Question about Cell Phones
I have a motrola tundra, that will not reconnect to a ford sync system after the key is turned off
  • jhooper9 Jan 05, 2011
    THE SOLUTION WORKED FINE FOR 30 MIN, THERE WAS NO OPTION TO ALWAYS CONNECT IN THE SET UP. THE SYNC MESSAGE IS CANNOT FIND PHONE. ANY CLUE WHAT IS GOING ON? IS THIS A PHONE OR SYNC PROBLEM
    THANKS
    JHOOPER
  • 437 Answers
Hi jhooper9 ok i need you to disconnect the sync from your phone. delete the motrola out of your car. Go to sync and make sure your reg to the sync site. Now after you you see that your rg on the sync site. Go back to the car and reload the motorola to your ford. You will be asked if you wanted to always connect to the car. Once you pair the phone back to the car you should be go now. Hope this helps.
Posted on Jan 04, 2011
  • RONALD CARTER JR Jan 06, 2011
    It sounds like a sync problem take the phone to your carrier and have them test to see if your
    blue tooth connects to any other phone. Also you can see if the phone connects to a test blue tooth in the store. Now if it doesn't work it sounds like a sync problem. You may need to reg on sync. Then do all of the above steps again. Hope this helps.
How do you disable a 2008 Toyota tundra anti theft system
Tip & How-To about Cars & Trucks
Want to bypass your vehicle security system?
The short answer is you can't!
All modern cars have alarms and immobilizers. There is a chip in the key and a chip in the ignition lock. If both are present, the ECM (engine control module) releases power to the ignition circuit. When you turn the key, the starter spins the engine and you get a spark. If any one of those three items are not in the chain, you get the engine to turn, but no spark. There is no way to beat the system.
The immobilizer is in place to stop exactly what you are trying to do. Vehicle theft has reduced to virtually nil.
Posted by Andrew... on Mar 26, 2016
Nov 20, 2016 | 2008 Toyota Tundra
My truck will turn over but won't start
Toyota Tundra Maintenance & Repair Questions - CarGurus
www.cargurus.com > Questions > Toyota > Tundra
CarGurusfrustrated2000tundra asked a 2000 Toyota Tundra 2 Dr SR5 V8 4WD Standard Cab LB Maintenance ... My 2000 tundrasr5 4.7l 4x4 wont start! ... 2008 Toyota Tundra ...won't Start ... Report. rckwll asked a 2001 Toyota Tundra Maintenance & Repair question 2 months ago ... 2002 Toyota Tundra Turns Over But Will Not Start.
Toyota Tundra Questions - CarGurus
CarGurusGet fast answers to your Toyota Tundra questions from experts in the CarGurus automotive ... My 2000 tundrasr5 4.7l 4x4 wont start! Thought wasn't getting fuel because tries to turn over but wont. ... Tundra Dead Battery, How Do I Open The Door Or Hood To Recharge? ... 4wd Hi Light Flashing, But Will Not Engage.
Jan 22, 2016 | 2001 Toyota Tundra
How do I connect to Ford Sync?
To use any of the phone features for SYNC such as making a call, receiving a text message, or using SYNC Services, you must first connect, or "pair" your Bluetooth-enabled phone. Pairing is what allows Bluetooth devices to communicate securely with each other.
Please note that SYNC can make and receive calls using only one paired phone at a time.
Before you start
There are a few things you should do before starting step 1:
blobserver?blobkey=id&blobwhere=1309207543643&blobcol=urldata&blobtable=mungoblobs&b=91
Turn on your
  • Mobile phone
  • Vehicle
  • Radio/SYNC
blobserver?blobkey=id&blobwhere=1309207543650&blobcol=urldata&blobtable=mungoblobs&b=91
Enable your phone's Bluetooth feature and make your phone discoverable.
Press the Phone button to access the Phone Menu. Press OK. Add a Device displays. Press OK.
SYNC prompts, "Press OK to begin pairing device." Press OK.
SYNC prompts, "Search for SYNC on your device and enter the PIN provided by SYNC." Press OK.
A six-digit number displays on the screen for three minutes, during which time SYNC actively seeks for the same number from your phone.
Type the number displayed by SYNC on your phone key pad.
Upon successful pairing, a message displays confirming the phone is connected.
Exit the phone pairing process by pressing the Arrows to select the Exit message and press OK to leave the Phone menu.
Aug 25, 2014 | Cell Phones
Where is the shut-off switch for tundra alarm
Hi, I am not sure where the switch is but 3 months ago the following was posted by:-
liverhuyen2003 answered 3 months ago
Make sure the drivers front(left front) door is closed and you have your car keys. Insert your door key into the drivers door and turn it to the locked position two times. Then turn the key to the unlock position twice. The alarm should be disarmed, now.
SECOND TECHNIQUE: If not then take the ignition key and turn the ignition switch all the way ON then OFF then ON a second time and OFF again. These are the procedures for nearly all factory alarm systems. If neither of these works you probably have an after market(add-on) alarm system.
Warnings This technique is only for use on your own car that you own and have keys for. If you don't have the keys- disconnect the negative battery cable to stop the horn until you get your keys. Then reconnect the negative terminal and proceed to step one.
Hope this helps!
Apr 06, 2014 | 2001 Toyota Tundra
My Toyota Tundra 2000 had a flat battery, due to my driving it so little. My son rigged up a trickle-charger as a long term solution & hooked it to the flat battery. He unlocked the truck doors with...
Hi Moyerwm, Disconnect the battery for about two minutes and reconnect. If that does not help, have the battery fully charged and then it should be fine. Regards John
Feb 01, 2013 | 2000 Toyota Tundra
Bmw motorcycle theft alarm will not deactivate .
unplug the battery, leave for a while to discharge the system. Put keys in ignition and turn to first position then reconnect battery. Hopefully then, you will have reset the alarm or at least be able to re sync it.
Sep 14, 2009 | Anti-theft Alarm System 3 Series E90 E92...
After disconnecting the battery and then reconnecting it on my 2000 Toyota Tacoma, the alarm goes off and the car will not start. I do not have a remote for this car and need help in a course of action. I...
If after unlocking the driver door with the key and still no luck, put the key in the ignition and turn forward to start (if it won't start turn forward anyway) then push you're red reset button on the dash. That should do it.
Jul 10, 2009 | 2001 Toyota Tundra
Cell Phones Logo
51 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
