Question about GE GSS25LGM Side by Side Refrigerator
I ordered WR55X10656 and found existing Motherboard part # 200D2260G006 installed. Are these boards compatible? Looks like the plugs will line up but there are extra ports. also the existing Motherboard is defective there is a burnt mark on the back. Please advise. Thank you Luis
The donw side of the fridge boatside cool but the up side didn;t cold could be the fault to replace.
Thanks
Posted on Jan 06, 2011
SOUND NOT COMMING
if it has a built-in sound card, check your motherboard product name (printed name found in *********** board) then try to search and download the compatible sound card driver for your motherboard..
May 21, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
My laptop is HP Pavilion Entertainment PC.now got Windows 7 installed.sound not to be heard
Find the information about your audio, is it on the motherboard or is it through a sound card. Is *********** board / sound card compatible with windows 7? Do you have the drivers installed if they exist? If none of this is compatible you need to buy a newer windows 7 compatible sound card and install it.
djbr1ck
May 12, 2011 | Computers & Internet
Installing new MB in old case
Thank you blcos, I appreciate that.
I didn't know what level of tech/fabricator you are, and I now see you are very competent.
My two-fold proposed solution is,
A) IF, the Support Plate you have for the motherboard you have on hand, is too small in area to just rivet it to the existing metal 'Ribcage' metal frame work,
1) Cut the inner part of the existing Support Plate/Framework, so that there is a large rectangular hole in the center, leaving a 'Frame' around the edge.
The 'frame' being approximately 1 inch wide, or whatever is compatible.
(Would resemble a picture frame when done)
Leaving enough area for the new Support Plate to rivet to it.
(Pop rivet)
A minor, (Major?) problem is that the existing Support Plate would have to be removed from the 'Ribcage' frame work, in order to cut a rectangular hole in the center.
(Unless you have a large hole made, and use a metal nibbler cutter.
Example: http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=96661 )
The rivets would be drilled out, with pop rivets to reinstall.
The brass standoff's, or plastic spacers would have to be the right height, in order for the I/O ports on the motherboard to line up with the holes in the I/O Shield.
Or modifications made to them, or the I/O Shield.
The I/O Shield not only keeps dust out, and helps form a tighter seal for air flow inside the computer case, but also is a Radio Frequency interference shield.
B) Proposal 2 was to use the existing Support Plate, and mount the new Support Plate on top, with modifications to the 'Bumps' on the old Support Plate, and to the I/O Shield, and spacers used.
(Plastic spacers, or metal brass standoff's)
As you stated, flatten the Bumps down
The I/O Shield may have to have one side reduced, (Outside case edge), so that the I/O ports will line up with the holes in the I/O Shield.
The extensions, (Spacers or Standoff's), may have to be reduced in height, or substituted with a compatible item that will work, so that the I/O ports line up with the holes in the I/O Shield.
Whatever line of modification you use, I suggest that a gap be created in-between the Support Plate, and Motherboard for air flow, and also to keep the solder joints on the bottom of the motherboard, from touching the Support Plate.
If possible I would like to know how this comes out.
Regards,
joecoolvette
Feb 05, 2010 | Compaq Presario 5716 PC Desktop
Half hour after installing XP and turning off, I came back and found computer on, no video and burned out kvm switch. Now board turns on by itself when I plug in computer and there is no bios, beep, no...
Ouch. Ok first thing to do is unplug the system, clear the CMOS, and unplug the hard drives from the motherboard. plug the power back in and see if it posts. If it doesnt, pull the ram and see if it at least beeps when you turn it back on. If it deosnt beep at that point it looks like you have a dead board.
Nov 21, 2009 | Asrock K7S41GX Motherboard
I've been told my Compaq Presario f730us needs motherboard. Before I attempt to repair/replace motherboard: how do I know if the CPU is still good from old motherboard is still good? the cpu will need to...
If your PC still boots initially it means your processor is still working but if your PC is in blackout mode its possible that its your processor or your motherboard is damaged...better do a little troubleshooting first and write the detailed problem of your PC..If they suggest you changed the board it means your processor might still be working..
as long as the parts are compatible with the model of your laptop you have nothing to worry about..hope this helps..ITTech7574
Aug 28, 2009 | Compaq Presario 700 470024-192 Notebook
The line in is not working.. 2 audio connectors one internal and one external came with d tv tuner card. i did not find any port on board(DG31PR) to connect the internal connector.so i connected the...
YOUR MOTHERBOARD IS NOT FULLY UPDATED WITH TV AUDIBLE DRIVERS. GO TO YOUR NEAREST OUTLET ASK FOR A RECENT MOTHERBOARD CD MATCHING YOUR MOTHERBOARD SO THAT YOU COULD INSTALL THE NECESSARY MODULE.
HOWEVER, WAIT FOR MY TOMORROW'S ANSWERS IN ORDER TO GIVE YOU A BRIGDE OF MOTHERBOARD TO EASE THE AUDIO OUT.
THANKS
WONDER
Aug 11, 2009 | Computers & Internet
Our GE Arctica PSS27NHN has gone out. We took a look inside and found the motherboard has a burnt spot, so that is most likely our problem. Can anyone tell me if this model is on the recall list. I have...
No recall list that I know of .G E now has 2 boards available . The pt# you need is WR55X10656 . Less problems than a board for each model .
Jul 19, 2009 | Refrigerators
Ram memory upgrade not recognized in system info.
does your mother board ddr2 compatible? do you have the manual of your motherboard? because there are brands listed in your manual which are compatible. if you have an existing ddr installed temporarily uninstall this and try this ddr2 512mb alone and let it run, if a beep beep sound occurs that means this is not compatible with your computer. remove this and bring this together with your ddr that work to your supplier, ideally the cast latency timer of these should be the same including the brand. hoping that this will help you
Nov 26, 2007 | ASUS Intel 440BX Chipset P2B-S Motherboard
GE GSS25LGM Side by Side Refrigerator Logo
168 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
