Question about Zenith IQB64W10W 64" Rear Projection Television
We have the Zenith Inteq IQB64W10W television that was given to us from a family member. Tried hooking up the cable to the tv and it just says "no signal" in middle of screen. I have been able to hook up the tv having the cable go to our dvd layer and then hooking up the cord with three plugs (red, white, yellow) to the tv and play the tv through the dvd player. I am unable to change the channels but can through the dvd player. I would like to be able to hook the tv up correctly and have it work through the tv. I bought a remote (universal one) and can now turn the tv off and on with it, but can use nothing else with it at this time. Is there a manual or do you have the directions to hook the tv to the cable correctly and be able to use tv as I should?
techman
  • 3130 Answers
SOURCE: MY ZENITH MODEL # Z60Z83R8 BOW'S VERTICALITY
You have a problem MOST LIKLY!!, that happens to almost if, not to all projection tube sets ever made. Its the old bad convergence IC falure. It's not something you can do unless you have had exstensive electronic training and soldering skills. There are no user replaceable parts inside of this set so please call out a pro to repalce the convergence IC for yop! A repair such as this should cost around 250 to 400 bucks, depending where you live..Good Luck
Posted on Aug 04, 2006
JMuskovitz
  • 135 Answers
SOURCE: Hey
You can find the owner's manual for this set online at: http://www.zenithservice.com/gcsc/b2c/hpi/main?tc=owm.command.OwmCmd It says that the BOTTOM four connectors are: 1. S-Video IN 2. Video IN 3. Audio (Right) IN 4. Audio (Left) IN Above the Audio IN connectors are two audio OUT connectors, which you could hook to external speakers, your stereo, etc. But these are not needed for hooking up your DVD player. From your DVD player, you need to hook up either the S-Video or Video connection (Video is typically the Yellow wire), plus the Audio connections (Red and White). If your DVD player has an S-Video output, this will give you a better picture than the standard Video connection. S-Video cables have a different plug, with four or five wires in the connector, and are keyed so they only fit into the socket in one orientation. Be careful to line it up properly and not force it in the wrong way.
Posted on Feb 28, 2007
CrazyLarry
  • 173 Answers
SOURCE: Zenith 50" R56W36
maybe on your remote press menu and find converence and use the keys to move the red first over the green then move the blue over the yellow ..by standing back and just using the remote....should end up with white lines. and dont hit that button again once set. a tech should do this quickly and charge you minium.
Posted on Aug 17, 2007
T-Mo
  • 19 Answers
SOURCE: Need code for zenith Televison
I don't know if you need the 3 or 4 digit code for your specific remote. I have found the site that provides the codes for your universal control.
http://www.jascoproducts.com/support/universal-Remote-codes.asp
Zenith HDTV
If you have a 4-digit remote, it should be 0634
If you have a 3-digit remote, it should be 634
Zenith standard TV (there's a bunch)
3-digit: 000, 001, 004, 009, 023, 038, 039, 050, 058, 059, 064, 078, 091, 111, 121, 131, 134, 135, 136, 153, 226, 227, 245, 247, 252, 266, 288, 310, 338, 358
4-digit: 0121, 0009, 0050, 0078, 0091, 0138, 0059, 0131, 0038, 0111, 0134, 0153, 0064, 0004, 0135, 0226, 0227, 0245, 0247, 0252, 0266, 0288, 0310, 0338, 0358, 0023, 0058, 0039, 0001.
I hope this helps!
T-Mo
Posted on Feb 09, 2008
  • 9 Answers
SOURCE: Zenith 44" LCD TV
The yellow spot is due to the BLUE LCD and/or lens assy cracked, reason, to much HEAT! The blue is the darkest color and hold the most heat, so it goes first, always! In some cases it’s only the lens, however most of the time LCD is damage to. Parts are available, however install and alignment is timely. Quick fix is the complete light engine, which for model# E44W46LCD is part# 3141VSN916C, which customer cost is $1,449.27, wholesale for about $1,065.21. Rebuilt, if you can find it around 850.00 to 950.00. However the rebuilt does not always look as good as factory. My advice, TRASH set. This part will fail again in about 3 to 4 years, unless you watch a lot of white video. Remember, on a black or dark picture, all three LCD are blocking 100% of the light, causing extreme heat within the light engine. It’s a bad design.
TV Tech
Posted on Aug 11, 2008
Zenith inteq iqb50m90w has no sound, hooked up cable box with component cables
To be honest I do not really understand clearly your issue so I will pose a few questions that might clear things for me up:
1. No sound from internal speakers.
2. Speakers have be checked and are not open, disconnected or switched to external or variable audio out only.
3 A DVD or similar connected to a rear video and audio input has no sound.
4. The set had sound when hooked to the bose system.
Do I understand correctly or did I miss something?
If all the above is correct the set has a audio output problem (old trick is put ear directly to a speaker and see if anything, a buzz, faint sound or nothing at all.)
Dec 04, 2012 | Zenith IQB50M90W 50" Rear Projection...
Tv has blue & yellow shadows
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 18, 2010 | Zenith IQB64W10W 64" Rear Projection...
Zenith IQB64W10W 64" power problem
Try replacing N-channel mosfet transistor 2sk2518. I had the same problem, and it worked for me. It is located on the convergence board.
Aug 10, 2008 | Zenith IQB64W10W 64" Rear Projection...
ZENITH/INTEQ MODEL IQB36B44W OWNER MANUAL
LG`s home page doesn`t show an e-mail address but heres the next best thing. 1-800-243-0000 be sure to have your model number ready when they answer, hope they still have one
Nov 27, 2007 | Zenith IQB36B44W 36" TV
Zenith inteq 60 in rear projection coolant leak
I would check with LG/Zenith on this, there was a update sent out to add a collection cup in case this would happen. If leaked on the board it would be to costly on repair with the board is still available.
Nov 10, 2007 | Zenith IQB50M90W 50" Rear Projection...
Liquid gel
Thats coolant. Thats bad.
Call a Zenith service place and ask how much to replace that gun and clean up the mess.
Nov 09, 2007 | Zenith IQB50M90W 50" Rear Projection...
Picture is off center, (skewed to the left)
I don,t have an anwser for you but if you are going to get rid of your set I would be willing to buy a board out of your set.
Nov 23, 2006 | Zenith IQB64W10W 64" Rear Projection...
IQB64W10W high-def problem
Your problem sounds like the digital board and probably was what the repair people said. I would suggest telling them about Tri-State Module, Inc in Evansville, IN. 800.203.7484. They have a good selection of modules for about any set and most are under $150.00 with the average being $100. They rebuild boards and all boards carry a 12 month warranty. You can also access them at www.tristatemodule.com. If they can't help try PTS in Bloomington Indiana. I use them for alot of replacement modules. Same deal as tristate. www.ptscorp.com
Oct 12, 2005 | Zenith IQB64W10W 64" Rear Projection...
Zenith IQB64W10W 64" Rear Projection Television Logo
64 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
