Question about Dryers
I have a maytag dryer model number de303. was working fine, now it buzzes but the dryer won't turn on?
    President:
  • 1,194 Answers
Hi
When the dryer wont start it is the thermal fuse that is bad, you can test it with a voltmeter before replacing. This fuse is located inside the rear panel and it cannot be reset. If the fuse tests fine then it can be the main board that is bad and is due for a repair.
Hope this will help...
Posted on Jan 01, 2011
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
My maytag dryer,model no.DE303 makes a loude clank-a-d-clank noise as the barrel rotates. Sometimes the sound will change and smooth out, only to get lound again. How do I fix this? It still turns and drys...
This is likely caused by a worn-out drum roller. There are two of these which support the back of the drum and allow it to turn smoothly. Replacing these involves taking the front panels off and removing the drum.
Dec 15, 2011 | Maytag Dryers
I have a Maytag LSE1000. The dryer and washer each have an issue at the moment. The dryer intermittently won't engage when it is turned in. When you press the "regular" button to start it,...
I really have NO idea what's causing your Maytags to misbehave, BUT I can tell you that the Maytag service centers have always been very accommodating when I've called about problems with dishwashers, dryers, and washing machines.They have explained the construction of the appliance and even told me the type of tools I needed to make repairs! If you still have your owner's manual, the toll free number should be in there. I hope this helps!
Jul 28, 2011 | Maytag Dryers
When we push the button to start dryer it buzzes, it won't go and won't dry clothes. maytag admiral dryer ADG7005AWW
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 19, 2011 | Maytag ADG7005AWW Gas Dryer
Maytag DE303 Dryer
first check and make sure the power breaker is on. next the door when it closes there is a safety switch normaly there is a small hole around the frame of the door. when you push on it, you shoud hear a clicking noise. if you don"t, that switch will prevent the tumbler from turning another thing is the belt that goes around the tumbler if it's loose or broken the tumbler will not turn. that can be checked by accessing the bottom panel in the back the belt should be tight. good luck!
Jul 24, 2010 | Maytag 7.0 Cu. Ft. Electric Dryer
Maytag DE303 dryer installing the drum belt
No don't lube the idler pulley replace it. There are videos at www.appliancehelponline.com/servicemanual.html that can walk you thru the disassembly and also on replacing the belt. You can also enter in your model # for diagrams and illustrations.
Apr 09, 2010 | Maytag Dryers
I have a maytag dryer model number is mce8000ay
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Dec 23, 2009 | Maytag Neptune MCE8000AY Electric Dryer
How do i OPEN a maytag model DE303 dryer? Not just the door (duh), but the actual dryer itself, for repairs...
remove the two screws down by your toes . in front panel //pull out at bottom till panel is 45 deg . and the two top cli[ps will release . carefull to not brake the door & wires . remove wires and set side . hey your in .. now what do you want to do .. feed back pls .. mm
Dec 17, 2009 | Maytag 7.0 Cu. Ft. Electric Dryer
I have a model DE303 series 07 maytag electric dryer and it is not heating up?i am experienced in electrical
hi..A poor connection between the wire terminals and the
heater relay causes high current draw and damages the
terminals on the heater relay on the main control board.
check it out..
thank u..
kindly rate my response..
Jul 06, 2009 | Maytag Dryers
I am looking for a tint trap for a Maytag dryer model #DE303 Series 07 Serial # 189625 XJ
Try partsstore.com as they do have your part in stock. I would phone them to make sure their website information is correct. If for some reason this did not help you you can try the chat portion of this website
Sep 07, 2008 | Maytag Dryers
Dryers Logo
80 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
