Question about Nintendo Video Game Consoles & Games
We got a new internet connection. I have not changed the set up the Ds lite in years. It is giving me error code 51101 and asking for a different Wep "Key". What do I enter here?
DODNT KNOW
SAME PROMBLEM HERE
Posted on Feb 09, 2011
Why can't I connect my DS Lite to my Wifi?
hi Kevin,
The ds lite uses WEP encryption, you will most probably be using wpa/wpa2 which has alot better security but is not compatible with the ds lite. I think the dsi uses wpa and therefore works. I wouldn't recommend changing your current wifi to wep just to get on the internet with the ds lite.
Hope this helps
Paul
Jul 31, 2012 | Nintendo DS Lite Console
Im trying to connect to allspark wars on my ds lite and it says creating account and then it says an error occurred while communicating with the game server. my wifi connection is fine..thats not the...
I think the problem is your wi fi. You see nintendo uses a different security setting when connecting to the internet( i am unsure as to why) than most other consoles.
You have to access your router settings by putting in your routers IP address in the search bar then enter your router username and password(it is normaly admin and admin for both but it may be different for you) If the password is not admin smply look on the back of the router for it.
Now you find the option named internet connection and you should see an option called security or connection type. Then you want to pick the option WAP(default is WEP) and then save it.
With this new security setting you should have no probelms connectiong to the game.
Jul 11, 2012 | Nintendo DS Lite Black Console
I can't connect to the internet. My DS is giving me Error Code: 51300. What can I do?
According to Nintendo's tech support website, error code 51300 means that the access point you are trying to connect to is not compatible with the Nintendo Wi-Fi connection. Try to find another access point and see if it will work then.
Jun 29, 2011 | Nintendo DS Lite Console
Connecting to Wifi at home. Error Code 51102 What
A WEP key is a Security code but for some wireless providors a WPA-TKIP or WPA"-TKIp is used instead. check your connection details to find out which one yours uses and the use the appropriate settings.
Important notes would be that if your connection is using WPA-TKIP or WPA2-TKIP then the DS or DS lite will not be able to connect because they can only use WEP keys. If the system you are using is the Nindento DSi then all you need to do is to use connections 4, 5 and 6 found in Advanced Conection Settings under the internet option in the DSi Settings menu ( remember this method is only for use with other wireless securities than WEP keys like WPA-TKIP and WPA2-TKIP.)
Apr 03, 2011 | Nintendo DS Lite
My ds lite wont connect to our internet i have a wireless router the ds says the security settings are not supported by the nintendo ds
WPA and WPA2 are not supported by the DS Lite, only WEP and unencrypted wifi connections are. There is no known way at the moment to make the DS Lite support WPA of any form so your only three options are to go to WEP encryption, use no encryption (not recommended), or set up an adhoc connection on a computer with that is connected to your router that has internet connection sharing enabled.
Mar 10, 2011 | Nintendo DS Lite
No compatible access point in range - error code 51099
The Following website lists your Error Code. Per Nintendo:
"Likely cause: It appears that the settings entered into the Nintendo DS are not compatible, or the router's broadcast settings should be changed.
How to fix: Try creating a new connection with your system. Nintendo DSi owners trying to play multiplayer games will want to be sure to read the "Trying to play online multiplayer with Nintendo DSi."
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51099&system=DS&locale=lang
Mar 10, 2011 | Nintendo DS Lite Console
Pokemon black, i cant get the liberty pass, Error code: 51101 i try to do the first step instructed by the step booklet that comes with the game, and it says " No Compatible Access point in...
Error Code: 51101 Was this information helpful?The WEP key for the Access Point you are attempting to connect to has changed since you last connected.
What to do:
    • Errors ending in 0 = connection file 1
    • Errors ending in 1 = connection file 2
    • Errors ending in 2 = connection file 3
    • Errors ending in 3 = Nintendo Wi-Fi USB Connector
  • Verify the Access Point's WEP Key is entered correctly into the Nintendo DS. If your router has slots for more than one WEP key, the first (#1) must be the one selected on your router. If you need assistance, click here and select your router manufacturer and model number. If available, our router pages can provide specific steps and information that may help you with your router's WEP Key.
    If you have multiple connection files saved to your Nintendo DS, the error message you received can help determine which connection file may be experiencing a problem:
If the above information does not work, and you are connecting at home with a wireless router, there could be settings on your router that need to be adjusted. Please click here for more information.
Mar 06, 2011 | Nintendo DS Lite Console
How to fix error code 051110-1
This code means that it couldn't access the Wi-Fi access point. Make sure you are close enough to your router, and your connection settings match. Also, try using WEP (instead of WPA) if you aren't already.
Jan 25, 2011 | Nintendo DS Lite Console
Getting Error code : 052000-1
Error Code: 052000 Our experience has shown that this error message is solved by performing a manual setup on the Nintendo DS. Please follow these steps:
The first thing you'll need to do is find out what IP address range you should be using. To do this:
  1. Click the "Start" button in the lower left-hand corner of your computer.
  2. Next, you will need to access the command prompt. To do this:
    • Windows XP users click "Run."
    • Windows Vista users click inside the search bar.
  3. Type "cmd" into the box and press Enter.
  4. Type "IPCONFIG/ALL" and press Enter. The IP address, Subnet Mask, Default Gateway, and DNS servers of the PC will be displayed.
The IP address you are going to assign to the Nintendo DS must be 10 digits higher than the PC's. (e.g., 192.168.1.100 becomes 192.168.1.110). The DS and PC must have different IP addresses.
Enter in the exact same values for your Subnet Mask, Default Gateway, Primary DNS and Secondary DNS. They must be the same for your Nintendo DS and for your PC.
  1. Click here to go to our Wireless Router Configuration page.
  2. Use the drop-down box on the left to select, if available, your router manufacturer.
  3. Click on your router's model number, if available.
  4. Read any "special notes" at the top of the router's page. Many issues can be solved by changing the settings found in the Special Notes. Follow the instructions and test the connection.
You will now need to manually assign this new IP address to your Nintendo DS. For step-by-step instructions on how to do this on your Nintendo DS or Nintendo DS Lite, please click here.
Check Nintendo's router info for special notes, if available, for your router.
If you try these steps and you get a different Error Code, please review the values that you entered carefully, since an incorrect manual setup will cause another Error Code to appear. If the 52000 Error Code persists, than the problem may be caused by a basic setting in your router such as transmission rate. Please carefully read the instructions below:
If you are still unable to connect, please call 1-800-255-3700 in the USA or Canada for more information.
Aug 16, 2010 | Nintendo DS Lite Console
Nintendo DS vs. ActionTec GT704WG
Your DS may need another connection that is only blocked with a red lock. (Meaning WEP code locked.) If so, phone a computer tech support to help you set a connection with Wifi (wireless connection) and ask him/ her to set it to WEP code and "blocked". Then ask them to temporarily leave while you set your WEP password. A grey lock means that your DS is not compatible to your access point.
Feb 07, 2009 | Actiontec (GT704WG) Router
Video Game Consoles & Games Logo
51 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
