Question about Necchi Sewing Machines
My Necchi EX1 will only sew straight and zigzag stitch... how do i switch the stitches? cant find my manual ... i've pushed the corresponding button for the stitch... but is something else i must do?
Trifect7
  • 57 Answers
SOURCE: How do I change the stiches?
You can do all of these stitches by using different combinations of your stitch selector, stitch width and stitch feed knobs, for instance, on the panel I can see on your machine:
http://www.jo-ann.com/joann/product/images/52659.jsp?CATID=cat3122&PRODID=prd11333
Stitches 1, 2 & 3 are straight stitches, centered, left and right. Really basic stuff, not different stitches at all. 4,5,6,7 & 8 are zig-zag stitches of different widths. 9 is the widest zig-zag (no. 8) on a finer stitch length, etc...
I think you should try and get an instruction manual for your machine. After a lengthy search of my usual manual sources, I've determined that that this may not be so easy. I think you should contact White on their 800 number and let them try and help you... 1-800-331-3164.
If you found this helpful, please vote generously as I receive nothing other than acknowledgement for my time.
Posted on Mar 08, 2008
bargainbox
  • 1388 Answers
SOURCE: My bottom thread is loose when sewing a straight stitch
Please TRY the solution BEFORE giving your considered rating.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
Posted on Jul 24, 2008
Zenqi
  • 208 Answers
SOURCE: singer machine needle won't do width in zigzag
It sounds like it needs lubrication on the needle bar frame and linkage.
Posted on Oct 01, 2009
  • 980 Answers
SOURCE: Kenmore 2142 sewing machine won't zigzag.
Before you put the cam in did you make sure the machine was set on straight stitch and then select zig zag?
Posted on Nov 06, 2009
SOURCE: PFAFF 362 Sewing Machine: The shift
I just fixed this on my pfaff 230-the problem is the needle position dial-the middle dial with the chrome lever on the right-has froze up .
remove the dial-it doesn't come off by the screwhead in the middle of the dial ,the screw you need to loosen is the one under the wider end of the part of the dial you hold-you will need a glasses screwdriver.
once it is off ,heat the exposed shaft with a heat gun while turning the shaft back and forth with pauses for dripping 3 in 1 oil on the shaft so the heat melts the hardened grease and draws the 3 in1 in to flush out the old grease and lube the shaft.
eventually you will be able to turn the shaft easily-then when it cools off replace the plastic dial.make sure your upper dial is on "0" there is a cam on it that will push down the other end of the chrome lever.
This will work-there is no plastic in the shaft and arm assembly to melt and you don't have to dissasemble from the top-that sucks.
Posted on Feb 04, 2010
How do I get it to sew something other than the basic straight stitch?
Your machine will have a touch screen or button to increase or decrease the stitch width. However, digital machines have to be set to the zigzag position in order for the width to take effect. On this machine the # 10 turns it on zigzag.
Aug 14, 2015 | Sewing Machines
While sawing the embroidery holder moves as well, looks like its not falling into its place correctly after embroidery, how can I fix it? Also I've self checked the machine but cant get the zi
YOUR MACHINE USES A PULSE MOTOR (SMALL MOTOR) THAT CAUSES THE NEEDLE ARM TO MOVE. IF THE MOTOR IS A PROBLEM THEN YOUR ZIGZAG STITCH AMONG OTHER STITCHES WON'T WORK. YOUR HOOP I'M NOT SURE BUT IT SOUNDS LIKE YOUR HOLDER ISN'T LOCKING WHEN YOU PUSH THE HOOPS ON. LOOK INSIDE THE HOLE WHERE YOU PUSH THE HOOP AND TOUCH ON EACH SIDE AND PLACE PRESSURE TO SEE IF THEY BOUNCE BACK. ANYWAY, YOU WILL PROBABLY NEED TO GO TO YOUR LOCAL REPAIR SHOP ON BOTH OF THESE PROBLEMS.
Nov 17, 2014 | Janome Sewing Machines
Why straight stitch will not work but zigzag and herringbone stitches work on my machine.
it sounds like the machine needs to be checked at a sewing
machine shop to see what's wrong with the cam's or gear
that makes the stitches
Aug 01, 2012 | Sewing Machines
Straight stitch works fine, but,on any size zigzag the machine skips stitches
let me ask this,,
have you tried a new needle?
is the needle inserted correctly--if there is a flat side to the needle it should be to the back of the machine & pushed up inside the needle holder as far as it will go
is it the right size needle for the fabric & thread?
if you check all these things & none of these things help then it's possible the cams or gears that do the zigzag stitch could be worn some.which means it needs to be serviced
Sep 08, 2011 | Necchi 3101 Mechanical Sewing Machine
I need to know how to make a button hole, can't find manual.
Hi there, don't know your machine but you can do a plaiin buttonhole manually.
