Sim unlock code is nothing puk code plz call up th sim service provider Nd ask for puk code tht unlocks th sim access Nd jst to make sure jst on/off th phn Nd tht code can be used whenever u forget or lock th sim
tape out from reciever to line in on the eq --then line out from the eq to tape in on the reciever --whenever the tape monitor will be used on the reciever the sound will then be equalized
try this code on your cellphone ##002# this code should cancel any call barring , and for the sms check the Service center number if is the same as the one of your provider
You need to restore factory settings of your k800i . your phone default code is 0000, go to setting then select restore setting or factory setting and enter code 0000 .
If this solution is helpful please click a thumbs-up rating below.
u can contact ur service provider an ask about prob ur r facing... te il giv u th solution for call barring prob by reseting th sim settings... so that u can recover from th prob...
ur mobile keypad might got slight damage... since it got wet.... u can go to th authorised service centre for motorola an get ur keypad service.... so that ur prob get solved..... kindly rate me .... thank you....
