Question about Avanti W789SA Top Load Washer
Where can I find a new drain hose for this machine?
    Sergeant:
    Champion:
  • 250 Answers
Sears/lowes
Posted on Dec 30, 2010
Need to replace tub, How??
Depends on the make and model
Jan 11, 2017 | Washing Machines
Tub has come off its springs?? rince cycle clothes still very wet. how to fix diy??
Step 1 - Record Specifications Carefully read your owner's manual to find the specifications for the washing machine drain hose. If you are unable to locate it, look at the steel tab at the back of the washing machine, and write down the model and serial number instead.
Step 2 - Purchase New Hose Head to your hardware store and show this information to a representative to get help in finding an appropriate replacement drain hose.
Step 3 - Cut the Power and Water Before you start replacing the washing machine drain hose, make sure to pull the power cord out the wall socket. Better yet, turn off the power supply to the washing machine at the circuit breaker.
Similarly, turn the knob on the water supply line to the washer. If you cannot locate it then temporarily turn off the water altogether. Afterward, lift and shift the drain tube into a bucket, so that any accumulated fluid in the hose will fill this instead of spilling out all over the floor.
Step 4 - Remove the Old Drain Hose Your drain hose will be held in place by clamps attached at the back of the washing machine. Hold the clamp with pliers and unscrew it out of its position with a screwdriver. After removing the clamp, inspect it. If it is not damaged or corroded by rust it can be used again, but if not toss it away and install a new clamp after the replacement hose is in place.
Step 5 - Secure the New Drain Hose Take the new hose and slide the clamp on; it should go through the straight end. Now, place the hose onto the connector located at the back of the washing machine, and slide the clamp to where the hose rests on the connector. With a wrench, make the hold of the clamp tight. Make sure it is fit in properly so that you will have no problems with leakage.
Step 6 - Put the Machine Back and Test Place the washing machine back in position, and reconnect the drain tube to the pipe. Then, turn on the power supply and open the water supply so you can test that everything is working as it should.
I have a old maytag washing machine that drain hoses needed replaced got new ones put on and it half kinked.so now it will not drain right what do I do
The replacement drain hose may have to be replaced with a replacement drain hose maybe of better quality (non-kinking) or connected and routed to avoid kinking.
Apr 19, 2014 | Maytag Washing Machines
I purchased a new washing machine, Samsung SW50V3WFP, this is top loading washing machine. Problem: Water is draining out from the machine from drain hose, I cant fill water in machine to wash after...
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Jul 02, 2011 | Washing Machines
Model - LG F1480FD. Need to replace drain hose. Please advise best way to get in to replace drain hose (? from bottom side etc.)
underneath......
drag maching to outside door and let old hose hang outside
this will drain alot of water out of machine then upend it to replace old hose with new 1
cheers
Mar 27, 2011 | LG WM-1480FHD Front Load Washer
Whats wrong with our ge washing machine it keeps draining water,it is brand new just arrived.what do you think is the solutions to our problem. everything is being put together, we already install the...
make sure the drain hose is higher than the washer tub sounds dumb i know but if the drain hose is left lying on the floor going into a floor drain or something it will not fill up
Mar 23, 2011 | GE WBSR3140DW Top Load Washer
My wf t1001tp wont drain...can anyone help?
sounds like a blocked drain hose or a faulty pump motor..If the machine can be drained by putting the drain hose lower than the water level then the hose is not blocked and it may be the pump...Make sure the hose leaves the machine from under the tub and not high on rear of washer. Obviously water won't flow uphill..If the pump has failed a new pump motor is much cheaper than buying a whole new pump....Nomess
Apr 04, 2010 | LG WFT1071TP Top Load Washer
Water wont drain during spin
Check the drain hose, drain pump and the drain sump for any object that might be blocking the passage of water.
Drain Problem Troubleshooting Guide for Frigidaire Front Load Washers
  1. Safety first. Unplug the machine.
  2. Remove the drain hose from the drainage.
  3. Cushion the top rear edge of the machine with a thick cloth then lean it back against the wall.
  4. Remove the two screws holding the front access panel to the base of the machine.
  5. Pull the front access panel down and out.
  6. Lay a towel under the drain sump to prevent flooding the base of the machine.
  7. Remove the drain sump from the tub by loosening the clamp holding it..
  8. Remove the drain hose from the pump by loosening the clamp holding it.
  9. Remove the two screws holding the pump housing to the base of the machine.
  10. Disconnect the wiring harness from the pump motor terminals then pull the pump out of the machine.
  11. Remove the drain sump from the pump by loosening the clamp holding it.
  12. Check the drain sump and the drain hose for any clogging and clean it.
  13. Replace the drain pump if the drain hose and drain sump are not clogged. Install the new pump on reverse of the removal steps above.
Feel free to ask for further assistance if necessary.
Jan 23, 2010 | Frigidaire ATF6000ES Front Load Washer
GE Drain Hose
Hi, Does this washer have to pump the water up into a drain? If it is possible, it would be better for the machine if you can bring the drin pipe closer to the washer. I know it is not always a possibilty. The longer the drain hose, the harder it is on the washer and sometimes the cloths don't spin out as dry as they will with a short drain hose.
Vic
Jun 20, 2009 | GE Profile WPRE6100G Top Load Washer
Washing machine wont drain
the drain hose assembly is similar to a p-trap underneath your sink. make sure your drain hose is a upside-down J. from what you describe your hose isn't a p-trap.
Nov 02, 2007 | Washing Machines
Avanti W789SA Top Load Washer Logo
99 people viewed this question
Top Avanti Washing Machines Experts
Jim Thurston
venugopal durairajan
Kolbrun...
Are you an Avanti Washing Machine Expert? Answer questions, earn points and help others
