Our TV keeps shutting it self off intermittenly. Sometimes it will stay on for hours, other times it shuts itself off every few min then will run again for hours. We are selling the TV, but would like to repair it before selling it. What is the issue?
  • 29 Answers
My Samsung big screen showed the same symptoms. It ended up being two $5 resisters that burned out a very short time after purchase. My extended warranty took care of it but it took several service calls and the end solution was to replace the entire light engine.
Most of the time heat is the cause for shut down. Check the vents which allow air to circulate thru the set, also be sure the fan is working.
The first thing a repair man will do is replace the bulb. If you can do it yourself you can save some $$.
My advice is to find a good TV guy. One who's been around for a while. Sorry couldn't be more help. Good Luck!
Posted on Dec 30, 2010
My sony big screne started shutting itself off and wouldnt come back on for several hours. Then it would power up and standby flash 7 times and after a few mins the picture would be gone but the sound...
On your tv you have cooling fans on the back side you will need to check to make sure that they are running. Lay your tv on the bed take off back cover (it's not hard) and used some air-in-the- can to remove dust from the back! If you need a fan go to Partstore.com (1-866-925-PART
Jan 26, 2011 | Sony Televison & Video
Television shuts itself off
i had the same problem with my set shutting off and was told it may be the ballast so i changed that but it still would start up and shut down after a few mins, then i was asked if the bulb had been changed and i had not, so i did change the bulb and have not had it shut down yet. :) (so try a new bulb)
Jun 01, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Tv comes on then just shuts off will turn right back on
hello it sound like theres may be a dry joint probably in the power supply you would need a strong light and a magnifying glass and soldering iron and some solder
shaun
Apr 08, 2009 | Hitachi 50GX49B 50" Rear Projection...
Sony lcd projection tv repeatedly turning on & off
There are 2 primary things that can cause this problem - a bad TEMP sensor that is sensing too much heat, OR, a lamp that is going bad, which sometimes causes excessive heat before it dies. Either way, the set will shut itself off, and you can turn it back on in about 5 min or so, and it will work OK....for another period of time before it shuts off again.
You need a good TV Tech with the Sony Service Codes for your set, to come out & check your set. The Service Codes will tell him the exact problem you are having, and how many hours your set has been running. Most of the time a new bulb solves this problem, (if youe set is at least 3 years old).
Jan 17, 2009 | Hitachi 43UWX10B 43" Rear Projection...
My Panansonic TV shuts down every few minutes and the LED blinks three times
I still have that problem. I calle Mfr and also spoke to repair shops recommended by them and they said they estimate a cost of 300-400$ or so approx. I am waiting to buy a new LCD which could be few 100 more but at least dont have to live with the old one and keep spending money...
regards
Oct 07, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Maytag refrigerater
If you have an ice maker in the freezer compartment try raising the bail arm and shutting it off. It is possible that an ice maker will increase your run time.
May 16, 2008 | Maytag Refrigerators
Tv powers off after 15 mins to 2 hours
what is the model # and brand
May 02, 2008 | Televison & Video
Shuts off after 20min
found cold connection on board at tuner
Feb 14, 2008 | Televison & Video
Tv powers on, but turns off after a few min
somone with some sort of tv knowledge told me that sometimes people dont realize t but moisture builds up inside and it needs to be dried back out
Jan 28, 2008 | Televison & Video
Televison & Video Logo
153 people viewed this question
Top Televison & Video Experts
Electro Med Services...
