Question about Kodak EasyShare V550 Digital Camera
Battery won't charge on Kodak Easyshare V550
When I plug the camera into the charger, the 4 blue lights on top blink rapidly. The lens will not open either. It did the same thing with 2 other batteries. Has anyone else had this issue?
  • 1 more comment
  • Anonymous Nov 05, 2008
    replaced battery on v550 and still wont charge lights on top start blinking but no charging
  • Anonymous Jan 29, 2009
    Please help, I have the same problem. Camera will only work in favorites mode and I just bought a new battery.
  • jphayes Apr 07, 2009
    When we attempt to recharge our V550, the four blue LEDs on top are lit, sometimes, the LED farthest to the right blinks. The camera won't power up, lens will not become extended ....the camera is only about 3 years old, and does not get heavy use in extreme environments, has never been dropped or otherwise shocked.
I don't think its the battery. My just did this this week..If I slide the Favorites switch up (switch by hand strap mounting hole) I can view the pictures in it, but it won't use in photo mode, Lens won't extend, and it shuts off?
Posted on Jul 14, 2008
Will not charge
Kodak camera wont charge? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 1, 2011 - My Kodak EasyShare M580 digital camera wont charge. I have the USB charger, but when I plug everything in, the charging light wont light up, ... Kodak Easyshare camera will not charge?
Mar 27, 2014
My kodak easyshare m580 WILL NOT charge?
Mar 14, 2012
Kodak Easyshare M580 Not Responding To Charger?
Dec 7, 2011
My kodak easyshare m580 will not charge?
Apr 16, 2011
More results from answers.yahoo.com
Nov 29, 2015 | Kodak Easyshare M580 Digital Camera
Kodak easyshare won't work unless plugged into charger
Hello Pam, You have either a faulty contact for the battery or your battery is suffering from age. After time these camera batteries lose their capacity. Try a new fully charged battery.
Best Regards, Russell
Jan 11, 2013 | Kodak EASYSHARE M340 Digital Camera
No flashing blue light when charging. Lens will not return into
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair or possible alternative a new cable.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 28, 2009 | Kodak EasyShare M1033 Digital Camera
I press the on button, the lens doesnt extend and the power shuts off
are you using the recommneded battery fro your camera KODAK Li-Ion Digital Camera Battery KLIC 7001? If yes please charged the battery for 3hrs and try to turn on the camera., if encounter same problem it means the gear lens of your V550 is already defective and needs of repair please call precision and binocular repair at 1 800 665 6515.,
Oct 31, 2009 | Kodak EasyShare V550 Digital Camera
Won't turn on after charging; lens just sticks out
Charge it again with a new batery and the 5 volt charger.
3 hours.
Vitally
Apr 21, 2009 | Kodak EASYSHARE M1063 Digital Camera
Lzoom lens goes out and in, immediately, then camera turns off
Pull the battery and plug the charger into the camera. It should turn on and take pics now. If it does, you need a new battery!
Yeah, I know, the battery shows fully charged but it's weak and old so it really doesn't have the current to drive the lens.
Try to clean the battery terminals with an abrasve pencil eraser, (old red eraser #2 pencil from grade school) and wiggle the battery in the camera (gently) to clean the terminals inside the camera.
Let the camera charge the battery completly, (not in the dock!) and see if it turns on.
If it does, you will probably find that it discharges VERY quickly.
Buy a new battery! That extra battery that you have had since you bought the camera is probably also shot! They do have a shelf life!
If the camera does not turn on with just the charger, (no battery) then it's probably a lens error, but you should see an error code if it is.
Ned
Apr 09, 2008 | Kodak EasyShare V550 Digital Camera
Kodak v550 digital camera
Hey akpssttt, I had the same problem with my kodak and even though I was able to turn on the camera, the lens would not come back in. So after awhile I just gave up took it to the repair shop and they still weren't able to fix it. So I left the camera for about a year now, gathering dust, but recently I decided to give another shot, and amazingly when I plug the camera into the charger, the lens went back in! And now the camera works perfectly.
So I would suggest you leaving your camera out for awhile and do not charge it until the batteries is completely drained. And then plug it back into the charger.
Hope this help.
Mar 24, 2008 | Kodak EasyShare V550 Digital Camera
Kodak V550 EasyShare
hmm, that happened to me too when the battery was dead. try recharging your camera. make sure it is sitting on the charging dock right. make sure the charger is plugged in and it's working. see if the battery was put in correctly. if none of this helps, try a different battery, maybe the one you bought is no good. who knows what shelflife is on those
Mar 08, 2008 | Kodak EasyShare V550 Digital Camera
Kodak Easy Share V550
mine fell in water and now the lens retracted and won't shut and i have error #45lol
try charging your camera, if it hasn't been broken from the fall, hope it had a soft landing!
Feb 25, 2008 | Kodak EasyShare V550 Digital Camera
Kodak V550 Camera Problems
Sounds like a new battery would do wonders. I would contact Kodak and see if hey will offer you a new battery. If not then I would go buy one. The battery is probably the most likely to go bad so fast on a camera.
Aug 23, 2007 | Kodak EasyShare V550 Digital Camera
Kodak EasyShare V550 Digital Camera Logo
263 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