Set machine up for zigzag stitch, needle to left side, mark out the size you need with pins or marker pen. Start at the top and set for widest zigzag with 0 length for the top bar, cannot give sizes as don't know the button you are using, about 6 stitches, set stitch width to just over half the width of top bar and length to approx 0.5. Stitch down to bottom marker and again set up ffor the wide bar, do the same amount of stitches as the top, finish with needle down at the outside edge, turn work so that you will now stitch down the other side to meet the top bar, not forgetting to adjust stitch length and width again.
Hope this helps
Ellie
Jan 09, 2011 | Necchi 3537 Mechanical Sewing Machine
I have a necchi 4595, and well I cannot figure out the straight stitch....the dial doesn't show one?
It's just in the front panel, where the drawing of all the built in stitches are, it's the drawing number eleven from the left, you'll see a zig zag (red) and a straight stitch (black) Select A group of stitches (knob with the arrow) and then select the eleventh stitch (same knob but use the dial, look the manual) and then select zero on your stitch width dial. Hope that helps :)
Apr 23, 2009 | Necchi 4595 Mechanical Sewing Machine
Necchi automatic BU supernova sewing machine
Hello! Hello!
Your machine is probably not 50 years old. I have one just like it that we purchased about 5 years ago. Necchi makes a very sturdy reliable machine. There are a couple of tricks, though. First, your bobbin thread has to turn clockwise. If it doesn't, it will either not sew, the stitch will look horrible or the thread will break. Second, threading it is pretty easy; however, I can't explain some of the parts. I would be happy to scan the diagram and e-mail it to you. E-mail: daridoll@yahoo.com. The tension should be set at 3 unless you are doing a ruffle or close zigzagging (machine applique). For applique, I find that I have to move it to 2. For ruffles or gathering, set it at 0 and your stitch width to 4. Another trick is to hold the top thread for the first 2 stitches. This alleviates a bobbin catch at the beginning. Other things you will want to know are in regard to the two knobs. One is pretty simple. It has a line that gradually increases in a zigzag. This knob basically adjusts the width of the zig zag. Obviously, for straight stitching, you would make sure the straight line is towards the top. The other knob determines the type of stitch you want to do. The red stitch options on top of the machine can be done with #1, 2, 3, 4 or 5 at the top; however, I usually use #1. The blue stitches are really fun! Simply decide which stich you want and make sure the corresponding number on the dial is turned towards the top. Also, it is very important that you adjust the other knob to the largest zigzag possible AND change the stitch length to 4. Don't pull on the fabric from behind the machine as you are sewing, because the machine will go forward and backwards while making many of these stitches. The green A, B, C on the dial are used for the automatic buttonhole feature. In order to use this, make sure you have the button hole foot. It looks like a long rectangular piece of plastic with measurements on it and hollow in the center. Not sure if that description makes sense. Anyway, the first step is "C." Make sure you begin with the button hole pressure foot measuring "0". Also, change your zigzag width to the desired width AND change the stitch length to less than 1. (You will notice that this area has a green line on it.) Begin stitching. You should be moving forward. When you have reached the desired length, make sure the needle is up, then turn the knob to "B" (sometimes I make my zigzag wider for this part), begin sewing. You should not go forward or backward. This step makes the bottom of the button hole. I only make 3 or 4 "B" stitches. When done, make sure the needle is up, adjust your zigzag back again if you changed it for B, and set it on "A". This will take you backwards. If you started your button hole with the foot on 0, it will automatically stop moving backwards when you reach 0 again. At this point make sure your needle is up again, then set the knob on "B" once more. If you adjusted B before, do it again. There you are! You can use twin needles on this machine. It also works well with a walking foot for quilting. Oh! To wind your bobbin (starting from the thread spool) you need to slide the thread under the little metal knob sticking out on top of the metal "?" right above the tension and then insert it into the hole in the bobbin spool. Push the bobbin to the right. This locks it into place. Next, hold the outer part of the flywheel (round wheel on right side of machine) while turning the inner wheel towards you. This will disengage the needle and allow the bobbin to wind. Now you can press on the "gas" and wa-laah. It will slow down and almost stop when it is completed. Cut your thread, slide the bobbin to the left to unlock, tighten the wheel and you're done. If you have any more questions, let me know. Hope this helps!
Jul 27, 2008 | Necchi 3537 Mechanical Sewing Machine
Zigzag issues
Either you have the setting on a variation of ZZ which steps forward several stitches then one to the side (ZZ), so check that first.
If you are certain it is on the correct ZZ setting, and this is a recent purchase, phone the dealer tell them the issue and arrange to take it back for them to adjust, it is almost certainly ever so slightly out of timing.
www.bargainbox.com.au
Mar 29, 2008 | Necchi 3101 Mechanical Sewing Machine
Mar 07, 2008 | White Sewing 1418 Mechanical Sewing...
Sewing Machines Logo
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
