided Backup PIN ,Google account ID and correct password.
  • Note: No user data will be erased in while resetting pattern with above method
  • Method (2) : Pattern unlock with hard reset.
  • If you do not remember Backup PIN or the Gmail ID & Password details or you has not logged in with his Gmail ID then you should perform hard reset.
  • Note:This method will erase all user data and settings from the phone. and process is irreversible.
  • Make sure phone is Powered Off.
  • Press & Hold the "Volume Down Key (V-)" and "Power button" altogether
  • As LED at the bottom of the phone lights up, Release both pressed keys (V- and Power key)
  • Just after releasing the keys, press & hold "Home" key for about two seconds.
  • The phone will turn ON & perform Factory Reset immediately.
  • Warning!During working on this trick if accidentally your handset may have dead or faulted. We are not responsible for that please read our privacy policy.
Phonetolls
http://i.fixya.nethttp://i.fixya.nethttp://i.fixya.netwrite_tip-jtiacr1a5dvtxudcpg5eyczh-3-0.jpg
on Jun 24, 2015 | Cell Phones
How do I hard reset my phone?
Have you tried this?
http://www.hardreset.info/devices/lg/lg-ln240-remarq/
Dec 02, 2014 | LG Remarq LN240
How to unlock a plum phone useing a google acount
If the phone has service you can do it by logging into your google account, provided that you have used that account on the phone previously. If not, you'll need to contact the service provider for reset instructions as each model is a bit different.
May 20, 2014 | LG Remarq LN240 rubberize Hard Plastic...
I cant load my lg remarq screenpage
Does your phone power on at all? I found out how to factory reset your device but you need to be able to get to the homescreen. (WARNING: You will loose everything saved internally in the phone. )
http://support.sprint.com/support/tutorial/Perform_a_Master_Reset_LG_Remarq/17873-101
There is no manual reset on this device that I know of.
Mar 11, 2013 | Cell Phones
Unlock comcel colombia lg
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Nov 02, 2012 | LG Sprint Remarq Ln240 Messaging Slide...
Lg500 puk unlock code
Sep 08, 2012 | LG 500g TracFone
How to delete sprint LG remarq text numbers history?
Erasing Phone Content
Use the Security menu to quickly erase all the content you have created or stored in your phone.
1.Press > Settings > Reset/Delete and enter your lock code.
2.Select Delete Stuff.
3.Highlight an option and press .
Messages to delete all messages.
Call Logs to delete all call logs.
Browser Cookies and Cache to delete the browser's cookies and cache
Mar 05, 2012 | LG Cell Phones
How can i turn off the voice command on my Lg Remarq
It is under Main Menu -> Settings & Tools -> Phone Settings -> Voice Commands -> Call Alert
Jan 17, 2011 | LG enV3 VX9200 Cell Phone
Cell Phones Logo
1,581 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
